Old 25th February 2011, 00:57   #31
IndrojitSircar's Avatar
Thanked: 116 Times
Default Re: Gypsy engine swapping with Baleno 1.6L engine ?
If the base vehicle used is a 1.3 carb model, What are the things would one need for the 1.6 transplant?
1). 1.6 Engine
2). Wiring Harness
3). ECU
What are the mods that need to be done to get the 1.6 into the Gypsy ?
1). Reduce the Sump height
2). Drill additional holes in the bell housing of the 5 speed transmission
Could anyone add to this please ?
Old 22nd March 2012, 19:00   #32
Default chevrolet optra 1.8 engine swap for gypsy possible or not
hi every one
i am planning to build a gypsy for off roading
as of now i have a rally prepared 1.6 gypsy which i dont want to use for offroading
have a question that is it possible to plonk a optra 1.8 engine to gypsy with and if yes then what all modifications need to be done as i have an optra which no one is using so alll the parts are available as i will be a picking an army disposal for this project
thanks
hitesh
funmaniac is offline   Reply With Quote
Old 25th December 2012, 20:28   #33
atheistrical's Avatar
UPDATE: I tried to create a new thread for the following queries, but the moderator removed the thread twice, asking me to post in existing threads.
I have a worn out (I mean, externally) MG-410 (1988 Model - let's call it "X") and have recently acquired a MG-410W (1995 Model - and let this be "Y"). "Y" has engine heating problems and requires a Engine-Head change (as suggested by my reliable mechanic) at ≈ 15 K INR expenses. However, when compared to "X", this vehicle has immense pulling power (or torque as some may say).
  • Is it because of the gearbox? Is the gearbox of 1995 model better than 1988's?
The engine of "X", on the other hand is a charm and feels like a breeze to the ear. I mean, it produces extremely low noise when running, compared to "Y" whose engine rattles, like other normal kins. I have driven a lot of Gypsies and the difference in engine sound is very clear. Also, "X" has an engine with SUZUKI engraved on it whereas "Y" has a MARUTI mark on it.
  • Is the SUZUKI engine any better than MARUTI's? If no, then what are the differences and why is there a difference in their respective engine running noises?
I was wondering if the 1988 SUZUKI engine was weaker to the 1995 MARUTI engine, and hence the difference in power. With so many gurus and Gypsy worshipers here, I beg to seek enlightenment please.
My decision to adorn the newly acquired beast "Y" with the silent engine of "X" rests on you BHPians' feedback. The cost of engine swap is ≈ 2 K INR.
atheistrical is offline   Reply With Quote
Swapping a Santro Xing for a Fiat Palio 1.2 EL honeybee Hatchbacks 47 9th August 2013 21:01
Have you ever been a victim of Parts-Swapping ? mithun Indian Car Dealerships 14 1st September 2011 23:32
Is it worth swapping my Accent for a new Chevy Spark! krish82 Sedans 22 10th August 2008 08:38
Advice needed : Swapping a Swift Engine D1ISTHE1 Modifications & Accessories 43 17th June 2008 23:17
