Old 13th February 2009, 10:05   #91
abhinav.gupta88's Avatar
Thanked: 310 Times
Originally Posted by Fountainheader View Post
We have found out that the S Drive can save your lives.
An encounter made us realize this.
Wat say Manan.
Old 13th February 2009, 13:48   #92
iraghava's Avatar
Thanked: 156 Times
Drove the car yesterday & must say the remap is impressive. Can potter around in traffic in 2nd gear & don't feel a lack of low-end grunt at all, much better than stock. When pushing it, going past 7500rpm is useless since power tapers away sharply after that point, revving beyond that is pointless. Needs a more extensive back-to-back comparison to see exact benefits but I think it's a good 30k spent on correcting one of the most glaring problems in the Civic.
Manan - You need better tyres, the Maxxis's just don't cut it in hard driving. The ABS starts kicking in way too early.
Old 13th February 2009, 14:13   #93
dinu2506's Avatar
Thanked: 351 Times
Can't wait to TD one in Bangalore. If this has managed to address the biggest problem in the Civic - that of low end grunt, then its money well spent. The increased rev limit is an added bonus.
Curse the recession, else I would have jumped on this immediately.
dinu2506 is offline   Reply With Quote
Old 13th February 2009, 14:29   #94
Screwdriva's Avatar
Thanked: 377 Times
Simply putting a warm air filter under your hood hasn't done anything for horsepower. It's all psychological.
Bottom line - vehicle manufacturers are well aware that cold air increases horsepower. What you have done is remove cold air promoting piping they have and substituted it with a greater volume of hot engine air. That's all.
I'd be impressed if you gain anything at all. Don't succumb to corporate marketing. Instead, use a K&N filter in your OEM filter box or a true Cold Air intake
Screwdriva is offline   Reply With Quote
Old 13th February 2009, 16:07   #95
m4ugr8's Avatar
Thanked: 123 Times
Wat say Manan.
Yup, Saves life and lakhs of ruppees worth of ICE equipment
I am glad you liked it, Yes Shift at 7500 RPM, No use going any further. Better tires, well i was out in the market searching for them today only, had a close shave yesterday night also. Will contact you soon on the right choice.
This is something which not only gives performance but added bonus in traffic also, The Low end Grunt in second and third has gone up tremendously. Infact i rather enjoy the feel in second and third rather than Redlining it too often.
I dont about the other filter installs, But a K&N Typhoon kit improved stuff to quite some extent on my car, The Difference could be felt immediately.
m4ugr8 is offline   Reply With Quote
Old 13th February 2009, 19:47   #96
Thanked: 310 Times
Damn . I would have taken that HU for sure. By the way, can you show some graph of the torque and power curve?
Old 13th February 2009, 20:16   #97
v1p3r's Avatar
Thanked: 27 Times
You can't put headers on a 1.8 Civic.
Old 13th February 2009, 20:20   #98
m4ugr8's Avatar
Thanked: 123 Times
No Headers, What i meant was to eliminate the catalytic chamber.
Honda Civic Weapon R R18 Race Header at PRO Civic
Old 13th February 2009, 22:38   #99
aajtaksabsetej's Avatar
Congrats on your new kit.I would like to know for how much did you get the front grill for?Is the carbon fiber or vinyl?Even I am willing to install the grill on my Civic.Enjoy your ride.
aajtaksabsetej is offline   Reply With Quote
Old 14th February 2009, 00:39   #100
m4ugr8's Avatar
Thanked: 123 Times
Front Grill is real CF, got it from Thailand costed me around 8k with the Front Red original H Logos, Only the grill is for around 6k
Manan
Old 14th February 2009, 02:46   #101
v1p3r's Avatar
Thanked: 27 Times
Don't do that. Be nice to the environment.
Old 14th February 2009, 19:51   #102
kutlee's Avatar
Thanked: 202 Times
why is it so? please explan....
kutlee is offline   Reply With Quote
Old 14th February 2009, 21:05   #103
ImmortalZ's Avatar
Thanked: 312 Times
Because the catcon is built into the exhaust manifold. You'll have to make a whole new set.
Old 14th February 2009, 21:22   #104
Vid6639's Avatar
Thanked: 21,086 Times
lol. Not really. It's because the exhaust manifold is built into the engine block. The headers are part of the block and only a single tube comes out and goes straight to the cat-con mounted vertically.
You can see from the below pic the cat-con just after the single exhaust port.
Old 14th February 2009, 21:36   #105
civ4647's Avatar
Thanked: 174 Times
actually it is the exhaust manifold which is built into the engine block. the cat-con is still outside. it is in the downpipe. the weapon R race header and the megan racing headers just replace the cat-con. the original headers are still in the engine block and cannot be changed.
and manan if you are going to go for headers i would recommend that you change to a catback rather than the axleback which you have.
civ4647 is offline   Reply With Quote
The RR700 Prostreet Turbo. The Ultimate Bullet mod job EDIT - Now Super Charged ForcedInduction Motorbikes 98 19th December 2015 11:18
K&N Typhoon Intake Kit for Honda Civic dinu2506 Modifications & Accessories 35 20th September 2012 21:05
My Turbo charged Baleno - now 116 whp @ 6psi Edit:145whp at 11 psi! binz Modifications & Accessories 128 13th February 2012 10:18
