Old 18th December 2008, 22:15   #1
RedMM340's Avatar
Thanked: 24 Times
Default Palio Wiper Blade size
Can anyone advise the size of the front wiper blades?
I am in the U.S. right now and would like to pick up a set of premium wiper blades for my 2002 GTX, but want to make sure of the exact size. Would appreciate it if someone could take a measuring tape and post the sizes of the front blades.
There are some really nice blades available here, and I am looking at either the Bosch Excel +, or Rain X Latitude.
There is a post earlier that says 21 inch & 18 inch. Can anyone verify these lengths with an accurate physical measurement?
Thanks,
RedMM340 is offline   (1) Thanks Reply With Quote
Old 18th December 2008, 22:21   #2
Rudra Sen's Avatar
Thanked: 4,288 Times
600 / 400, 24" / 16", If that helps.
This is from Bosch list for India.
Old 18th December 2008, 22:56   #3
carfreak's Avatar
Thanked: 179 Times
Red,i recently purchased a set of Bosch wipers for my 1.6.dont know the measurement as the mechanic himself bought and replaced the standard ones,but its a perfect fit length wise.i will find out from him tomorrow and tell you if its not that urgent-that is if you can wait till tomorrow
carfreak is offline   Reply With Quote
Old 18th December 2008, 23:05   #4
RedMM340's Avatar
Thanked: 24 Times
Rudra & Carfreak,
Thanks for the replies. No rush, so just get me the measurements when you have a chance. But please try to take the measurements yourself with a tape-measure.
Thanks,
RedMM340 is offline   Reply With Quote
Old 19th December 2008, 22:50   #5
khan_sultan's Avatar
Thanked: 3,872 Times
Gaurav, Here are the measurements -- my Palio 1.6 S10. Measured with a tape.
Right Wiper: 19.7"
Left Wiper: 18.7"
Cheers,
khan_sultan is offline   Reply With Quote
Old 5th March 2009, 21:59   #6
moralfibre's Avatar
Thanked: 6,532 Times
Did we manage to figure out the exact size? I wish to pickup the Michelin wiper blades for my Palio - Pylon Manufacturing Corporation.
RedMM540, are you still around the Bay area?
Old 6th March 2009, 01:44   #7
carfreak's Avatar
Thanked: 179 Times
Hi moralfibre, i totally forgot i promised Red i would measure and tell him.anyway i will just measure in mine and tell-i have fitted Bosch ones now
Btw are the michelin wipers available in India?
Old 6th March 2009, 12:11   #8
toiingg's Avatar
Thanked: 83 Times
Default Bosch
395_wiper Blade leaflet_final.pdf
This pdf was posted elsewhere in the forum. It has the stock sizes for most of the cars.
Hope it helps.
toiingg is online now   Reply With Quote
Old 6th March 2009, 22:42   #9
carfreak's Avatar
Thanked: 179 Times
Just checked-right is 24 and left is 16.think that pdf file has the model no. of the palio wipers
Old 21st January 2010, 16:15   #10
Thanked: 29 Times
Just adding to this post.
2 days ago, I noticed my Palio Stile 1.6 rear wiper was not working and the rear blade was facing down towards the road. I thought the wiper motor was an issue. So I dismantled the assembly and checked the motor (without the wiper attached), by switching on the rear wiper. The motor seemed to be working fine.
I then realised that someone(kids !!!) had forcefully pushed down the wiper arm and as a result, the motor shaft was turning, but was slipping inside the wiper. The screw hole of the rear wiper blade was clean as a slate and did not have any grooves. The teeth of the motor shaft, seems worn out too (perhaps as a result of the force applied).
I will be going to try a new rear wiper balde to check if that "holds" on to the shaft. If not, I might have to replace the wiper motor.
Can only the shaft be replaced ? Any idea of the cost of the whole assembly? It is Denso.
Seeler_Rebeiro is offline   Reply With Quote
Old 22nd January 2010, 17:15   #11
recshenoy's Avatar
Thanked: 104 Times
REDMM340,
We have detailed discussion about Bosch viper blades here. Kindly check out
http://www.team-bhp.com/forum/modifi...oon-drive.html
recshenoy is offline   Reply With Quote
The 'Wiper Blade' Thread Sankar Modifications & Accessories 1307 14th July 2018 11:43
VW Passat DIY: Replacing the Wiper blade element rpunwani DIY - Do it yourself 9 23rd June 2016 15:21
Silicon/Water blade greenhorn Modifications & Accessories 4 7th October 2009 11:03
