Old 1st June 2006, 20:10   #16
DRC
DRC's Avatar
Thanked: 48 Times
I don't think there is a need to modify the head.
In this case wee need to slightly decrease the compression, not increase. So May be you can do with a double gasket.
If TC can be done go for it. You can think of head mods / gaskets later if the problem of over heating arises.
Enjoy...
DRC is offline   Reply With Quote
Old 2nd June 2006, 18:49   #17
ollie's Avatar
First get the External Air Filter, Free Flow / Exhaust... Make sure its not only the noise that u get with the Exhaust leaving the power behind, get it done from a pro.. !! Then Just get the Turbo Intercooler for your Palio Diesel.. but make sure u get the whole complete set.. wich comes with the thing that suppies required amount of fuel to ur engine to avoide knocking of ur car !! Will try and get more info fout u on that !!
Cheers !!
ollie is offline   Reply With Quote
Old 2nd June 2006, 19:02   #18
satish_appasani's Avatar
Thanked: 45 Times
To get more power
Dump the Palio D and buy a Palio 1.6
If you want to keep Palio D, take it to a highway and enjoy a long cruise...
satish_appasani is offline   Reply With Quote
Old 24th August 2006, 12:04   #19
Ketan's Avatar
Thanked: 179 Times
That was a good suggestion Satish
Hey Guys,
presently i'm in TX, US. One of my friends wants to go for a K&N for his Palio 1.2. i'm going to buy one for him.
I own Palio 1.9D and wanted to check with you guys what wud be the best solution for Palio 1.9 D. I'm not looking for a big diff in Power and FE.
My pref. wud be a little push in power without any impact on current FE or a little improvement on current FE wud be welcome .
on K&N site, what I see is this part number for the most of the Palio model.
Replacement Air Filter - part # 33-2793.
what do u guys mean by the complete kit for K&N?? is there anything else that makes complete kit for K&N?
is the above filter is correct for Palio D and Palio 1.2?
if its not the complete K&N kit,, what else is required? and what is the diff between complete kit and just the above item I have mentioned.
thanks for your inputs in advance.
Ketan is offline   Reply With Quote
Old 24th August 2006, 14:03   #20
team dragstar's Avatar
dude ... with respect...... forget it!!!!!!
team dragstar is offline   Reply With Quote
Old 24th August 2006, 18:06   #21
Ketan's Avatar
Thanked: 179 Times
What!!!!!
I Completelt did not get what you said. So, are you saying K&N is of o use???
Would you please rlaborate it? I normally dont agree without proper justifications
thanks.
Old 17th April 2007, 10:56   #22
Ketan's Avatar
Thanked: 179 Times
This is been inactive for a while.
Hey Finney!! how's your K&N doing! Have you noticed any performance / FE improvement yet!!
I'd be glad if someone can answer my post on August 24,
Old 17th April 2007, 13:07   #23
sorry but would like to contradit
there cant be knocking in diesel engines due to higher brake mean effective pressurs<says sir harry recardo!the bible of auto engines!!!>
u need to reset the injection pressure accordingly to reduce the diesel noise.
the same bottom half with dohc head 1.9 fiat lancia engine gives 148 bhp in turbo form invarious cars including cadillac bls
TURBOSAM is offline   Reply With Quote
Performance twins on a Budget- Palio 1.6 GTX Vs Ikon 1.6 (Edit - Its a Palio 1.6 GTX) Makesh Hatchbacks 48 9th October 2012 01:34
My Story of Going from Petrol (Palio 1.1) to Diesel (Palio MJD) ant_vas Test-Drives & Initial Ownership Reports 13 8th November 2010 14:28
76mm Honda performance pistons, baleno performance cam & NOS kit for sale. mclaren1885 Shifting gears 6 16th September 2007 14:02
Palio Diesel rated the 2nd Best Diesel Car in India in a ET Survey! finneyp The Indian Car Scene 15 10th October 2006 16:08
Chips n Performance Upgrades for Palio Sagarpradhan85 Technical Stuff 5 19th April 2006 13:15
