Old 26th September 2008, 09:51   #1
High Torque's Avatar
Post Santro - Dual Exhaust
Is it ok to install dual exhaust on a Santro? Can anyone help me with the pros and cons of having a dual exhaust.
High Torque
High Torque is offline   Reply With Quote
Old 26th September 2008, 10:20   #2
Jaggu's Avatar
Thanked: 8,686 Times
Welcome High Torque to TBHP. What do you mean by dual exhaust, do you mean 2 tail end pipes or 2 separate pipes right from headers onwards?
Old 26th September 2008, 10:23   #3
Hey Jaggu,
I meant two seperate pipes right from the header.
HT
Old 26th September 2008, 14:27   #4
Thanked: 152 Times
In your case, i assume there will be a loss of power due to inadequate backpressure. The Santro is a small car with a small engine! You dont need twin exhausts.
Cyrus43 is offline   Reply With Quote
Old 26th September 2008, 14:28   #5
Jaggu's Avatar
Then you can build and 4*2 exhaust system, very honestly its an overkill, unless you are into heavy performance territory. It will also be a pain to route the 2 pipes in the space of one.
Straight forward approach will be to go for a 4*2*1 system, any good modfication workshop will be able to help you or after market vendors like automech will have ready made kits.
Old 27th September 2008, 07:26   #6
Jaggu/Cyrus, Thanks for the info.
High Torque
Dual Exhaust, How good are they? monty9991 Modifications & Accessories 9 20th August 2010 15:06
2 Subs - Dual Mono or Stereo - "Kb ka dB" kb100 In-Car Entertainment 847 1st October 2007 07:52
For Sale : Santro - FreeFlow Exhaust, K&N Air Filter... rareone Shifting gears 2 28th June 2007 12:51
Dual Sim Adaptor v.tec Gadgets, Computers & Software 0 9th March 2006 20:05
