Old 21st October 2008, 22:37   #1
ak916's Avatar
Thanked: 145 Times
Default Problem with clutch
We have a couple of Zen's in the family. Both are 2005 MPFI, one is black and the other is Silver. Now the silver one has never had this sort of problem but for some reason the black zen's clutch has been giving problems, though both are driven identically.
Few months ago the Black Zen stalled as soon as we entered the city from one of our trips to kerala. We had to get it towed to a service center where they replaced the clutch plates.
Now I notice some vibrations just before i depress the clutch i.e. in normal position, the clutch is vibrating slightly. It is pretty unusual.. I wanted to know if someone is having similar issues with their cars...
And both of us who drive the cars dont "ride the clutch".
ak916 is offline   Reply With Quote
Old 22nd October 2008, 10:48   #2
Thanked: 89,540 Times
How many kms has the silver one run? No two cars are built identically so it's not necessary for them to be as reliable (or not) as the other.
If this vibration has cropped up only after the install, you need to have the mechanic check the marriage between your flywheel and clutch. The install is not perfect.
If the vibrations were present prior to the clutch job, you need to check the engine mounts.
Old 22nd October 2008, 11:09   #3
ak916's Avatar
Thanked: 145 Times
GTO - Silver has done 52k Kms and the Black is just 3k kms lesser. The problem started after the clutch job. I just want to be sure I know what is going on, before I take it to the dealer.
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Using clutch and designing clutch... The Wolf 4x4 Technical 55 9th May 2011 11:50
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
