Old 10th February 2009, 22:04   #46
crazydiablo's Avatar
Thanked: 21 Times
What was the earlier rev limit (pardon my ignorance)? Do you see any power drop between earlier rev limit and new rev limit? I see a sharp drop in power after 7100 on the dyno chart, so my question is do you need a 7.8k rev limit?
Was the remap done any specific mods?
crazydiablo is offline   Reply With Quote
Old 10th February 2009, 22:05   #47
abhinav.gupta88's Avatar
Thanked: 310 Times
Nice.
Congrats.
Do post a iphone dyno run.
Waiting for results ( in comparison to the previous 2 runs - stock and with filter.)
Old 10th February 2009, 22:06   #48
noidaboy's Avatar
Thanked: 260 Times
2 "T"s for you
Test drive
Treat.
Enjoy
noidaboy is offline   Reply With Quote
Old 10th February 2009, 22:10   #49
m4ugr8's Avatar
Thanked: 123 Times
The Earlier Rev-Limit was 7100 RPM, Frankly i dont feel any power drops from 7100 to 7800.
Yup the Re-map is mod specific, Zakie tuned it according to my car. I guess Zakie/Viper would answer the question better.
m4ugr8 is offline   Reply With Quote
Old 10th February 2009, 22:11   #50
faithless_1984's Avatar
Thanked: 217 Times
What the.......
So that's what you were upto.
NICE.!
As Sanyam said ,time for a T.D and a treat now.
faithless_1984 is offline   Reply With Quote
Old 10th February 2009, 23:32   #51
harsh87's Avatar
Congratulations Manan.
Like I said, its time for 0-100 timings now. and +1 to what faithless said
I'm sure you must be loving every bit of this upgrade
harsh87 is offline   Reply With Quote
Old 10th February 2009, 23:34   #52
manveet's Avatar
Thanked: 586 Times
Congratulations Manan !! These kind of mods are the best, safe and pretty much reliable.
Edit: So I guess this works with the Accord as well, since it shares its engine with the CRV?
manveet is offline   Reply With Quote
Old 10th February 2009, 23:36   #53
Fountainheader's Avatar
Congrats Manan. So you still feel for the need for more speed now ?
Have fun driving around.
Fountainheader is offline   Reply With Quote
Old 10th February 2009, 23:37   #54
m4ugr8's Avatar
Thanked: 123 Times
Thanks Guys, But dont congratulate me yet, I have a long list of MODs now waiting to happen on the Performance Scene.
This gave me the perfect start.
Yes it does, CR-V and Accord both have the K24. Works on any Honda i guess. Zakie can tune any car even an Indica
Last edited by Rehaan : 12th February 2009 at 12:28. Reason: Posts merged. Please use the MULTIQUOTE button instead of making multiple consecutive posts in the same thread.
Old 11th February 2009, 03:51   #55
iraghava's Avatar
Thanked: 156 Times
Congratulations Manan! Can I have a Test Drive please?
Old 11th February 2009, 13:59   #56
hellspawn's Avatar
Infractions: 0/1 (10)
Test drove manan's remapped civic today and I have to say the improvement surpassed my expectations.I wasn't expecting a noticeable difference.But i have to say the throttle response,the power delivery is very impressive.Having driven his car a couple of times before,i could easily gauge the improvement.It pulls faster in every gear compared to the stock car.
The increased rev limit has also led to increase in the in gear top speeds.
Where the 1st and the 2nd gear used to max out at 55kmph and 95kmph respectively.After the K&n typhoon kit,the 2nd gear used to max out at 102kmph.
After the remap the in gear max speeds have increased to 64kmph and 117kmph at 7800rpm.The thing that impresses the most is that torque in the lower range has increased substantially and its easier to drive in the city,and overtaking is effortless without dropping down a gear.Kudos to viper and zakie for something that actually works.
Highly recommended for all civic owners.
Hopefully will get my siena or the sx4 remapped and will post a detailed review soon.
P.S.: Manan informs me that there is no change in Fuel efficiency even under hardcore acceleration .
hellspawn is offline   Reply With Quote
Old 11th February 2009, 16:20   #57
hydrashok's Avatar
Congrats, Manan! Great mod! So what's next?
Old 11th February 2009, 18:18   #58
Thanked: 21 Times
its good that its mod specific. However if you see the re mapped civic on the dyno it shows a sharp drop in power and torque curves after around 7100 rpm. So the rest must be over rev, how much of over rev do we need in an engine?
Again this seems to be a little contradictory. Lets just take the case of 2nd gear top speeds. If your gearing is unchanged and you rev limiter is unchanged theoritically you max speed in any gear will remain unchanged irrespective of the mods. So that means that before the filter 95kmph and after figure 102kmph is not possible.
Old 11th February 2009, 18:36   #59
manveet's Avatar
Thanked: 586 Times
Test drove manan's remapped civic today and I have to say the improvement surpassed my expectations ..
Where the 1st and the 2nd gear used to max out at 55kmph and 95kmph respectively.After the K&n typhoon kit,the 2nd gear used to max out at 102kmph. .. Kudos to viper and zakie for something that actually works.
You are right diablo, and i'm sure hellspawn also knew that. so I was quite surprised to see his post mentioning different top speeds. In his defense, see this post he made almost a year ago ..
The in gear speeds aren't linked to the FFE,rather its linked to the gearing.even if you put 50bhp more,it will still touch the same speeds in the corresponding gears but will get there much faster.
Source: http://www.team-bhp.com/forum/modifi...tml#post787108 (Mitsubishi Cedia Sports "Psychoed!")
Old 11th February 2009, 20:28   #60
NOS Power's Avatar
Thanked: 55 Times
Thumbs up
Great work m4ugr8.
Which set of alloys are on your friends CRV? I mean they look awesome.
NOS Power is offline   Reply With Quote
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged ForcedInduction Motorbikes 98 19th December 2015 11:18
K&N Typhoon Intake Kit for Honda Civic dinu2506 Modifications & Accessories 35 20th September 2012 21:05
My Turbo charged Baleno - now 116 whp @ 6psi Edit:145whp at 11 psi! binz Modifications & Accessories 128 13th February 2012 10:18
