Old 16th April 2009, 03:40   #16
NomadVagabond's Avatar
Originally Posted by COUGAR View Post
Can 4WD be retained after the engine swap? Or will the gypsy be a 2WD?
Yes the 4WD can be retained after the swap. It all depends on which engine you are swapping with and how far the engine is going into the firewall. The transfer case should mate well enough. I might be wrong though. Kindly correct me if I am.
Anirban.
P.S: The Gypsy which I had mentioned before was originally a 410 on which a 1800 Isuzu petrol engine was swapped. It retained the 4WD. The owner had mentioned that the firewall was reworked and the original transfer case and the GB of the 410 was used in it.
NomadVagabond is offline   Reply With Quote
Old 17th April 2009, 13:44   #17
Thanked: 226 Times
Cougar,
I have swapped Isuzu engine and gearbox for my gypsy MG 410 retaining the transfer gearbox. The advantage with gypsy is transfer gearbox is divorced unlike jeeps. So, you can reposition the transfer gearbox mounting and align the main gearbox with T-Case and propeller shafts.
Please see my thread Powering up gypsy.
Dwarak
dwaraka is offline   Reply With Quote
Old 17th April 2009, 14:13   #18
esteem_lover's Avatar
Thanked: 451 Times
@ kaushik, If you are not going ahead with this project, could you please pass the Baleno engine here ?
Old 24th April 2009, 12:24   #19
khan_sultan's Avatar
Thanked: 3,872 Times
Default Gypsy Engine Swap: 1.6L Baleno vs 1.8L ISZ. Which one is more VFM?
To cut a long story short; 'IF' one were to consider an engine upgrade to the 1.3L mpfi motor of the Gypsy, which would be the more VFM option between 1.6L Baleno engine vs the 1.8L ISZ engine.
Assumption: The owner wants more low end torque/power than what is currently present (for off-roading purposes)
Parameters to be considered:
  • Cost of the swap/parts/labor
  • Availability of mechanics/workshops who have been there done that
  • Time factor for the swap job
  • Ancillary mods to be done for swap (e.g, shafts, body work etc etc)
  • Reliability factor
  • Future maintainability & serviceability, spare parts availability
  • Weight of the engine + swap parts
  • Availability of the donor engine
Specs (Do these even matter?):
1.3L Mpfi Gypsy Engine:
  • Power: 80 PS @ 6000 rpm
  • Torque: 103 Nm @ 4500 rpm
1.6L Mpfi Baleno Engine:
  • Power: 94 PS @ 5500 rpm
  • Torque: 130 Nm @ 3000 rpm
1.8L Mpfi ISZ Engine:
  • Power: 75 PS @ 5000 rpm
khan_sultan is offline   (2) Thanks Reply With Quote
Old 24th April 2009, 12:31   #20
Sha
Sha's Avatar
What khan next modification is getting planned. I would prefer baleno engine more reliability and MASS centres to repair anytime.
Sha is offline   Reply With Quote
Old 25th April 2009, 20:52   #21
headers's Avatar
Thanked: 464 Times
Of the 3, I'd pick the 1.6 as it is more rev friendly than the 1.8 and 1.3 and generates the max torque too!!
But would love to check dwaraka's Ipszy before that!
Old 26th April 2009, 21:14   #22
Mpower's Avatar
Thanked: 1,687 Times
Baleno powered Gypsies have been built and raced. Quite popular in the T1 category of Raid de Himalaya. The top guys like Suresh Rana and Sunny Sidhu run these.
Any idea about engine weight? The isuzu is the only one with an iron block IIRC. Is a lower final drive doable in the 1.3 gypsy for crawling.
Old 27th April 2009, 00:08   #23
renegade's Avatar
Thanked: 38 Times
i guess calmini makes adapter kits for gypsy to plonk in a 1.6 engine. I have seen one on a gypsy in shimla it even had coil all over suspension and has a baleno engine and yes it so very rev friendly.
renegade is offline   Reply With Quote
Old 27th April 2009, 09:47   #24
The Raid reports mentioned that these had reliability issues -- that's what I have read in various reports. Including a certain turbo Gypsy
As per what people say, it is 30kgs+ heavier than the 1.6
he he. NO WAY. At best crawling in jungle trails
From what I have heard, there is NO need for any adapter plate etc for using the 1.6 Baleno mpfi engine (assuming that the base vehicle is a 1.3L mpfi gypsy)
khan_sultan is offline   Reply With Quote
Old 16th August 2009, 02:00   #25
MexXxentric's Avatar
Thanked: 11 Times
for the 5 speed GB, the top studs match. Bottom ones need to be drilled in the engine frame.
Yep. Clutch failure and driveshaft failures owing to the extra torque generated
MexXxentric is offline   Reply With Quote
Old 16th August 2009, 11:11   #26
Awaiting Email Confirmation
Thanked: 20 Times
Wont the Performance clutches for the baleno be of any use here? Sorry for the n00b question.
Driveshafts- well..*shrugs*
Old 19th August 2009, 16:33   #27
Thanked: 11 Times
When we use gearbox from Gypsy we can't use baleno's clutch.
whatever clutch we use should match and fit in the gearbox bellhousing and spline shaft.
The difference in both baleno's and gypsy's clutches are not much.
both are of same outter diameter but the spline shaft dia. is different.
The gypsy's clutch is certainly beefy as it got to transmit high torque in 4L gearing
( unable to upload a picture due to low bandwidth)
Performance clutches made for Gypsy will solve the issue of early clutch burnout.
There are a lot of such options available in U.S like centraforce dual friction clutch
Old 10th September 2009, 00:30   #28
desertfox's Avatar
Thanked: 544 Times
My guess is for 14 BHP extra power and no modification in torque at low rpm and more sustained flat torque curve from 1500 to 4000 rpm, an engine swap is not worth the trouble.
Why Isuzu, for that matter even Diahatshu Rocky 2000 cc engine ( Daihatshu Rocky has a very similar chassis and common drivetrain systems as Suzuki Samurai ) can be mated and fitted into a Gypsy 413 W, but is it worth it ?
In one case I have seen a 1.6 Baleno engine transverse mounted in a Gypsy which originally has a longitudnal engine. This is going to lead to constant trouble.
The best and reliable option to get more out of an MPFI, 1.3 Litre Gypsy is.
Modify the intake - install a K & N filter with an isolator kit if possible.
Install a free flow exaust
Install a heavier cable set
Upgrade to quadra polar or platinum / Iridium Spitfire spark plugs
This modification alone will get you an additional 14 to 15 bhp.
If more power is required, another 4 to 5 BHP, modify the ECU.
And for offroading, modify the suspension, use high performance leaf springs and Nitro Filled shocks.
Install genuine mud / rock crawler tyres and your Gypsy will never let you down off road.
desertfox is offline   (2) Thanks Reply With Quote
Old 5th November 2009, 15:59   #29
Thanked: 11 Times
There is modification in the torque curve. 1.6 will be more drivable.
For a 1000 cc gypsy, this modification will bring great change
Oh my god.
too unrealistic & dimensionally impossible.
can you get more details on this regarding the gear box used and transmission layout? I am too curious
Install a free flow exhaust
what about torque? even if you get a low&mid range FFE, what will be the torque gain?
Tyres alone wont help. You need low end torque to drive these monster tyres.
Note:every engine modification or transplant will affect the vehicle's reliability.
1.6 engine transplant can give maximum benefit with minimum compromise on reliability. a better choice.
Imagine the result if you do the same in 1.6 engine
MexXxentric is offline   (1) Thanks Reply With Quote
Old 6th November 2009, 09:03   #30
arjunrudra's Avatar
Thanked: 13 Times
that can be so surely done.My friend from bombay is getting it done now.
maybe he could help u out.
go to 4x4->vehicles->xtreme power pimps a gypsy.
arjunrudra is offline   Reply With Quote
Swapping a Santro Xing for a Fiat Palio 1.2 EL honeybee Hatchbacks 47 9th August 2013 21:01
Have you ever been a victim of Parts-Swapping ? mithun Indian Car Dealerships 14 1st September 2011 23:32
Is it worth swapping my Accent for a new Chevy Spark! krish82 Sedans 22 10th August 2008 08:38
Advice needed : Swapping a Swift Engine D1ISTHE1 Modifications & Accessories 43 17th June 2008 23:17
