Old 30th December 2008, 11:22   #16
speed0mania's Avatar
Originally Posted by vikram_d View Post
Not really. You just need to use the correct procedures.
Exactly the problem not too many facilities where processes or equipment are available, not saying its next to impossible but definately more of a problem when compared to MS or SS.
Here is a basic block diagram i made in paint as no CAD in office but will give you an idea of what kind of mechanism I'm talking about. I feel this should work, corrections and sugestions are more than welcome!
speed0mania is offline   Reply With Quote
Old 30th December 2008, 12:33   #17
madan80's Avatar
Thanked: 73 Times
if you are putting in so much effort to move the engine to the rear - why not make the box a sequential shift? Most of the race cars have sequential shifts anyways right?
Sequential manual transmission - Wikipedia, the free encyclopedia
Sequential Gearbox,Sequential Manual Gearboxes,Sequential Gearbox Manufacturers,Gearboxes Exporter
madan80 is offline   Reply With Quote
Old 30th December 2008, 13:06   #18
vikram_d's Avatar
Thanked: 940 Times
Madan, I'm sure for a college project the funds will be pretty tight. Making a new gear box will involve everything from the design stage. Not very simple to achieve. Will only push up costs.
Old 31st July 2010, 01:09   #19
Originally Posted by madan80 View Post
if you are putting in so much effort to move the engine to the rear - why not make the box a sequential shift?[/url]
As far as I've read about sequential shift mechanisms, they can't be used directly onto a maruti 800 engine which has manual transmission.
By the way even I'm involved in a similar project..similar problems!
nvpF1crazy is offline   Reply With Quote
Maruti using weak engine mounts? commonman Technical Stuff 4 12th January 2017 23:24
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Maruti 800 CAR & Engine Diagram jramprakash Technical Stuff 1 15th August 2008 17:08
Maruti likely to renew Maruti 800 with a brand new car askicode The Indian Car Scene 32 13th February 2007 12:57
Using a maruti 800 engine on a bike? blueoyster Motorbikes 31 8th May 2006 18:52
