Old 7th December 2008, 16:20   #1
Thanked: 645 Times
Default Palio Stile 1.6 Engine Mods
I would like to soup up a Palio Stile 1.6, to make it quicker and faster. I do not plan to do any mods on the body or interiors. I would still need to use it as any everyday driver. Any ideas guys.
I do not want to make it a Speed run car so no outlandish ideas please!!!
jyobeb is offline   Reply With Quote
Old 7th December 2008, 17:52   #2
Thanked: 147 Times
Well, What is your budget? If it is around 30k, I Strongly suggest a Cam Change along with the Standard Filter and Exhaust Changes. Piper has a Bolt on cam for the 1.6 for around 16-18k or something if i remember correctly.
Cyrus43 is offline   Reply With Quote
Old 8th December 2008, 01:52   #3
v1p3r's Avatar
Thanked: 26 Times
Search the forums. Harrie had done some stuff to his car.
Ah, here it is. http://www.team-bhp.com/forum/modifi...1-6-gtx-2.html (My very own Torqueinstein! (Palio 1.6 GTX))
Old 8th December 2008, 08:18   #4
moralfibre's Avatar
Thanked: 6,149 Times
Can you give me more details on the Piper Cam? Any link to confirm that it is "Bolt on" should help a lot.
Thanks.
Old 8th December 2008, 20:54   #5
carfreak's Avatar
Thanked: 178 Times
Hi i am also interested in this.can you give more details?is it a bolt on fit?
carfreak is offline   Reply With Quote
Old 9th December 2008, 00:15   #6
RedMM340's Avatar
Thanked: 23 Times
Here is what I have done so far:
Iridium plugs
K&N replacement filter (I am having some idling rpm fluctuations so I might revert to a stock filter)
Automech exhaust with custom made SS muffler
Mobile 1 synthetic engine oil
Mobile 1 full synthetic gear oil
Removed the back seat to lighten up the car.
I too would be interested in a performance cam if such a thing is actually available.
RedMM340 is offline   Reply With Quote
Old 9th December 2008, 00:16   #7
Thanked: 147 Times
@ MF...
I will ask Anant of N1 Racing. He did have one in stock. Basically, it is the Stock Came mountings but the Lobes have a different angle. I have heard that they are really good. Do ask Varun more about the car with the Piper Cam that he drove.
Old 9th December 2008, 00:44   #8
hellspawn's Avatar
Infractions: 0/1 (10)
Im interested in the cams as well.
This is what i found out on piper's website for the fiat twin cam 1.6 engine.Dont know whether the engine is the same as the one that we get here.
Piper Cams frames page
EDIT:The link isnt showing the exact page.So click on can catalogues,and select FIAT from the drop down menu.Though the drop down menu isnt working so type F,and press GO.
Look under Twin cam 1.6.
hellspawn is offline   Reply With Quote
Old 9th December 2008, 10:27   #9
khan_sultan's Avatar
Thanked: 3,186 Times
Here is what I have as a plan to mod my 1.6 as well to make it a sleeper car. (This is the broad outline and will get it done over time)
  • Air Intake (Done: Green Storm CAI)
  • Exhaust FFE, a low end setup with absolutely NO loud noise
  • Porting & Polishing
  • Piper CAM
  • More stiff suspension (Not sure which one)
  • Improved Braking (Not sure which brakes)
  • RD ECU
This should hopefully get enough juice out of the 1.6 mill to put a smile on the drivers face.
Total budget over time: 50-60K
Cheers,
khan_sultan is offline   Reply With Quote
Old 10th December 2008, 10:08   #10
RedMM340's Avatar
Thanked: 23 Times
Has anyone shaved the head to increase compression?
I discussed this with the head mechanic at the authorized service center, and he said that there is very little clearance with the 1.6 engine and the piston might hit the head if any shaving is done.
I would be very interested in hearing from anyone who has actually done this and get some advice before trying to attempt it.
Also, if anyone has some used pistons or camshafts lying around from an engine overhaul, I would like to get my hands on them. I could take a piston back to the U.S. and source a high compression piston. The camshafts could be re-ground by a machine shop over there.
Thanks,
Old 10th December 2008, 10:48   #11
SYJ
SYJ's Avatar
Thanked: 33 Times
I feel palio engines are best left alone, if anything goes wrong, be ready for a large bill and looong days at the garage. Max u need is a FFe and intake
SYJ is offline   Reply With Quote
Old 10th December 2008, 11:46   #12
16v100bhp's Avatar
The head was shaved ported and polished on my S10. I ran close to 10k on the same without any issues. The power diff was amazing if you ask me.
Will try out the RD ecu first thing after I am back in india
16v100bhp is offline   Reply With Quote
Old 10th December 2008, 12:05   #13
Great to know that buddy. Where did you get your stuff done and by how much was the head shaved?
Did you find the stock suspension & brakes sufficient to handle the extra power?
Also, does someone know the 'technical number' of the 1.6 engine (The one in GTX/S10), Like we have BA16's GA etc etc..
Old 10th December 2008, 12:19   #14
mclaren1885's Avatar
Thanked: 28 Times
I remember the JBL demo Palio being a hoot to drive inspite of all that heavy ICE at the back. I think it had oversize pistons plus some work on that engine too. Maybe you should contact Sam for further details. That by far, is the fastest GTX I have driven in my life.
Old 10th December 2008, 12:19   #15
Thanked: 156 Times
  • Piper CAM
  • RD ECU
Cheers,
Yup, that's the way to go for your sleeper. However I'm not too sure about the budget. From the quotes I got from some pro tuners, a professional porting and polishing job alone will set you back by 25-30,000 bucks, add an RD ecu and you've almost exhausted your budget.
From what little I know, the list you have mentioned will need at least 80,000-100,000 bucks if done professionally, maybe more.
Astleviz is offline   Reply With Quote
2002 palio 1.6 GTX (or) 2006 Baleno (or) New palio stile 1.6 sports (or) Ford fusion Mr_Bean Hatchbacks 31 16th December 2010 17:12
Can a Palio Stile be modified to look like the Palio 1.8R currently in Brazil? jasher26 Modifications & Accessories 11 1st January 2009 00:07
Palio Stile 1.6 or Palio Stile 1.3MJD? rudrah Hatchbacks 47 5th May 2008 03:45
Palio Retro -> Palio Stile windsurfer Modifications & Accessories 17 20th September 2007 20:31
Palio Stile 1.6 or Old Palio 1.6 2006 vinodbijlani Hatchbacks 12 14th August 2007 15:44
