Old 8th December 2008, 14:46   #1
scorpian's Avatar
Thanked: 235 Times
Infractions: 0/1 (5)
Default Help Some info on Esteem brakes on zen.
Hi guys,
I have read in many posts that people who upgrade their engines(zen-b or zen-e)have to upgrade their brakes by installing esteem brake kit..
I want to know what does this change involve?
1)Is it that the discs of esteem and rotors are installed on the zen.
2)are the rear drums also swapped?
3)master cylinder and what else needs to be changed?
If we do upgrade do we need to change rim size from 12 to 13'?
i drive a 02zen mostly on highways and the braking has given jitters many times,have serviced,replaced disc pads,done bleeding basically all the works,hence the basic idea was to buy estemm stuff and upgrade the zen braking...
Kindly tell me as to how its done..
Thanks....
scorpian is online now   Reply With Quote
Old 19th January 2009, 14:45   #2
Thanked: 127 Times
Originally Posted by scorpian View Post
Hi guys,
Thanks....
Exactly my query, i have time till sunday to get this done to our zen. It would be great if someone who has already got the brakes of the zen swapped with an esteem's answer the above questions and some more too.
4) Are the brakes from Esteem Type 1 or Type 2?
5) What are the parts that required to be swapped or upgraded? I would be looking for O.E stuff so the names of the brands i can buy would be helpfull.
6) Do i need to change the rim size from 12"to 13" too for the rotors to fit?
I hope i can get this done by the weekend.
heavy_foot is offline   Reply With Quote
Old 19th January 2009, 14:51   #3
nitrous's Avatar
Thanked: 285 Times
Along with it source a set of EBC green brake pads. Amazing friction difference.
Product code: DP2762
Confirm once though.
Old 19th January 2009, 15:12   #4
Thanked: 127 Times
Perfect nitrous. I would have to check if its available here. Bombay boys anyone?
Old 19th January 2009, 17:12   #5
nitrous's Avatar
Thanked: 285 Times
Electra Automotive always carry stock of EBC.
Old 19th January 2009, 18:06   #6
Awaiting Email Confirmation
Thanked: 20 Times
@nitrous- would you happen to have some idea of the pricing? What about the life of these pads? would they last longer than stock?
Old 19th January 2009, 21:36   #7
iceman91's Avatar
Thanked: 22 Times
prefer black diamond to ebc, they are really good as well.
iceman91 is offline   Reply With Quote
Old 19th January 2009, 21:46   #8
nitrous's Avatar
Thanked: 285 Times
5,000 rupees.
I'll know the life of these pads when the ones on my car are done.
I got my set from the US.
The other good brand I would recommend is Hawk. PJSPEEDSHOP is carrying stock of Hawk Pads.
PJ's also got the track/autocross series of Hawk brake pads which work at temperatures upto 800 degree Centigrade. But, these don't have bite at cold.
@RipperGeo: PJs got stock of Hawks for swifts.
Old 20th January 2009, 11:58   #9
skyliner34's Avatar
Thanked: 63 Times
can i only replace OEM brake pads with EBC green brake pads on my zen?
will it really make a difference if at all i chose to change?
if someone has done it please let me know, the OEM brakes on zen are not worth mentioning
skyliner34 is offline   Reply With Quote
Old 4th March 2009, 03:36   #10
revtech's Avatar
Thanked: 35 Times
was going through this because i was reading up on Ezens. just wanted to confirm the questions from the first post because the replys are not very clear.
im guessing the rotors and pads of the esteem are installed on the zen.
does one also swap the rear drums or are the rear of the zen good enough ?
not too familiar about brakes but besides the master cylinder is there anything else that needs to be changed ?
rev
revtech is offline   Reply With Quote
Old 4th March 2009, 07:44   #11
headers's Avatar
Thanked: 464 Times
on a E-zen / B-zen, apart from brake pads, one should also look at a stiffer suspension setup, wider footprint and positive cambering of the wheels. Its not the brakes alone, but the suspension too that plays a vital role in bringing the car to a stop in a straight line!
Old 4th March 2009, 18:22   #12
Gtea's Avatar
I also want to know more details on the zen to esteem brake swap as I'm planning to do it to my car.
Gtea is offline   Reply With Quote
Old 4th March 2009, 18:41   #13
revtech's Avatar
Thanked: 35 Times
do we just stiffen up the zen suspension or are we looking in for an entire overhaul.
obiously the overhaul would be better but my question here is budget being an issue will handling be adversely affected with a stock zen suspension made stiff.
rev
Old 4th March 2009, 19:43   #14
headers's Avatar
Thanked: 464 Times
rev
My 01 E-Zen was fast..touched 140 like a rocket and would hit 160..but braking was sad and so was handling..
I also realised at one point in time, the chassis of the car needs to be modified suitably to take the extra power.
Guess one needs to look at a complete revamp of the suspension rather than just stiffening..
Stiffening and sway bars etc just reduce body roll, but one needs more..
Old 4th March 2009, 20:17   #15
Thanked: 127 Times
It would be really helpfull to some of us if someone who has done this already can answer the things asked above, just putting it down here once again.
6) Do i need to change the rim size from 12"to 13" too for the rotors to fit? ( asking this so that the rim change can be planned accordingly )
Improving Zen MPFI brakes by fitting an Esteem Type II brake booster etc Trust_In_Thrust Modifications & Accessories 26 6th June 2010 12:42
Urgent: mumbai members please help with some info Rahulkool Shifting gears 3 17th May 2010 20:54
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
Esteem- Rear Disk Brakes speedfreak7116 Technical Stuff 10 18th November 2008 15:37
Esteem rear disk brakes? frankmehta Modifications & Accessories 2 18th May 2006 19:56
