Old 10th October 2008, 17:29   #1
Default Fit Powersteering to my Zen
Hi Folks, I have a 2000 Zen MPFI LX, I wanted to know if i can convert it into a Powersteering model. how much would it cost and where to get it done in bangalore if possible?
enigmatictech is offline   Reply With Quote
Old 10th October 2008, 20:12   #2
gpa
gpa's Avatar
Thanked: 282 Times
Hi enigmatictech,
It is not advisable to get this done. Retrofitting a power steering would involve a lot of changes to your vehicle current setup and will prove to be very expensive. It will prove to unreliable as well.
If you are looking to drive with a power steering, it would be best to trade in your old Zen for one with EPS (Electronic Power Steering)
Cheers,
gpa
Old 10th October 2008, 21:02   #3
archat68's Avatar
Thanked: 290 Times
You can install a hydraulic power steering (HPS) in Zen - once I inquired with my service center and they gave me an estimate of 6-7K for that.
EPS will be costlier and will set back you to 25K IMO.
All estimates are for job done outside A.S.S.
But its better to avoid these changes - as when reselling the car you will not get the same return for the amount spent.
BTW for Zen do you really need a power steering?
archat68 is offline   Reply With Quote
Old 11th October 2008, 10:14   #4
Thanked: 103,535 Times
Please DON'T!! For a device as crucial to safety as the steering, do not mess with factory components.
Exactly. The Zen's steering is pretty light, even a low speeds. Live with it.
Old 16th October 2008, 19:17   #5
Jay
Jay's Avatar
Can be done, Have seen one fitted with an EPS, costed him around 22k i guess. Been running without any problems.
Jay is offline   Reply With Quote
Old 20th October 2008, 01:14   #6
yzfrj's Avatar
Thanked: 119 Times
22k??
err.. as GTO pointed out Zen's Steering is not that bad after all. Even with the 165/65/13 its pretty "light"
22k no way, I'm gonna spend that much.
PS did cross my mind while parking, on the move its pretty ok.
yzfrj is offline   Reply With Quote
Old 20th October 2008, 11:00   #7
Thanks very much for your wise thoughts folks, The main issue was with parking and nothing else, I was also "spoilt" after driving my friends powersteering model. any way if its not worth why bother.
Old 20th October 2008, 11:13   #8
dkamath's Avatar
Thanked: 120 Times
Hi, so long that you get the conversion/retrofitment done by an authorised dealer, i see no problem in going for it. I had got the power steering retrofitted on our Indica DLE about 5 years ago, and it's working fine till date, with no issues whatsoever.
dkamath is offline   Reply With Quote
Old 5th March 2010, 21:00   #9
yzfrj's Avatar
Thanked: 119 Times
Yesterday I went to MASS to check the brakes of my Zen. The owner of the shop during the test drive commented that my steering is heavier than usual.
I told him its running 165/65/13 and its an old model and there was no Power Steering at that time on Zen.
He said carb Zen did come with PS.
To my knowledge it has not.
I requested for further info and he said he can give the part number too.
Yes MGP
so here you go
Part number Description Price
48200-72F21 Steering Column 40,165/- (INR)
38720-700F00 Controller Box 14879/- (INR)
He insisted that this is an Electronic PS.
Any thoughts guys ?
Old 5th March 2010, 22:00   #10
dar3dev|l's Avatar
Thanked: 88 Times
well i am using a 97 zen with tyre upgrade to 155/65/13 and really never felt a need of a EPS other than while parking
dar3dev|l is offline   Reply With Quote
Honda Fit (Jazz in India) gets a fit-ting facelift sidindica The International Automotive Scene 16 17th August 2011 10:03
Making a non powersteering car steering lighter. abhibh Technical Stuff 11 19th September 2010 14:22
What size speakers can I fit in Zen Estilo vebmetal In-Car Entertainment 11 28th September 2007 16:28
Zen MGA fog lamps fit WagonR ? prateekkaul Modifications & Accessories 2 9th January 2006 16:55
Honda Fit Sports Concept amit The International Automotive Scene 8 18th October 2004 18:35
