Old 8th July 2009, 11:43   #16
NIP
NIP's Avatar
Thanked: 94 Times
I would love to upgrade my centre console to the newer one as well. Any luck with this razor ?
NIP is online now   Reply With Quote
Old 8th July 2009, 12:09   #17
razor4077's Avatar
Thanked: 258 Times
Unfortunately, no luck. It seems the handbrake issue is a show-stopper. Would involve a fair bit of work, and "juggad" work, even when done at an A.S.C is never that reliable. So, stayed away from it.
razor4077 is offline   Reply With Quote
Old 2nd January 2010, 09:39   #18
mooza's Avatar
Thanked: 271 Times
Originally Posted by spawnofsatan View Post
How about an anti roll bar for the severe body roll and a coil spring conversion for comfort, I have an '05 and want to the mods that you are looking at. The ride quality is so bad that my back is almost destroyed.
Hi spawnofsatan & fellow Scorpions, has anybody got the conversion to coil springs done? I have just bought a 2004 Dec Scorpio, and I am wondering whether I should do this to improve my ride quality.
mooza is offline   Reply With Quote
Old 2nd January 2010, 16:01   #19
4x4addict's Avatar
Thanked: 2,668 Times
Coil spring conversion is very complicated and expensive. Your best be will be to go for Carbon Fibre leaf springs which a few members on this forum have already done to their jeeps/Ford Endys.
4x4addict is offline   Reply With Quote
Old 4th January 2010, 07:31   #20
mooza's Avatar
Thanked: 271 Times
Thanks a ton 4x4addict, I found a great thread, by using your keywords !
My problem seems to be one of very low rebound damping, as the Scorpio needs 5 to 6 oscillations to settle down (when I do a bounce test in standstill). Automotive literature that I have read up say that the rebound oscillations in a properly damped suspension should not exceed 2 cycles, when bounce tested in standstill.
I hope the carbon fibre leaf spring has good inherent damping characteristics as well, to support the weak stock dampers present on these Scorpios (other leaf spring Scorpio owners may correct me, if I am wrong here). Or maybe its just that my shock absorbers (dampers) need replacement, as they are around 80k old.
cheers,
mohit oza
Old 4th January 2010, 10:31   #21
4x4addict's Avatar
I suggest, get your shock absorbers checked first. It could be time to replace the shocks since the vehicle has done 80K. You may also get the leaf spring re cambered and see if this makes a difference.
Old 5th January 2010, 09:32   #22
agbenny's Avatar
Thanked: 119 Times
Is there anyone here done Pete's Automotive Products Pvt Limited ? When I wrote them, they only said they have satisfied Scorpio customers.
agbenny is offline   Reply With Quote
Old 5th January 2010, 11:13   #23
mooza's Avatar
Thanked: 271 Times
My thanks to 4x4addict and agbenny for the suggestions. I visited my ASC today, and they have told me that the shocks are good, and therefore they do not promise much improvement after change of shocks (I liked their candid opinion in this regard, I must say !).
So I will have to choose between Pete's suspension upgrade and Carbon springs, I guess.
Old 6th January 2010, 10:15   #24
mooza's Avatar
Thanked: 271 Times
Did some more ground work yesterday. The composite leaf spring option for the Scorpio is currently being offered only for the rear suspension, and costs 20k here in Bangalore. The supplier claims that this will reduce pitching in the rear.
The other option, Bilstein B6 shocks (for better damping) is being offered in Bangalore at 36K for the whole set, and they claim good results as well.
It would be interesting to know if a combination of composite leaves for the rear & Bilsteins for the front will a workable option. That translates into a total spend of 38K (considering only 2 Bilsteins, at the front).
Studio on wheels - Pioneer P01 & more ( In making) Invinsible In-Car Entertainment 15 30th March 2011 00:19
Making a 3B/Jeep more Comfortable Red Liner 4x4 Technical 46 10th October 2010 17:20
Sprucing up Gypsy King MPFI and making it more reliable (for the RAID etc) aditya.b Modifications & Accessories 35 15th July 2010 16:07
Making a Jeep's Steering more predictable Tejas@perioimpl 4x4 Technical 31 22nd May 2010 12:49
Camry OR Safari ? Which has a more COMFORTABLE ride ? comfortfreak SUVs, MUVs & 4x4s 63 28th May 2007 23:10
