Old 29th September 2008, 19:30   #1
Thanked: 12 Times
Default Innova Clutch height modification
I have owned an Innova for about 6 months now. I am having a problem with the clutch height which is a little too high for my left foot (I am a shoe size of 8.5 so its not that i have small feet). I need to lower the clutch height by about 2 inches so that it is closer to the center of my left foot. Any advise on how to do this?
If i cant fix this, then i need to sell the innova and go for some automatic car as my office is about 25 km from my home in bangalore and the traffic really sucks
Do advise
Amit
originalamit is offline   Reply With Quote
Old 30th September 2008, 13:49   #2
Thanked: 103,400 Times
I wear a shoe size of 9 - 10 (dependent on brand & type) and haven't faced this problem in the Innova. However, since you evidently are, lets get down to solving it. Be prepared for some amount of trial & error:
1. Logically, a thick floor mat (1/2 - 3/4 inch) will raise the level at which your foot rests and hence, reduce the distance to the clutch. This has got to be simpler than altering your clutch pedal height.
2. How about visiting a known garage (Psycho's, v1p3r's etc. etc.) and trying to fit in a custom-made spacer (or similar)? Will require a little jugad but shouldn't be that difficult.
Hiring a chauffeur will work out cheaper, if you consider the $$$ that you will lose in selling a 6 month old car. Not to mention the convenience!!
Old 30th September 2008, 17:26   #3
Thanked: 12 Times
thanks for this advise...I'll give the mat thing a try this time...maybe put some thermocole below the rubber mat might do the trick..
alternatively, can you let me know where these garages are located in Bangalore?
Thanks a ton !
Amit
Old 30th September 2008, 19:06   #4
badboyscad's Avatar
Thanked: 172 Times
Or
how about using a dead pedal ?
badboyscad is offline   Reply With Quote
Old 1st October 2008, 07:29   #5
Thanked: 12 Times
Hmm, this makes sense too. I think one of these options should work well. I'll drop by at the accessory shop and find out a good fit. I'll avoid doing any major rework on the clutch height as either padding or a dead pedal should solve this issue.
Thanks all for your inputs ! This is a terrific forum.
Amit
Originally Posted by badboyscad View Post
Or
Attachment 54643
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Using clutch and designing clutch... The Wolf 4x4 Technical 55 9th May 2011 11:50
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
