Old 6th October 2008, 22:19   #1
Default Swap i10 rear suspension into a Santro?
From eyeball measurements, the new i10 suspension looks like a good candidate to be retrofitted on a Santro. The Santro comes with a dead axle with a panhard rod which has pretty poor roll stiffness and is overly stiff to boot. i10's Codependent Torsion Bar Axle rear suspension is definitely newer tech and has slightly better spring ratios. It also seems to have the body-roll under better control. Though i haven't measured it, it looks like rerouting the exhaust is probably the only change needed. Has anyone gotten any further on this than just looking at them?
P.S. : Motivation : Actually want to upgrade to a new (more fun to drive) car but if the finances don't fall together, may have to simply work on bettering my Santro to make it a little more involving to drive.
ajith is offline   Reply With Quote
Old 7th October 2008, 12:36   #2
Thanked: 89,494 Times
You'd be better off customising the existing suspension of your Santro, with performance upgrades. Will cost you lesser too! I am not aware of specific component upgrades available for the Santro, but am sure others could help you out there.
Old 14th November 2008, 04:56   #3
Thanked: 42 Times
Default 2007 Santro -- Rear Suspension
Hello Guru's,
I've heard lot of people who complian about the rear suspension in Santro.
I want to know what modifications can be done to the suspension so that people in the rear have better comfort.
zaveed
zaveed is offline   Reply With Quote
Old 2nd February 2009, 13:43   #4
simply_sunny001's Avatar
Thanked: 15 Times
i would love to hear about any mod that people have done ti improve the ride quality in Santro.
my cousin has one santro 2.5 years/1.2L kms old,and i can the suspension is totally dead.and trust me it was never gr8 even when new.
so looking for some good alternatives.
simply_sunny001 is offline   Reply With Quote
Old 5th January 2011, 18:13   #5
supratim07's Avatar
Thanked: 29 Times
Default Re: i10 rear suspension in Santro?
I replaced my 2006 Santro XL rear dampers with Gabriels Gas shocks but i don't see any improvements. Still feel hard bumpy ride at the rear.Any suggestion would be helpful.....
supratim07 is offline   Reply With Quote
Old 6th January 2011, 18:14   #6
Default Re: Swap i10 rear suspension into a Santro?
supratim07, the reason tall boys generally have stiffer suspensions (hence, the bumpy ride at the back) is because they are tall! Softer setups will increase the chance of a roll over. The easiest way to better comfort levels will be:
- Choose a comfort oriented tyre
- Lower the air pressure by 1 - 2 PSI (in the city ONLY)
2009 Hyundai i10 Rear Suspension Collapsed!! Torsion Beam Cracked! Sankar Technical Stuff 35 19th February 2012 20:29
Spark, Santro, i10 or others - FE important - 1500kms/month, Rear seat not important monishdesign Hatchbacks 7 11th March 2008 12:27
Swap: Vtec engine into OHC Type I crazydiablo Modifications & Accessories 7 28th September 2007 00:13
Engine Swap Tata 407 into a Mahindra Jeep moralfibre Modifications & Accessories 11 30th July 2007 18:48
