Old 8th December 2008, 17:57   #1
Default Aftermarket Steering Wheel for Indica Xeta
Hi friends
starting this thread on behalf of a friend - Black Indica.
In spite of having power steering, he finds the steering very heavy. Will changing to an aftermarket steering wheel (Smaller diameter) have any effect on this?
Could you also suggest where he can buy and get it fitted, and brands.. Checked out Momo, but it is out of budget (costs 2.5k+)
Cheers!
SB
silver baleno is offline   Reply With Quote
Old 8th December 2008, 18:31   #2
vinit.merchant's Avatar
Thanked: 939 Times
I think decent quality steering wheels will always cost around 2.5 k +.
Is it not that reduced diameter of the steering will need additional force to operate than the one with larger diameter?
vinit.merchant is offline   Reply With Quote
Old 8th December 2008, 18:51   #3
Spark's Avatar
Thumbs up
Originally Posted by silver baleno View Post
In spite of having power steering, he finds the steering very heavy.Will changing to an aftermarket steering wheel (Smaller diameter) have any effect on this?
SB
>>>> Yes It would further increase the problem!!!
Could you also suggest where he can buy and get it fitted, and brands.. Checked out Momo, but it is out of budget (costs 2.5k+)SB
>>>>> Changing steering wheel may would give mild change in feel(If at all in this case), Stiff Power steering might be a result of malfunctioning or wornout steering column/pump. Oversized tyres/underinflated tyres are also major contributors-check for them.
All done by your self?-don't overdo-Better get it checked with some seasoned mechanic!!
Spark is offline   Reply With Quote
Old 8th December 2008, 19:06   #4
greenhorn's Avatar
Thanked: 1,516 Times
I wonder if his power steering seals have leaked off all the fluid. Happened to me once - no fluid = heavy steering. the lines are very vulnerable and can scrape off over speed breakers. ask him to get it checked.
Having said that , the indica xeta does have the lightest steering of all the indicas - especially when compared to my turbo which is at the other end, having a heavier engine and bigger wheels. of course , its nowhere near as light as even the non PS altos
I doubt if a smaller dia steering wheel will help things. But if you really want one , you can use the one from the indigo CS. its a smaller dia wheel, and fitting it onto the xeta should be relatively straightforward
Old 8th December 2008, 19:25   #5
Bouncer's Avatar
Smaller dia steering wheel will require more force application. Will not help but make things worse. Check for any power steering faults as greenhorn suggests.
Bouncer is offline   Reply With Quote
Tata Indica e-xeta petrol with 17.1 kmpl and e-xeta LPG sidindica The Indian Car Scene 7 9th July 2011 12:39
Steering wheel problems of Indica Xeta pankaj_veerkar Technical Stuff 0 14th July 2010 16:52
All wheel steering vs front wheel steering SamtheLeo Technical Stuff 17 28th July 2009 20:11
Indica Xeta - First Experience-How Xeta won the race nirmalkumar Test-Drives & Initial Ownership Reports 12 20th April 2008 16:41
Aftermarket Steering Wheel Sankar Modifications & Accessories 16 10th June 2005 17:09
