Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 31st March 2005, 23:16   #1 (permalink)
Question basic mods for optra
hey guys,my dad is FINALLY ready to buy the optra(1.6),we will go to book it tomorro or maybe day after tomorrow,i wanted to know what basic mods should i make(maybe wheels),use it more on highways,also on security systems and music system.Please help guys
vandan is offline   Reply With Quote
Old 31st March 2005, 23:47   #2 (permalink)
libre sito's Avatar
The Optra 1.6 comes with a security system i guess as my friend has it on his optra 1.6 i think its an LS model.
Well music system and wheels all depends on your budget pal.
__________________
HAVE IT FLAUNT IT
libre sito is offline   Reply With Quote
Old 31st March 2005, 23:51   #3 (permalink)
i think i will be taking the basic 1.6 not the ls...also i wanted to know wether it is even necessary to change the wheells for highway driving...my dad thinks alloys is a waste but i will convince him soon...
Old 1st April 2005, 02:54   #4 (permalink)
jigarmuni's Avatar
yeha dude for highway driving alloys and tubeless tires are a must. As far as other mods go, you can basically start off with putting an air filter & a mild exhuast (Since ur dad is driving the car). This alone should add another 7 HP to your cars performance. But then make sure u put some good rubber on ur car its a must.
__________________
RACING..........All the other sports just take ONE BALL
jigarmuni is offline   Reply With Quote
Old 1st April 2005, 03:05   #5 (permalink)
revtech's Avatar
hey dude if you are going to be using the car on the highways its recommended that you use tubeless tyres.it decreases the chances of a tyre blow out.alloys arent really essential as such but give the car a totally different look.if i am not mistaken the security system come along with the car even in the base model and the music system depends entirely on your budget ranging from around 13000 - no limit but for a round 15k you should be able to get your self a descent system which includes basic head unit , speakers. since your dads mainly going to be using the car he wouldnt want a very loud system so that should be sufficient
Rev
__________________
Revin Beyond Limits !!
revtech is offline   Reply With Quote
Old 1st April 2005, 14:49   #6 (permalink)
will the air filters and exhaust have any effect on the F.E.?where can i get these and how much will it cost me(installation + parts)
Old 1st April 2005, 15:53   #7 (permalink)
speedsatya's Avatar
hey vandan,
dont know abou the headlamps in an optra,but if its 55/60w get a p[air of 100/90w bulbs along with a relay.this will be very helpful for highway driving.
i doubt if your pops is gonna allow you to modify ur exhaust .as it will require tampering and cutting the exhaust.
before any modification,it is important that you get a proper set of tires.alloys is not important ,but its the the tires taht is.
and u can safely put a k&n stock replacement filter without any mods.that i think is more than enough .and as your car gets older maybe you can think of other mods.
speedsatya is offline   Reply With Quote
Old 1st April 2005, 17:37   #8 (permalink)
RJK
RJK's Avatar
Just change your tyres, upgrade the headlamps & install a nice music system...Pioneer 5650 with Pioneer 6990 speakers. Perfomance exhaust can come later once the warranty expires.
__________________
'94 Mazda MX-6
My first car with my own money.
RJK is offline   Reply With Quote
Old 1st April 2005, 18:50   #9 (permalink)
jigarmuni's Avatar
Well, if driven properly it can marginally boost your FE, but then if the exhaust work if badly done then it may hamper your cars performance and FE. Do one thing forget about the exhaust since ur car will be under warrenty & Plus its a not so advisable thing on a new car which ur dad will be driving, just put a stock replacement K&N Filter in your car. It will give u enough boost of power at about Rs. 3200/- with fitting
__________________
Old 2nd April 2005, 09:41   #10 (permalink)
hey guys thanks so much for your replies,does the filter hamper with the warranty?i stay in worli so any idea who can get this job done well close by?also better tyres someone said...can you please be more specific......thanks alot
Old 2nd April 2005, 11:29   #11 (permalink)
Rudra Sen's Avatar
Yes. It'll be an excuse for the dealer to tell you that you're not going to get a good FE. Your local dealer may say something else but that was the answer I got then. However, my car has completed I year and I'm going for it regardless.
Old 2nd April 2005, 11:34   #12 (permalink)
Optra Is A Great Car And There Are Host Of Accessories Avaialable Both Utility And Functional.
Go For The Oe Aloywheels Since They Are Good Quality And Also Come With Standard Size.
Music System Go For A Blaupunkt But Whats The Budget Buddy
Security System Is Also Available As A Genuine Acc, Dont Get The Wires Tampered From Outside
Carbuff is offline   Reply With Quote
Old 2nd April 2005, 11:37   #13 (permalink)
Would Recommend That Before Changing The Bulb Specs Check The Wire And The Couplers Since At Times Higher Watt Rating Bulbs Melts The Wire And Causes Short Circuit.
Regarding Exhaust And Filter Dont Go For Any Mod Right Now, Enjoy The Car Original For Sometime
Note - Please use the "edit" function to add text to your previous reply if it is within 20minutes of your earlier post.
Old 3rd April 2005, 23:47   #14 (permalink)
Also , ask the dealer to do free Body coloured door handles , mirrors and side strip
Also try to get fog lamps.
dipen is online now   Reply With Quote
Thread Tools
Basic Swift touring mods in Delhi (HID, skid plates, GPS mount) - what else? phamilyman Modifications & Accessories 25 3rd October 2008 00:00
mods and performance mods for unicorn please give your views rider60 Motorbikes 127 14th September 2008 09:51
Mods for Chevrolet Optra 1.8 LT ollie Modifications & Accessories 8 13th March 2007 13:15
basic mods for an ohc vtec...help! Angel Eyes Modifications & Accessories 8 4th May 2006 13:09
hey plz suggest some good mods for Optra Royale!! Arnav_Kacker Tyre & Alloy wheel Section 5 26th February 2006 20:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
