Old 16th December 2008, 15:08   #1
Ice
Ice's Avatar
Thanked: 102 Times
Default ECU Tuning - Palio MJD
Hey guys,
I'm stuck! I want to buy a bolt-on ECU for my new Palio MJD. I've spoken with Karthik (racedynamics.in) and Pete's. Pete's box is more expensive but also more commonly used, with more reviews, etc. So....basically going mad trying to choose between the two
Does this gathering of great minds have a suggestion for me?
Also, my car's got around 3K kms on the clock - ok to go ahead with a bolt-on ECU?
Ice is offline   Reply With Quote
Old 16th December 2008, 15:40   #2
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Would anyday prefer a piggyback where you can control all the parameters individually based on the engine tune and keep changing them accordingly than just have a box with a fixed map. But thats just my opinion.
Also, with a piggyback, the advantage is it can be used on any diesel car, unlike Pete's which is car specific.
Old 16th December 2008, 15:47   #3
noidaboy's Avatar
Thanked: 260 Times
Same case for a DDIS?
@ice,what estimate has RD given to you?
noidaboy is offline   Reply With Quote
Old 16th December 2008, 15:48   #4
vikram_d's Avatar
Thanked: 940 Times
I would recommend that wait at till your car has completed 5k kms before investing in performance products. By then the true performance of your car will be known and also the difference in performance by these products will be more apparent.
You can go in for either. Both are extremely capable products.
But since you are in Bangalore I would recommend the RD piggyback as you can get it tuned at RD itself. Also as Rahul has mentioned you can get customized to your driving style. Plus it will work with almost all vehicles.
Old 16th December 2008, 16:00   #5
Ice
Ice's Avatar
Thanked: 102 Times
18k for the basic 1-setting box, and 21k for the 3-setting example
Old 16th December 2008, 16:03   #6
Ice
Ice's Avatar
Thanked: 102 Times
Thanks, Vikram. I was more concerned about any potential damage to the new (and possibly un-set) engine . However, I am tending towards RD because he's right here.
Old 16th December 2008, 16:43   #7
vikram_d's Avatar
Thanked: 940 Times
That is why I still recommend wait till minimum 5k kms. And owning an RD product myself I can say that are excellent products.
Old 16th December 2008, 16:46   #8
noidaboy's Avatar
Thanked: 260 Times
Well priced,Did you get the chance to test drive a car running on this?
Old 16th December 2008, 17:28   #9
harsh87's Avatar
What parameters can one modify with RD's piggyback for diesels, only injection timing or other parameters like boost as well.
harsh87 is offline   Reply With Quote
Old 16th December 2008, 17:48   #10
Ice
Ice's Avatar
Thanked: 102 Times
Not yet...going to visit his shop later next week. Will keep this thread updated.
Old 16th December 2008, 17:49   #11
Ice
Ice's Avatar
Thanked: 102 Times
Will do, Vikram. Thanks for the advice. With the running I have in mind, I'll probably notch up 5K by Republic Day!
You mentioned that you have an RD product...which one do you have? And for how many years have you had it.
Old 16th December 2008, 17:51   #12
Ice
Ice's Avatar
Thanked: 102 Times
Harsh...
I've not seen the boxes first hand. Will let you know the level of mods the 3 stage box allows..this should probably be end of next week.
Old 16th December 2008, 18:36   #13
sanjaymugur's Avatar
Thanked: 53 Times
try tunit boxes Tunit Performance - diesel performance tuning with over 2000 applications, people have used this extensively in europe for MJD FIAT engines & it is great product , costs around 30K.. there is a dealer in bombay who imports these boxes..
sanjaymugur is online now   Reply With Quote
Old 16th December 2008, 18:56   #14
navpreet318's Avatar
Thanked: 894 Times
I'd suggest irrespective of where you are based get some user reviews first.Any car which has been running safely with either of the 2 ECU's would be good enough.
Talk to busa here on teambhp.i faintly remember he said that the Pete's ECU has 3 settings according to the level of modifications done to the car.
Also give a thought to the warrenty.I hope both are user removable when you give the car for servicing so that you don't have warranty problems.
navpreet318 is online now   Reply With Quote
Old 16th December 2008, 20:16   #15
noidaboy's Avatar
Thanked: 260 Times
I think those have to manually switched on.you need have airfilter,exhust etc to switch on the settings.
Where as what i have heard about RD's box is that you can shift different settings on the fly.
Indica Vista MJD vs Palio MJD vs Swift DDiS greenhorn The Indian Car Scene 452 24th April 2010 18:11
ECU tuning for 320d the_stranger Modifications & Accessories 7 17th April 2009 10:14
DIY tuning gadgets for ECU under 1000$ chetanhanda DIY - Do it yourself 22 21st January 2006 09:49
