Old 30th November 2008, 11:51   #1
DeepakMenon's Avatar
Thanked: 145 Times
Default My Poor Esteem !!!
I have a 98 esteem which has done 62000, lately i it started to make all sort of moans
did up the suspesnsion; however the body noice is pretty much there. I have been told that the creaking noise from the door are becasue the panel coupliong has rusted & they expect me to change sll the door panels
guys any idea if this is my only option?
Also wanted to know what are options i have in clutch; i replaced the clutch 2 years back & it has started shuddering again. So in other words the Maruti OEM was not upto the mark. So what options do i have?
DeepakMenon is offline   Reply With Quote
Old 1st December 2008, 22:00   #2
Jaggu's Avatar
Thanked: 8,671 Times
Do you take your car to a MASS or an independent garage?
I suggest finding a good MASS or mech from Mumbai and take it further, regarding clutch how much has the car run on the new clutch plate? and did you change pressure plate, release bearnings etc along with clutch plate at last change?
Old 1st December 2008, 22:48   #3
Thanked: 145 Times
I ran close to 8K approx on the new setup; yes i changed the pressure plate; release bearing etc; atleast thats what the Maruti Service Station charged me..
Old 1st December 2008, 22:57   #4
Car&me's Avatar
Thanked: 33 Times
Its a 10 year old vehicle. Moreover if you have had the call all 10 years in Mumbai, its possible that some parts of the vehicle is rusting. If you still want to own this vehicle, you have to give a new lease.
My suggestion is do a complete overhaul, strip everything down, do some body and paint work and while putting things back in the car, you can start looking at fixing the damaged / broken parts.
Esteem is an excellent car and with MASS it will continue to shine. All you have to do is just Overhaul it.
Car&me is offline   Reply With Quote
State of plastic fitments on cars : Poor quality or poor maintenance? libranof1987 Technical Stuff 10 15th January 2011 21:14
poor headlights in Getz !! chandan Technical Stuff 11 5th October 2009 19:42
Esteem fuel pump(mpfi) in esteem-carb tank techn0l0gist Technical Stuff 0 13th June 2009 22:03
Poor performance of my 2005 Oct Esteem VXi babupaul Technical Stuff 8 29th August 2006 18:11
The poor man's supercar is back devarshi84 The International Automotive Scene 50 25th October 2005 01:33
