| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #91 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
@Shreyasma : Good effort. How about some pics with the number plate light turned on in the night?
__________________ "You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer | |
| | #92 (permalink) |
| Distinguished - BHPian ![]() | After much trials and flop shows, managed to convert the light in the boot to LED as well. This involved three parallel lines of 3 white LEDs and a resistor in series, bringing it to a total of 9 LEDs. This mod was slightly more tricky as compared to the previous one for the cabin light as instead of a direct positive and negative terminal, there was a bulb holder to deal with. Since i wanted a circuit modification which was easily reversible, i didnt dare to yank out the wires leading to the bulb holder. For all my efforts, it didnt come out either. The other option here would have been to cut the wires and then connect the LED circuit to it. Ruled out any cutting of wires, and so devised another crude approach yet again. Inserted two wires to connect to each of the terminals in the holder and this was then connected using connectors to the LED circuit. During the process, i managed to blow out the 10A fuse which controlled the circuit for the interior lights and the music player. After replacing the fuse with the spare, kept the fuse removed till i was done to avoid any shorting. Here is the final result. ![]() ![]() ![]()
__________________ "You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer Last edited by benbsb29 : 28th February 2009 at 21:11. |
| | #95 (permalink) |
| Distinguished - BHPian ![]() | @Benny, pls post a pic of the set-up - taken in day-light. That will give a better pic of how it actually is. Guess it is time for me to start this one too - the Sumo can do with a set of these lights.
__________________ Life is Analog. Digital is an approximation. |
| | #97 (permalink) |
| BHPian | First of all, Mods, Can you please merge the LED threads into one so that all those DIYs are accessible in one thread. So, secondly, here are my LED driving lights. bought a new set of fogs for Rs 800 (Local brand) and dared to open them without a clue if the DIY will be a success or not. But yes, It was a success to some extent. Further ideas are to buy 5mm LEDs and use more of them so that the brightness increases. Now due to the 10mm LEDs, i couldnt use more than 9. The output of 9 LEDs together are almost same as the 55watts bulb provided. ![]() ![]() ![]() If you are wondering whats the silverish paper below the LEDs, then its the gift wrapping paper! Put it there to use as a reflector. ![]() The fogs are not adjusted properly. Will do it some time in the evening Waiting for some darkness. ![]() ![]() The rear number plate LED strip was not a DIY. This was readily available and I had not started my DIY when i bought it. I am posting just for you guys to get more ideas when you are doing it. These LED strips are being stuck at the bottom of the stock headlights to give the angel eyes look. ![]() Will attach the night photos tonight
__________________ Cheers! Shreyas "Two Wrongs don't make a Right, but three Rights make a Left!" |
| | #98 (permalink) |
| Senior - BHPian | shreyas, would be better if you could post pics with bulbs in one fog lamp and LED's in the other , i mean, of how much they light up the road . I think the bulbs are better suited for the fogs. I'm planning to use the LED's as angel eyes for the fogs ![]()
__________________ '07 Indica DLG - Almost a DLX |
| | #99 (permalink) | |
| BHPian | Quote:
I cant again remove the setup now as i sealed the glass after fixing the LED. I am sure my friends will ask me to make one for them..i will host a pic with bulb in one and LEDs in one. Till then...please excuse. I am using a 6 LED setup with 520 ohms resistors per LED and powering using a 9v battery at home as a torch. So, 9 LED with 12v is bright. Just hang on for the night shot, you will not be disappointed ![]()
__________________ Cheers! Shreyas "Two Wrongs don't make a Right, but three Rights make a Left!" | |
| | #100 (permalink) | ||
Even before i touch the circuit, i need to remove the 10A fuse, so it doesnt go bust again. To improve the quality and robustness, will need to fabricate an adapter similar to what greenhorn used for his numberplate setup. Quote:
Currently the setup which i made just has the two wires plugged into the holder, and is not exactly shorting-proof. @Shreyasma : Looking forwad to pics of the setup with the 5mm LEDs. Somewhat off-topic : I'm so smitten by LEDs i got myself a rechargable LED torch from JC Road for Rs.150/-. I'm sure i could have done it myself, but needed a robust frame for the torch. Ofcourse, i could have dismantled an old one, but nevertheless.
__________________ "You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer Last edited by benbsb29 : 1st March 2009 at 16:43. | ||
| | #101 (permalink) |
| Senior - BHPian | I'll be taking them out when I send my car in for service. cant trust those idiots at the dealership. they just might confiscate the LED's , and charge me for replacing them with regular bulbs ! I didnt use any special wire - those loop like thingies are there only on one side and are the leads of one of the LED's I snipped off ![]() PS: shreyas, how much did the strip for the number plate cost you?
__________________ '07 Indica DLG - Almost a DLX Last edited by greenhorn : 1st March 2009 at 18:29. |
| | #102 (permalink) | |
| BHPian | Quote:
![]() The night shots are here. I will redo the fogs with 3mm or 5mm LEDs. I am 200% sure that I can achieve success. Till then I have my angel eyes ![]()
__________________ Cheers! Shreyas "Two Wrongs don't make a Right, but three Rights make a Left!" Last edited by shreyasma : 1st March 2009 at 22:21. Reason: Forgot to mask number plate | |
| Thread Tools | |
Similar Threads | ||||
| Unlocking the Ford Ikon : DIY Boot Release set-up | benbsb29 | Modifications & Accessories | 92 | 31st August 2009 12:21 |
| DIY: Matte black- Alloys, Calipers, Bumper trims on the 1.6 Ikon. | danlalan | Modifications & Accessories | 13 | 8th April 2009 00:51 |
| Quality Super Bright LEDs, where can I find them ? | s0uljah | Modifications & Accessories | 20 | 20th February 2009 17:20 |
| Skoda Octavia Angel Eyes and LEDs | abhinav.gupta88 | Modifications & Accessories | 77 | 15th January 2009 17:29 |
| Experiment! Replacing conventional headlights bulbs with LEDS! | frankmehta | Modifications & Accessories | 17 | 1st December 2008 00:55 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
