Old 11th September 2009, 12:34   #916
im_srini's Avatar
Thanked: 398 Times
Originally Posted by Sawyer View Post
But the UV rejection is very high, close to 99% and so the dashboard fading will still be substantially less.
Originally Posted by rkg View Post
Windshield glass itself rejects UV. No need for film. Any glass sold in the market rejects UV radiation.
I too think RKG is right, or at least that windshields, as-is, cut enough of the UV radiation (primarily UV-A) to prevent transition lenses from working. Even if you place them in direct sunlight, right underneath the windshield, transition lenses don't work (you'll get a very very slight tint, nothing else).
As per wikipedia UV-A is primarily light at wavelengths between 320nm & 400nm. Apparently window glass blocks 90% of UV radiation below 300nm & allows 90% of UV radiation through, when above 350nm. Anybody got a UV meter ?
im_srini is offline   Reply With Quote
Old 11th September 2009, 12:39   #917
shajufx's Avatar
Thanked: 490 Times
If thats the case, all those who have installed V-cool or CR70 or Garware Icecool have lost their money ? I myself was considering Icecool for my windscreen as many have claimed better cooling and less glare. How do I decide now ?
shajufx is offline   Reply With Quote
Old 11th September 2009, 13:18   #918
knp
Thanked: 18 Times
Even I am confused now. Today, I am supposed to go and get Ice cool installed for my i10.
knp is offline   Reply With Quote
Old 11th September 2009, 13:41   #919
Awaiting Email Confirmation
i suggest you can put your plan on hold for sometime....coming to reducing the glare, buy an nice pair of Rayban sunglasses:-)
srinivas9446 is offline   Reply With Quote
Old 11th September 2009, 13:59   #920
splitsecond's Avatar
Thanked: 12 Times
I am going to install v-kool on front glass in my spark, but the front windscreen already have company fitted tinted film(with 75% transparency) with black borders, so do i need to remove that inorder to install v-kool?
splitsecond is offline   Reply With Quote
Old 11th September 2009, 14:10   #921
As per this, if your lenses are using Silver Chloride (supposedly the most common material used for this purpose), shading difference can be interpreted as roughly the amount of UV below 386nm being blocked by windshield?
@shajufx and @knp, don't loose heart! UV doesn't contribute much to the amount of heat sunlight radiates. If their claims about IR/heat rejection are valid, then those films should be reducing heat, if not much of UV.
santosh.s is offline   Reply With Quote
Old 11th September 2009, 14:29   #922
im_srini's Avatar
Thanked: 398 Times
Question
Hi Santosh, as per my understanding Silver halides are used in glass versions of transition lenses only - the ones I have are plastic.
Yes, but it appears the windshield films do not do that too (see Sawyer's comments below)...
And remember that even they have a heat rejection of just around 55% - so the heat build up inside after a few hours will be not very different from naked glass.
The films are relatively pricey, so they must be working, but is the marketing mumbo-jumbo asking us to pay a lot for less ? Could a pair of shades be a better option ?
Old 11th September 2009, 14:32   #923
Thanked: 19 Times
Windshield glass itself rejects UV. No need for film. Any glass sold in the market rejects UV radiation. No need for separate film. correct me if iam wrong
It is a marketing ploy used by sun film makers to sell
Sunfilm should reduce heat trasmission
You are spot-on RKG. Its a marketing ploy.
The glass itself cuts the UV transmission by 99%. That is why although you may be uncomfortably warm with bright sunlight streaming through, you will not be sunburned.
Interestingly, this is something I found on Llumar india website itself. "Less than 1% of the sun's ultraviolet (UV) rays penetrate the windshield in newer vehicles. This is due to UV absorption by the PVB (polyvinylbutyral) interlayer that is used to laminate two sheets of glass together, making up the windshield unit. Some vehicles five years or more years old may allow as much as 10% of the UVA to transmit through the windshield glass. (In some countries, windshields are merely tempered glass, with no PVB interlayer at all.) UVB is screened by the glass itself and UVC is screened by the ozone layer of the earth's atmosphere"
Source:Welcome to LLumar website
Further, as already mentioned on T-BHP elsewhere, the main contributor to the incoming heat energy is from IR and Visible light. And therefore the UV ttransmission cut mentioned by the Sunfilm mfgrs is nonsense!
psp62in is offline   Reply With Quote
Old 11th September 2009, 15:22   #924
pachchu's Avatar
Thanked: 38 Times
good info there on the UV. looking at few more sites, it seems quite obvious that the newer cars don't need front sunfilm for UV protection alone. older cars should still consider it.
so I guess the buyers (who still haven't plonked their money yet) have to decide whether the heat rejection (50%), IR rejection (97%) and glare reduction (23%) is worth the money or not. (referring to 3M CR70 specs).
pachchu is offline   Reply With Quote
Old 11th September 2009, 15:48   #925
aks_karthik's Avatar
Thanked: 232 Times
The Main purpose of Windshield Sunfilm is for reducing heat and glare.
you can feel the difference once installing sunfilm.
I am using Xenos Panorama 60 Sunfilm in my windshield.though it's mainly used for buildings.
It's very efficient and cuts a lot of heat entering in to cabin.
AC is doing its duty pretty easy which boost mileage.
aks_karthik is offline   Reply With Quote
Old 12th September 2009, 00:16   #926
tsk13's Avatar
Thanked: 279 Times
Split Second, windscreens and glasses of all cars have about 70-75% transparency.
All films are applied on the glass/ windscreen directly (even if they have the black borders which almost all cars have now) and what you're saying of removing film with black borders, I don't think it's possible and moreover one is not supposed to tinkle with that tinting.
By the way BHPians, is the transparency level of the glass (70-75%) related to Lamination or glass formation?
tsk13 is offline   Reply With Quote
Old 12th September 2009, 01:06   #927
Ravveendrra's Avatar
Thanked: 406 Times
I find that films get foggy too soon as compared to bare glass. This can be a real problem when it is raining, I therefore recommend a good shade to put up when parking the car in the sun.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 14th September 2009, 11:16   #928
san9jay's Avatar
Thanked: 56 Times
That is why it is necessary to go for the top spec film for this application. And remember that even they have a heat rejection of just around 55% - so the heat build up inside after a few hours will be not very different from naked glass. But the UV rejection is very high, close to 99% and so the dashboard fading will still be substantially less. Glare reduction will also remain at the same levels, much better than naked glass.
I did go for the top spec of Llumar film. It didnt seem to make any difference.
I think the key aspect is that after a few hours in the sun the heat build up will be about the same since 55% of the heat is going through, it should just take longer to get to the same heat level.
A scientific test would be to place two cars in the sun and measure the temperature every 5 mins till the heat level stabilizes. One car with the film and one without.
For short trips in the sun the sun film should help since it lets in less heat.
Basically in hot cities I would guess that the front film is a waste of money since the car is likely to be in the sun long enough that the heat in the car would be comparable to a car without sun film on the front windscreen.
/sanjay
san9jay is offline   Reply With Quote
Old 14th September 2009, 16:25   #929
Thanked: 1,498 Times
/sanjay
Based on what I learn about the no additional benefit for UV ( welcome new learning for me!), the above sums it up well. After enough time in the sun, 45% heat absorption in India where the sun is strong, is enough to heat up the car to make it just as uncomfortable as one that has no film.
But the glare reduction is significant, and for those of us that have prescription glasses, even with transition lenses, this is still a very important benefit. I also suspect that it helps cut glare from oncoming headlights at night. I find that to be the case, and in which case, it is still a sensible accessory to install.
Sawyer is offline   Reply With Quote
Old 14th September 2009, 17:29   #930
Sawyer and Sanjay,
I see your points. However, when it's hot you should be using the AC. I believe having sunfilms will surely reduce load on A/C, in the form of reduced fuel wastage, you may feel more comfortable and may be able to reduce blower speed by a notch. People may not bother much about fuel part, but comfort and reduced blower noise (better enjoyment of ICE!) should be worth it, I guess.
Falling stone cracks front windscreen Lukeskywalker Street Experiences 32 14th June 2012 14:26
CAUTION!!! Swift Owners installing Front Windshield Sunfilm Pace in Blood Modifications & Accessories 95 23rd June 2011 11:33
New Swift Diesel - Water Leak through front Windscreen and the following messup!!! sam_sant2005 The Indian Car Scene 71 24th December 2010 17:02
Yamaha Rd350 Front windscreen cover bsa1955 Motorbikes 28 18th February 2009 11:51
WagonR front windscreen scratched DCEite Technical Stuff 2 8th July 2008 21:26
