Old 16th December 2008, 19:40   #16
vikram_d's Avatar
Thanked: 940 Times
Originally Posted by ramie2400 View Post
One question always struck's me,our hatchback car's Boot is also Lambo door style why don't they get loose/dis aligned so easily even after bashing them so hard to close it..I assume they use much stronger shocks or the pivot point and support's are bolted at proper direction to lift the weight of the Boot.
If the said issue are solved then we also can install the lambo door for daily usage
The reason the hatchback boot doors don't misalign is that they open only along one axis. For vertically opening doors there are two types.
In the first type the door first swings out a by a little bit and then opens vertically. Even for closing them you have first pull them down and close them like regular doors.
In the second type it is one single action but in a kind of circular/angled motion along two different axis. The swinging out of the door and vertical lift is done seamlessly. Imagine a hatchback boot door swinging upwards and towards the left or right at the same time.
Also the reason people complain of the door weighing like a ton of bricks is because the shocks used are very hard.
Old 16th December 2008, 19:45   #17
ananthkamath's Avatar
Thanked: 63 Times
Hehe, sorry couldn't resist.
ananthkamath is offline   Reply With Quote
Old 16th December 2008, 19:50   #18
vikram_d's Avatar
Thanked: 940 Times
Good one Ananth. I wonder why they are called Lambo doors then?
Old 16th December 2008, 20:11   #19
noidaboy's Avatar
Thanked: 260 Times
Originally Posted by vikram_d View Post
The reason the hatchback boot doors don't misalign y. Even for closing them you have first pull them down and close them like regular doors.
There has to a certain amount of play left in the door's for this function and for safety,That causes the doors to misalign with improper use.
this video might help
noidaboy is offline   Reply With Quote
Old 16th December 2008, 21:43   #20
autopsyche's Avatar
Thanked: 15 Times
Mwahahah ananth, that just about sums it up.
autopsyche is offline   Reply With Quote
Old 16th December 2008, 22:22   #21
m4ugr8's Avatar
Thanked: 123 Times
Originally Posted by ananthkamath View Post
Attachment 80079
LOL , I had seen this Pic while i was googling for more info. That Why i made sure to call them Vertical doors throughout the thread.
Anyways, Nice find
m4ugr8 is offline   Reply With Quote
Old 18th December 2008, 18:57   #22
prabhuav's Avatar
Thanked: 112 Times
The older lambos had them .
prabhuav is offline   Reply With Quote
Old 21st December 2008, 10:43   #23
Ricky_63's Avatar
Thanked: 394 Times
These "gullwing doors" are a total waste of money, apart from looking maybe good to some of us. They serve no purpose at all, except making service centers / workshops "very very happy" (pun intended). LOL LOL
Even Lambo saw the wisdom in going back to conventional doors !! As posted earlier by Ananth.
Old 21st December 2008, 11:05   #24
Akshay1234's Avatar
Thanked: 7,243 Times
gullwing doors are a bit different. they are the type of doors found on the toyota sera or the 300sl.
Old 21st December 2008, 11:20   #25
navpreet318's Avatar
Thanked: 894 Times
Infact i think the Gullwing doors are better than lambo doors as they have only one plane of movement.they are very much similar to the hatch doors in hatchbacks.hinges on the top and supported with gas shocks on both sides.they will definitely be the most reliable on upwards opening doors.
navpreet318 is offline   Reply With Quote
Old 21st December 2008, 14:11   #26
Rehaan's Avatar
Thanked: 25,043 Times
Originally Posted by navpreet318 View Post
Infact i think the Gullwing doors are better than lambo doors as they have only one plane of movement....
Check these two posts out. Types of doors :
http://www.team-bhp.com/forum/887738-post21.html
http://www.team-bhp.com/forum/454504-post19.html
cya
R
Old 21st December 2008, 14:46   #27
Akshay1234's Avatar
thanks for that. i always thought the sera had gullwings.
Old 21st December 2008, 16:37   #28
Parm's Avatar
Thanked: 611 Times
i dont have much faith in after market vertical doors.
OEM standard fitment are fine with me.
cheers:
Parm is offline   Reply With Quote
Old 21st December 2008, 17:48   #29
Thanked: 894 Times
I was talking about the doors on the 300sl.those in my opinion should be the most reliable as the basic construction is the same as the hatch doors on hatchbacks.
Old 21st December 2008, 18:43   #30
Ricky_63's Avatar
Thanked: 394 Times
I misused the term, my apologies. What I meant was the vertical or whatever doors that are available as aftermarket fitment are useless.
I agree with Navpreet on the Gull wing doors bit !
Vertical doors kits in Mumbai. xtreme power Modifications & Accessories 15 26th March 2006 10:55
vertical doors for honda city vtec ash_7635 Modifications & Accessories 3 12th February 2006 00:19
