Old 22nd April 2016, 23:27   #2086
straight6's Avatar
Thanked: 112 Times
Default Re: Front windscreen sunfilm?
Finally got Llumar films installed. Pp70 for the windshield and pp60 for all others. The heat rejection is good and its made a difference.
My next car will get the air 80 for the windshield along with the pp60. That's an even better combination.
straight6 is offline   Reply With Quote
Old 23rd April 2016, 00:28   #2087
Thanked: 298 Times
Originally Posted by Sawyer View Post
What is the legal situation/insurance cover status in case of an accident from which one can't run away along with the car, when there is any film installed?
While your question is a valid one, are you implying that one should one run away from an accident when possible ?
Lobogris is offline   (1) Thanks Reply With Quote
Old 23rd April 2016, 01:32   #2088
Thanked: 361 Times
I am hoping he meant the situation where the car has to go to the police station and the insurance company will do a thorough inspection of the vehicle. Could they theoretically deny you insurance in that case. In a small accident (fender bender), you can just claim the insurance without all that hassle generally.
pganapathy is offline   Reply With Quote
Old 23rd April 2016, 06:36   #2089
Thanked: 1,273 Times
I was referring to the minor fender benders where it may not be a problem. Get the police involved and the risk of sun film being found is very high and a loss assessor that does his job as he ought to, will deny the claim under the illegal modification escape clause in the policy. He could also argue that the accident was caused by reduced visibility and is therefore not entitled to be paid. How are you going to argue against that?
Bottom line, sun film is illegal and installed at one's own risk and consequence.
Sawyer is offline   (1) Thanks Reply With Quote
Old 23rd April 2016, 19:31   #2090
Thanked: 26 Times
Please suggest which film is the top of the line from Garware? To confuse further, there are too many types in Icecool range like Elite, Grand, Arctic cool, NF etc.
For front windscreen 70% vlt film theres another one called Shield along with different Icecool subtypes.
Do the 50% tints used on windows come in different colors like charcoal, gray, green etc.? If yes then, which color shade looks good and goes unnoticed with the cops?
prokinetic is offline   Reply With Quote
Old 27th April 2016, 23:32   #2091
Thad E Ginathom's Avatar
Thanked: 7,246 Times
I am very concerned about both practical and legal issues with adding CR70 to already-factory-tinted glass. Even though the heat reduction may only be half, I want to go with an almost-completely-clear film. My local 3M does not stock CR90.
Can I get CR90 at other Chennai outlets where a good job would be done? Can a high-quality alternative film be suggested?
Old 27th April 2016, 23:34   #2092
condor's Avatar
Thanked: 4,338 Times
Icecool Shield VLT70, as suggested by the distributor here.
http://pixelshopee.com/uploads/files/del.jpg
condor is offline   (2) Thanks Reply With Quote
Old 28th April 2016, 06:54   #2093
I have used CR90 in the past, and I haven't found it to be less than the 70 for all but one very important area - cutting the glare from the sun. The 90 is close to useless for that.
Unfortunately cutting glare seems to go hand in hand with light transmission levels, and the only way to handle that effectively in the current legal situation is to wear sun glasses.
Old 28th April 2016, 09:14   #2094
Thanked: 154 Times
I know that its illegal, however still...
What I have in my car is Hüper Ceramic 70. I had it installed in 2010, didn't bother to remove it. Its damn expensive (7K for front windshield( fiesta classic), 14K for all around). But its damn effective. You need to tell someone that it has film. Heat rejection is really good. I generally found its better than 3M CR70 in similar condition.
RaguHolla is offline   Reply With Quote
Old 28th April 2016, 12:09   #2095
Thanked: 26 Times
Many thanks, you just cleared my confusion. So, its Ice cool shield for front windshield and Elite for the windows.
The front windshield of the car has written "Transparency 70%" on it. I always wonder if its a factory tinted glass? Would appreciate any help to clear this doubt also. Thanks once again.
Old 28th April 2016, 12:19   #2096
condor's Avatar
Why not Snow Glaze for side & back ? Then again, that needs to be available.
Note: the Ice-Cool Shield comes in single use roll packaging, sealed.
Can you give more details about the second part of your post ?
condor is offline   (1) Thanks Reply With Quote
Old 28th April 2016, 12:21   #2097
Yes, if accurate, it is factory tinted glass that allows only 70% of the light to pass. If you stick a VLT 70% film on top, effective VLT will be down to 49% - 70% of 70.
Are you confident this will not render the car unsafe on poorly lit night roads - in other words, most Indian roads?
Old 28th April 2016, 13:02   #2098
Thanked: 26 Times
Is Snow Glaze better than Elite? Thought of Elite, just because Elite is a popular name from Garware. If Snow Glaze is better, then why not?
Thanks. I'll keep that in mind.
Sorry for confusing. Both the queries are for two different cars. The factory tinted glass query is for the car that I already have.
Garware sunfilm query is for the car to be newly bought. My bad, I should have mentioned this earlier.
Thanks for the reply. I don't intend to put any sunfilm on the tinted car. The garware films would go on the new car.
Old 28th April 2016, 14:06   #2099
Thank you!
That is 100% fine with me. I am quite happy to wear sunglasses when driving. Even with CR70 I did so on brighter days. Even in UK I used to: I find it reduces the fatigue of driving.
It is the heat that we want to beat, even if only by a little.
I suspect the prices are probably now much higher: that is close to what 3m charge for CR70.
Had been meaning to ask about Huperoptik, having seen it mentioned in some old posts.
Any recommended Chennai dealer? And for CR90?
Last edited by GTO : 29th April 2016 at 09:42. Reason: Quoted post deleted, hence...
Old 28th April 2016, 15:14   #2100
Bear in mind that after some time it won't help. If it cuts heat by 50%, in 30 minutes under the sun the car, that will still be a glass greenhouse, it will still get as hot as it would otherwise in about 15. And the Indian sun in summer can do a lot in just 15 minutes of accumulated heating of a greenhouse.
It helps therefore for relative short city drives when starting from parked in the shade. After an hour or so under a strong sun, it equals out. Glare and UV reduction are the only longer term benefits that remain; UV because eliminating over 99% of UV is a big deal even after a few hours of cumulative exposure.
Last edited by GTO : 29th April 2016 at 09:43. Reason: Please use the 'report this post' functionality for any thread requests
Falling stone cracks front windscreen Lukeskywalker Street Experiences 32 14th June 2012 14:26
CAUTION!!! Swift Owners installing Front Windshield Sunfilm Pace in Blood Modifications & Accessories 95 23rd June 2011 11:33
New Swift Diesel - Water Leak through front Windscreen and the following messup!!! sam_sant2005 The Indian Car Scene 71 24th December 2010 17:02
Yamaha Rd350 Front windscreen cover bsa1955 Motorbikes 28 18th February 2009 11:51
WagonR front windscreen scratched DCEite Technical Stuff 2 8th July 2008 21:26
