Old 9th April 2012, 08:07   #1816
condor's Avatar
Thanked: 4,897 Times
Default GPS and Garware IceCool Shield on front windshield
Map My India GPS owner's manual says:
If the car's windshield is tinted with a reflective coating, an external antenna
(Optional) may be needed to route the antenna
The usage of sun film also degrades GPS signal.
But, I did a quick check of the GPS reception inside the Ikon. The Ikon has regular film on the sides & rear, and Garware IceCool Shield on the front.
1. Powered on the unit, and placed it in the middle of the cabin, on the floor. The unit locked on to 2 satellites. Navigation was not possible because it needed signals from 4 satellites.
2. Moved the unit to near the dash (in front of the HU). It immediately locked to 2 more satellites, and with signal strength rated as "good".
Old 9th April 2012, 10:01   #1817
Thanked: 31 Times
Default Re: Front windscreen sunfilm?
Hello All,
I am back from my long trip (600 KM for a weekend is not long at all by our forum's standards). The trip involved travelling towards east in the morining and towards west in the evening.
The effect of having sunfilm is unbelievable. No more sun burns on the forearms, also kept the AC at the lowest level all the time, cooling was very effective.
I did not observe much reduction in glare from oncoming vehicles, but no much deterioration in the visibility at night.
I would surely recommend 3M CR70 to all..worth every penny.
Drive safe.
vidyasagar is offline   Reply With Quote
Old 9th April 2012, 10:09   #1818
Thanked: 708 Times
Originally Posted by amalji View Post
The only reason why I didn't mention Lumar models is because I do not have prior experience with it.
Well, I have used Llumar for more than 5 years. I haven't noticed any issues with it & quite satisfied with it.
Recently, for a friend's 3 year old car, we preferred Llumar AIR 80 over 3M CR70 as it offered 78% VLT compared to 70% offered by CR70. And, cost of Llumar film was same as 3M CR70. Let's see how it fairs this summer.
sukiwa is offline   Reply With Quote
Old 9th April 2012, 10:17   #1819
Thanked: 1,646 Times
Heat rejection of llumar is inferior to that of 3m and v-kool's premium models. V-kool and garware seems to have better vlt ( > 70% ) models with more heat rejection than llumar. In short, for a given vlt, the competition offers better heat rejection than Llumar.
amalji is offline   Reply With Quote
Old 9th April 2012, 11:05   #1820
Thanked: 158 Times
VLT i.e. visible light transmission determines the darkness. .
1) VLT determines the darkness
This is true only within particular brand! Not necessary across the brand. For e.g. Vkool 70 & 3M CR 70 may not match in Shade. One must also take a note that darkness of shades not necessary increases with VLT in similar range as in other brands. For e.g. Shade difference between 3m CR-70 & 3m CR-50 to that of simmilar range in VKool and others brands vary.
Added to Amalji's list of brand, If one wants better sun film but lesser cost than VKool, look for brand called HuperOptik. Costwise its little expensive than 3M CR series. HuperOptik Klar series comes with 10 year warranty! You can hardly see any shades in this film (May be if one wants to have privacy this might not be your film). They work wonderful in summer.
RaguHolla is offline   (1) Thanks Reply With Quote
Old 9th April 2012, 11:17   #1821
Vid6639's Avatar
Thanked: 21,049 Times
less darkness = better visible light transmission.
The shade can be anything and that is not important. For example RE series are colourless but the light transmission is based on it's reflective properties rather than it's "darkness". RE50 vs CS50 for example. You will feel that RE is light but CS is dark but both have same visibility. Only difference is VLT of RE series is based on reflective property whereas for CS series it's based on dyed colour.
Vkool70 3M CR70 maybe different shade but both have same visibility and hence they are equally dark although the shade is different.
Another example, Garware has grey, blue and green shades with same VLT.
Vid6639 is offline   (1) Thanks Reply With Quote
Old 9th April 2012, 19:38   #1822
mjumrani's Avatar
Thanked: 598 Times
Originally Posted by funkyp View Post
i wouldnt go with that. finding a good fitter willing to put the screen will be quiet a task.
Also, the 5700 odd price is that of the grey market and unless you know the shop well, chances of getting a spurious film is high.
i suggest you write to 3m and ask them where can you get their product in delhi. Since the cr70 is 7750 at 3m care outlet in all cities, it cant be more expensive than that in delhi.
I called 3M too. The price I'm getting is 9K.
That is why I am wondering what to do. The jump from 5700 to 9K is big enough.
mjumrani is offline   Reply With Quote
Old 9th April 2012, 19:41   #1823
Mpower's Avatar
Thanked: 1,687 Times
l
Sorry if I missed it but, isn't the Garware Ice cool shield a metallic type as opposed to the creamic type like the CR70.
Does it have similar numbers for VLT, IRR etc ?? Is there an updated comparison chart somewhere?
Old 9th April 2012, 19:54   #1824
funkyp's Avatar
Thanked: 97 Times
can you highlight this to 3m? if they have standard pricing across all other cities, delhi shouldnt be different.
is the car in question a jazz or aria? those are quoted at 9k
funkyp is offline   Reply With Quote
Old 9th April 2012, 20:04   #1825
Vid6639's Avatar
The Garware is not metallic at all. There's no reflection at all and it's died green.
VLT for both Icecool shield and 3M CR70 is 70%. TSER i.e. total solar energy rejected is 40% for Icecool shield and 50% for CR70. That's the biggest difference.
Vid6639 is offline   (2) Thanks Reply With Quote
Old 9th April 2012, 20:21   #1826
@vid - where did you get that TSER value for Ice cool shield? I've been searching for it everywhere and I only get HR ( heat rejection ) and garware claim that to be 50% . But since it's a non standardized measure, I do not want to trust them on that.
Ps: I'm planning to get garware ice cool shield for my mother's liva because no car accessory shop in trivandrum or even the 3m dealer in trivandrum doesn't have stock for any cr series film. They only have CS series which has pathetic tser of just 24% !
Old 9th April 2012, 20:29   #1827
Vid6639's Avatar
Garware website mentioned the TSER.
http://www.garwaresuncontrol.com/pro...-cool%2070.pdf
Also 3M has 2 TSER numbers one for direct 90degrees and other on angle of 60 degrees. The on angle is 59% vs 50% for direct. The difference being that on angle rejection will be better due to refraction as well as reflection.
Old 9th April 2012, 20:44   #1828
fast&furious's Avatar
Thanked: 52 Times
Did you visit Car Shoppe near Ulloor? IIRC, they had it in stock when I was there a few months back. Btw,would you please share the details of the 3M dealer in Trivandrum?
fast&furious is offline   Reply With Quote
Old 9th April 2012, 21:23   #1829
condor's Avatar
I have not been able to check 3M CR70 in action to compare it with my IceCool Shield. IMO the 10% difference TSER is getting a little hyped in the discussions we are having.
At the end of the day, at about 60% of the cost of Llumar, and even less when compared to 3M, I get a good front windshield sun film which does it's job. Eye strain is much less when driving in the afternoons, cabin/car feels much cooler, I dont feel the sun-burn on my fingers (with hands on steering wheel), and cannot complain about night driving - I dont feel visibility is a problem at night. On coming high-beams are not so trouble-some now.
So when IceCool shield does it's job nearly as good as the next two brands, but at much better price, why should I complain ?
Old 9th April 2012, 21:32   #1830
mjumrani's Avatar
Thanked: 598 Times
The car in question is a Civic.
Falling stone cracks front windscreen Lukeskywalker Street Experiences 32 14th June 2012 14:26
CAUTION!!! Swift Owners installing Front Windshield Sunfilm Pace in Blood Modifications & Accessories 95 23rd June 2011 11:33
New Swift Diesel - Water Leak through front Windscreen and the following messup!!! sam_sant2005 The Indian Car Scene 71 24th December 2010 17:02
Yamaha Rd350 Front windscreen cover bsa1955 Motorbikes 28 18th February 2009 11:51
WagonR front windscreen scratched DCEite Technical Stuff 2 8th July 2008 21:26
