Old 24th November 2008, 15:59   #16
DesertKing's Avatar
Thanked: 20 Times
Originally Posted by dinar View Post
YES, as you want to keep the 4x4, or find the Scorpio engine. Any other engine spoils the MM540/550. Unless it's for city use and never going to be used for off roading.
I heard that Scorpio engine is not straight fit. I would start my research on Propane (LPG) Fumigation in Diesel Engine to increase it's power. I understood that if it properlly fitted, it can increase the power by 20%.
DesertKing is offline   Reply With Quote
Old 24th November 2008, 22:38   #17
Thanked: 53 Times
scropio engine will need some mods, but one can retain the 4x4 capability , there's question of coupling the gear box and engine and the engine mounts, these can be tackled with some ingenuity.
As for the propane injection, it's great fun, I had built the system for my jeep, it's addictive and one goes through the propane bottle very fast.
You can build one by yourself, but have to be very careful while doing so and have to find the right pressure for injection, the pressure increase in the cylinder is very high.
dinar is offline   Reply With Quote
RE Bullet 4 speed to 5 speed gearbox swap LOGS Motorbikes 17 30th July 2012 10:50
Planning to buy among Pajero SWB or SFX, LC SWB or Xtrail. Suggestions plz SirAlec 4x4 Vehicles 27 9th November 2010 23:00
Premier Padmini 137D Gearbox Swap mituadas Modifications & Accessories 12 5th August 2009 20:48
1991 - Diesel 190 D Mercedes - Remap or Engine Swap ?? vipul_bscity Modifications & Accessories 5 18th January 2008 21:39
Willys Jeep Engine & Gearbox Swap dinya Modifications & Accessories 5 17th November 2005 10:06
