Old 13th November 2008, 11:57   #1
akshay_b's Avatar
Thanked: 9 Times
Default Painting wheel hubs- How do i do it?
Hi everyone
I decided to put wheel caps/covers on my 3 month old santro GLS coz they look a lot better than the stock wheel hubs, The stock ones look like this (This is not my car though)
This is what i want:
[IMG]http://www.******************/wp-content/uploads/2008/06/santro-2.thumbnail.jpg[/IMG]
I got a quote of 2k for 4 wheel caps including everything from hyundai, But one thing, The stock wheel caps are painted silver and I want to change it to black so that the steel rim will be less noticeable. I asked the dealer about the black paint and he said i should get the rims painted by myself, So are there in DIY paint kits so that i just spray it over the rim, or should i remove all the wheels and take it to a paint work shop and get some kind of matt finish black paint?? I examined my neighbour's accent with wheel caps, and the rims are painted with a normal black paint by the company itself.
Note from Team-BHP Support : Please note that it is now imperative for you to upload pictures directly to the Team-BHP Server. Click here to view our simple help article on uploading pictures.
Last edited by Rehaan : 14th November 2008 at 01:30. Reason: Please see note in post.
akshay_b is offline   Reply With Quote
Old 13th November 2008, 13:20   #2
Tejas@perioimpl's Avatar
Thanked: 1,223 Times
Originally Posted by akshay_b View Post
Hi everyone
Painting it on plastic / fibre wheel caps will result in the paint flaking off and scratching. Don't do it.
You can get the rims painted. But to do it yourself, you'll first need to sand paper the rim, and give two-three coats from the spray can. Alternatively you can go to the painter and save a lot of hassles. Make sure to either remove the tyres (recommended) or cover them properly to avoid paint on them. Re-balance the tyres before fitting.
Company painted caps go through a different process including baking. Not the same for DIY.
Tejas@perioimpl is offline   Reply With Quote
Old 13th November 2008, 14:04   #3
akshay_b's Avatar
Thanked: 9 Times
Is it so tedious?
Can i just cover the tiers and the screws with some sticky tape and get the paint job done w/o removing the wheels from a paint shop?
Old 13th November 2008, 14:05   #4
akshay_b's Avatar
Thanked: 9 Times
Image link fixed: http://www.bhagatgroup.com/xing/hyundai_xing.jpg
Old 13th November 2008, 14:29   #5
Is it so tedious?
NO NO NO NO!!!
The paint will start peeling from the edges near the tyres. If you wanna do something, do it properly, otherwise after a few months use, the car will look really bad with flaked paint.
It doesn't cost much to remove tyres and refit them.
And the paint will get stuck to the nuts and it'll be difficult to remove them in the future.
Don't be lazy, your car is a reflection of yourself and treat her properly!!!
You don't want a tailor to sew your torn shirt while your still wearing it; now do you?
Old 13th November 2008, 15:08   #6
Thanked: 104 Times
Essentially you are looking for full wheel hub caps. Try to check in accessory shop, it would be cheaper than from a hyundai dealer.
Normally, cars sporting full wheel caps would have rims painted in black. This feature was removed from santro to reduce costs.
If you really want to have better looking wheels, get it done at professional setup or in a manner done by professionals as suggested by Tejas.
And, you can also explore opting for alloys instead of rim painting and full wheel hub caps.
sukiwa is offline   Reply With Quote
Old 13th November 2008, 15:37   #7
Sudipto-S-Team's Avatar
Thanked: 89 Times
Although it's a question of your very personal taste, I think you are just going to ruin the original wheels of your new car. Save for a few months and then go for a set of alloys. Please don't be offended. That's not the intention.
Sudipto-S-Team is offline   Reply With Quote
Old 13th November 2008, 15:53   #8
Kevciti's Avatar
Well I got the same thing done for my xing initially. Got the same quote of 2k for 4 hub caps and 250 a wheel for painting from the dealer itself. But the painting wasnt done too well and after a month or so it started peeling off so took it back to the service guy and he accepted it was faulty work by the dealer and accepted to do it properly again with proper heat painting and stuff. This set time it lasted well enough untill I decided to move on to alloys in another six months time. Got a set of HR alloys (5 wheels for 14k+5 new eagle venturas 185/60) The tire guy took my old steel rims for 200 bucks a peice So would advise you to go for alloys once and for all because after some time the want of alloys does grow on you.
Kevciti is offline   Reply With Quote
Old 13th November 2008, 17:32   #9
Kevciti's Avatar
Oh and btw the rims are supplied to the factory in black colour only. Hyundai repaints all the rims silver since they believe it looks better on their cars. Got a source in hyundai factory who told me this. Actually come to think of it have seen most OEM rims from other manufactures in black only with the factory fitted hub caps.
Old 13th November 2008, 20:12   #10
akshay_b's Avatar
Thanked: 9 Times
For those of you who want me to go for alloys,
I personally dont think its worth spending 15k+ for alloys for a santro with small tiers, I'd prefer alloys for swift though Besides I'd get a nice set of leather upholstery or upgrade to a better ICE.
@Sudipto-S-Team, I'm planning to buy the wheel covers from hyundai which_do_look_good. And i wouldn't want to fix aftermarket wheel caps even if they were offered for free, coz they look cheap.
Dint u see this pic? Dont u think its good?
@-Tejas@perioimpl- Thanks buddy, U just saved my wheel hubs
@sukiwa- I dont think wheel caps from an accessory shop would look good on a santro
P.S- Thanks everyone, This forum is GREAT
Old 13th November 2008, 21:31   #11
SRK
SRK's Avatar
Thanked: 42 Times
Take your car to a local paint-shop. Ask him to remove your wheels & tyres and then Paint the wheels.
After getting your wheels painted and tyres back on go for wheel-allignment.
PLEASE DO NOT paint over the nuts. I would be very difficult for you to open them incase of a puncture.
SRK is offline   Reply With Quote
Old 13th November 2008, 21:57   #12
greenhorn's Avatar
Thanked: 265 Times
what about powder coating ?
Old 13th November 2008, 23:19   #13
AbhiJ's Avatar
Thanked: 125 Times
Will the accent's wheel covers fit your santro?
I think I have 4 of them lying around.... They are practically new.... They were on the car for exactly 1 day...
AbhiJ is online now   Reply With Quote
Old 14th November 2008, 00:26   #14
Powder coating will come off too. Anodizing is another option, albeit an expensive one.
Old 14th November 2008, 06:57   #15
greenhorn's Avatar
Thanked: 265 Times
can steel rims be anodized ? I thought only aluminum rims could be anodized
Lamda Free Wheeling Front Hubs for Jeeps 4x4addict 4x4 Technical 188 25th April 2013 00:55
Honda’s under-utilised Indian plants to serve as export hubs DukeNukem The Indian Car Scene 5 9th August 2012 17:38
2+ month old Ford Endeavour - rusted hubs? ssh1979 Technical Stuff 13 16th October 2011 11:01
New help installing 50's hubs on RE Bullet LOGS Motorbikes 8 29th June 2010 19:59
Simple DIY - Painting Alloy Wheel Cover of Verna dinu2506 Modifications & Accessories 9 22nd January 2010 12:43
