Old 26th March 2017, 13:36   #2146
Thanked: 44 Times
Installed 3M CR70 all around yesterday​ at 3M car care shop yesterday. Really fabulous service and very clean installation. It's hard to make out that there is sunfilm installed unless directly compared to car next to it. Also, the size makes it hard to guess the film.
There is remarkable difference in heat and totally worth the money spent on it.
nrahul is offline   Reply With Quote
Old 27th March 2017, 09:19   #2147
Thanked: 1,646 Times
Smile Re: Front windscreen sunfilm?
Using the contact given by team-bhpian - condor, I completed the installation of
Garware IceCoolShield Green ( 70% VLT and 50% TSER with 5 years warranty ) on the front windshield. The installation guys came to my home and did the installation.
Cost of the film - 4200 INR ( inclusive of taxes )
Labor cost for the home visit, removing the old film ( 3m CR 70 ), cleaning up the glass of any adhesive and then sticking the new film - 1000 INR.
If I had no film installed previously, the labor cost for the home visit would have been just 250 INR.
After the work, I parked the car in the sun for it to dry properly and then took the car out for a night drive. The visibility is very good. And I am so relieved that the stress of night driving with the wrinkles on 3m CR 70 is no more. Tried driving the car in the morning and the heat rejection seems to be pretty good.
Overall, very happy with this Garware product and the work quality of Shreyas and team ( referred by team-bhpian - Condor ).
Please share the details of the dealer in Bangalore along with the cost .
PMed you the contact details.
amalji is offline   (3) Thanks Reply With Quote
Old 27th March 2017, 12:00   #2148
Thanked: 149 Times
Default Re: Front windscreen sunfilm?
I am using this film on my car for almost 6 years now.
only issue I felt was fogging during heavy showers. Particularly at night the fogging makes it almost opaque. I tried various options to clear the fog but it doesn't go.
Check if this happens on your film please.
CANPUSH is offline   (1) Thanks Reply With Quote
Old 27th March 2017, 17:45   #2149
Thanked: 1,059 Times
This was an issue i faced in all 3 cars with front windscreen film (Spark, Alto K10, Fiesta). Spark had Garware, while Alto and Fiesta had the 3M film. Fogging during heavy showers was a major issue and rendered the glass opaque as you pointed out. Using the defogging method mentioned in the manual would help for a short while and then it would fog up again. So this time, decided to make do without any sunfilm in the new Figo TDCi which I got recently.
abhinav.s is online now   Reply With Quote
Old 28th March 2017, 08:47   #2150
Post Re: Front windscreen sunfilm?
Weird. While, I noticed that fogging is indeed higher with the films on than without, I always could tackle it by adjusting the ac according to what the situation is. The rules that I normally use are.
  • Whenever there is fogging, switch on the AC ( regardless of how heavy the shower is or how cool it is outside ) and close all the windows. This is important because AC also acts as a de-humidifier.
  • Make sure that the air circulation is in re-circulation mode ( because you don't want to loose the de-humidified air )
  • Adjust the temperature using the temperature knob to make the cabin comfortable.
  • Try and keep the temperature in the range of "slightly warm" to "not so cold" range.
  • If the AC temperature is set on the cooler side, do not redirect the air directly to the windshield because that can cause fogging on the outside of the windshield. ( If I need to get fog out of the inner side fast, I might redirect the AC to windshield position for 1 minute to remove all the fog and then put it in normal position again to avoid the cool air causing fogging on the outside )
With the above 5 rules, I never had to face the issue of fogging on my Etios with 3m CR70 on the front and V-Kool 70 on sides and rear. I hope, Garware too gives the same experience. Will keep the forum updated, if there is any change in behavior for the garware films.
PS: I use my car extensively in very humid climates of Kerala during the monsoon season.
amalji is offline   (2) Thanks Reply With Quote
Old 1st April 2017, 12:05   #2151
Thanked: 149 Times
The fogging is despite of above measures you have mentioned. I don't know about other brands but in my car I have experiences it at least 3 of 4 times.
CANPUSH is offline   Reply With Quote
Old 1st April 2017, 12:43   #2152
kutlee's Avatar
Thanked: 202 Times
3M CR70 does leave a tint. To see how much, i took Alto rear glass and did half of it with 3M CR70.
They have CR90 which should give 90% VLT but don't seem to push that product. Both cost approximately the same.
kutlee is offline   Reply With Quote
Old 1st April 2017, 15:13   #2153
Thad E Ginathom's Avatar
Thanked: 8,376 Times
CR90 has much less heat rejection than CR70. But I still wish I could get it for my factory-tinted windscreen.
Indeed CR70 has a tint. Not much noticeable, but it is there. Had it on my Polo for four years. No problems whatsoever. It is probably still there, but the car was in the flood and decided not to restore myself. Even despite the car being half full of water for a couple of days, I bet the film is still there, now six years later.
I'm sure it is all in the preparation/application skill.
Old 5th April 2017, 11:40   #2154
Thumbs up Re: Front windscreen sunfilm?
Please send in the details to me as well , Did you get this done in Bangalore?
iceman07 is offline   Reply With Quote
Old 5th April 2017, 14:57   #2155
condor's Avatar
Thanked: 4,902 Times
@iceman, you can call Shreyas on 9986502625.
condor is online now   (2) Thanks Reply With Quote
Old 6th April 2017, 15:27   #2156
Thanked: 94 Times
Got CR70 Installed on my front windscreen and there's absolutely no difference in cabin temperature while driving in the afternoon or after having parked under the sun. Do I have to install on the sides and the rear as well? (or the garware one) ?
P.S. Leather seats.
Vysakh is offline   Reply With Quote
Old 6th April 2017, 21:48   #2157
Originally Posted by Vysakh View Post
... ... ... Do I have to install on the sides and the rear as well?
It depends on which direction the sun is coming from!
But seriously (and please excuse my joke) I think: yes you do. Sorry, it is a much bigger expense in total, but if you go back to the same place maybe you might get a better all-car deal.
Windscreen only should cut glare. Do you find it easier on the eyes? That, alone, might be worthwhile. But, for heat rejection: do the the whole car.
Having said that, I recall that I never replaced the film on my Polo rear glass, after it was smashed by a vandal, and I did not notice three-sides film being much hotter than four. But I think you, or your passenger will notice the difference when the sun is blazing on the side of the car.
Thad E Ginathom is offline   (2) Thanks Reply With Quote
Old 7th April 2017, 11:15   #2158
Thanked: 44 Times
P.S. Leather seats.
I did all around CR70 and there is significant heat reduction. Not just the heat but the burning sensation due to direct sunlight is almost non existent now. I'm really happy with the money spent on it.
Old 7th April 2017, 11:58   #2159
Thanked: 45 Times
I got cr70 for front, and re30 for the sides and rear of my Esteem. Difference is huge compared to earlier. Without the films, I used to feel like a boiled egg!
Whenever I get a new car I'll be going for cr70 all around. Should cost 25-30k.
zhopudey is offline   Reply With Quote
Old 7th April 2017, 12:04   #2160
VKS
Thanked: 26 Times
Originally Posted by nrahul View Post
I did all around CR70 and there is significant heat reduction. I'm really happy with the money spent on it.
I am also planning for CR70 on front windshield mainly for glare reduction . Please provide your views on night driving after sunfilm installation . Does that help ?
VKS is offline   Reply With Quote
Falling stone cracks front windscreen Lukeskywalker Street Experiences 32 14th June 2012 14:26
CAUTION!!! Swift Owners installing Front Windshield Sunfilm Pace in Blood Modifications & Accessories 95 23rd June 2011 11:33
New Swift Diesel - Water Leak through front Windscreen and the following messup!!! sam_sant2005 The Indian Car Scene 71 24th December 2010 17:02
Yamaha Rd350 Front windscreen cover bsa1955 Motorbikes 28 18th February 2009 11:51
WagonR front windscreen scratched DCEite Technical Stuff 2 8th July 2008 21:26
