Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 14th September 2009, 19:35   #931 (permalink)
@Santosh - I am a V Kool adherent, V 70 on all my front glasses for many years now! So I do not need to be converted, but the UV learning was very valuable, I must admit.
__________________
If anything is worth doing, it is worth doing well
Sawyer is offline   Reply With Quote
Old 14th September 2009, 20:32   #932 (permalink)
shajufx's Avatar
I am almost finalising on the Garware ICECOOL as recommended by few other friends here. It seems to be the best VFM product compared to all other brands, just 2500 for the windsheild. One thing I would like to clarify now is: I see lot of cars with a greenish or greyish or blueish sun shade boarder on top of the windscreen (which lightens and merges to the glass colour at the bottom). Is it part of the windscreen film or need to be done seperately ? I would love to have them as we dont need to lower the sun shade each time we face the sun. On my Fiesta, the sun shade almost touches my forehead if lowered, because of the slanting windscreen.
__________________
"Woods are lovely, dark and deep. But I have promises to keep and miles to go before I sleep." Robert Frost
shajufx is offline   Reply With Quote
Old 14th September 2009, 20:44   #933 (permalink)
@Sawyer, V70 on all cars! then I can understand how valuable UV learning must have been. So far, I used to think that film model or brand doesn't matter regarding UV, because everywhere it is close to 100% blocking. It was surprising to know that in reality it doesn't matter much even between film versus no film!
santosh.s is offline   Reply With Quote
Old 14th September 2009, 22:43   #934 (permalink)
Once upon a time, when Garware had just begun marketing sun-film for heat control, I happened to be loosely associated with one of the distributors of this film for use on building windows. There was one variant that was completely colorless (neutral) and was claimed to reduce radiant heat (infra-red) by 70%. We tested this qualitatively by using a Philips infra lamp available those days for relaxing muscular pain. One could easily feel the difference between the direct radiation and radiation through the film. When you go out to get the film installed, do so when the sun is bright and overhead. Take the film on offer and test how it feels on say the the back of your palms. Needless to say, you could compare the different films this way firsthand.
Now for the second point: is it effective to use sun-film on the front screen. Do this observation - park your car below and go up to the terrace. Now look down at your car and observe all the glass panes. Which of them presents the greatest area to you? I sure the answers may differ, but for me it is the front windscreen. Now if I radiate heat directly from above then my sixth sense tells me that the front window will allow the maximum of this heat into the car. Whats more, the mid-day sun is supposed to be the hottest, at least in our country, so isn't it elementary Dr. Watson?
Another point: heat radiation bounces off the road, buildings, and other surfaces and enters the car through all the glasses. Infra-red radiation is the number one carrier of heat, so I am told. Ultra-violet (UV) is harmful to skin and eyes, but I do not know how much heat it can generate, relatively speaking. Ditto for visible light; I do not know how much heat energy does it carry; but psychologically it seems hot. Tints, in general, reduce visible light hence visibility. Glasses are normally UV-opaque but transparent to infra-red. In fact UV-transparent glass (quartz) is terribly expensive and is produced in very small sizes. Whereas even some cheap plastics are UV-transparent.
Now the next point about heat and temperature. Take a little glass cube and cover it all over with the best sun film with the maximum heat rejection. Keep this cube under the mid-day sun and watch its temperature (you had put in an electronic sensor inside the cube!). I guess you will see a slow rise in the temperature of the cube. Repeat experiment with a cheaper film, and you will perhaps observe a quicker rise in temperature of cube. The point is that one film cuts more than the other, the RATE at which heat energy enters your car. You will still have to figure out how to remove the heat that is getting in anyway. I am not inclined to believe that any film can demonstrate a cent per cent block of the heat energy.
Cheers.
gostel is offline   Reply With Quote
Old 15th September 2009, 00:28   #935 (permalink)
ImmortalZ's Avatar
Your question of how hot visible light is:
The best sunfilms have 99% IR reduction at 70% VLT. And yet their total heat reduction hovers at around 60%. So y'see, even if you completely remove IR, visible light contributes quite a lot of heat. If you want to block 100% heat, you have to block 100% of radiation. Which is 100% of everything. Which is near impossible.
__________________
Honda - Providing the least Kilo per Lakh since 1948.
Old 16th September 2009, 00:36   #936 (permalink)
Guys, I just checked out my Linea's windshield: It says 70% visibility.
So looks like in modern cars, even windshields are tinted.
Now my question. Already visibility is at 70%, now adding the wind-screen film will further add 70% reduction. So net Visibility we get is 49% (70% X 70%).
Isn't this illegal/dangerous then?
__________________
Fiat LINEA Emotion Pack FIRE 2009
Maruti ZEN LX 2002
Toyota COROLLA VE 1999 (Sold)
neotraveller is offline   Reply With Quote
Old 16th September 2009, 02:17   #937 (permalink)
Sprucegoose's Avatar
no windows/windscreen then?
just a couple of cameras and screens.
I hear microsoft is working on a project that renders 3D models of locations based on photos that have been clicked.
That'll be cool. Microsoft's concept car
controlled by project natal
with only 3 buttons CTRL, ALT & DEL
Sprucegoose is offline   Reply With Quote
Old 17th September 2009, 22:26   #938 (permalink)
mwzd's Avatar
I'm buying a new civic, the dealer is giving me V-Kool J60 / T35.
I'm told J60 is the cheapest in v-kool, how much should it cost for all 4 windows + front and rear?
And is it worth upgrading to the premium v-Kool 70, what should the price differential be?
__________________
  • '09 Civic 1.8VMT
  • '96 Std. Bullet 350
mwzd is offline   Reply With Quote
Old 17th September 2009, 23:27   #939 (permalink)
splitsecond's Avatar
^ya v-Kool 70 is worth the price paid, you can also check 3m films which gives somewaht same performance for half the price.
__________________
|~Pro UT Fragger~|
splitsecond is offline   Reply With Quote
Old 18th September 2009, 02:26   #940 (permalink)
I have a Linea MJD Emotion in Black, and felt the need for going in for Sunfilm especially after the previous car did not have any.
I drive equally at night too, hence visibility was always a prime criteria while reducing heat.
Evaluated on paper and a few demos with a heat lamp and sun film.
Compared Huper Optik, Garware, 3M, V-Kool.
Finally settled on 3M CR70 for the entire car.
This has 99.9% UV Rejection, 97% IR Rejection, 50% Total Solar Energy Reduction & 70% VLT. So it does allow heat to come in, albeit more slowly.
But i have never felt the need to keep the AC fan speed at more than 3 steps at 20 Degrees (Linea has 11 Steps for fan speed on the ACC) to feel cool.
Got it for INR 18000 at Bangalore. Black Car looks cool and has high visibility.
Unless you notice the 3M logo or are told, you would not be able to make out that the front windscreen has a sun film.
Works beautifully night and day.
However, i am not sure this is because of the installtion/film, the rear windscreen at night shines along the defogger copper strips when you have headlights from other vehicles.
Will get it checked shortly with 3M.
PM - B is offline   Reply With Quote
Old 19th September 2009, 00:47   #941 (permalink)
tsk13's Avatar
Please be specific to ask for Ice Cool Shield.
Moreover, the greenish part or of any other color is a part of the glass only. I think Esteem was among the first inexpensive cars to introduce this.
tsk13 is offline   Reply With Quote
Old 22nd September 2009, 08:15   #942 (permalink)
Well said Immortalz. Visible light forms a significant part of incident solar energy and converts to significant heat energy. But as sprucegoose put it, you cannot cut out the visible spectrum without going blind. Although the statute for VLT stands at seventy percent, a hundred percent VLT on the front screen would mean non-compromised vision at night. I am personally repenting for allowing the accessories guy to put an unsuitable film on my windscreen. I intend to correct this ASAP.
Thanks to guys like tsk13 for specifying a particular windscreen sun film. Is the Ice Cool Shield from Garware? Does it allow good visibility for night driving? Does it retain the clarity of the front glass even after film application? Your inputs would be valuable. My current film seems somewhat foggy.
Old 22nd September 2009, 13:02   #943 (permalink)
gostel,
If you choose a high VLT (I have 70%) You would not be able to make out that there is a sunfilm on the front windscreen unless you look carefully or are told. And absolutely no issues at night. I have used CR70 from 3M. The other specifics are in my post above.
Old 22nd September 2009, 13:37   #944 (permalink)
ImmortalZ's Avatar
I would get VK-70 for the front windshield. Cost is around 12k. I don't know how much J60 costs for the windshield though. 60% VLT might cause problems with the cops and/or night driving. You do not want to reduce visibility at night.
__________________
Old 22nd September 2009, 14:12   #945 (permalink)
Sn1p3r's Avatar
I picked the topic a bit late. Glass History from PPG
Today, in order to avoid Sunlight's bleaching property to the Glass additives are added that give greenish tinge to the glass. This removes most of the UV but not IR.
Thus its only for IR that we require heat control screens.
I wonder what brand does best. More research required... Thanks!
__________________
we only live once - make your mark
-_O
Sniper
Sn1p3r is offline   Reply With Quote
Thread Tools
CAUTION!!! Swift Owners installing Front Windshield Sunfilm Pace in Blood Modifications & Accessories 54 8th November 2009 18:02
Rear glass net & front glass eonomic sunfilm for Optra rendezvous Modifications & Accessories 2 23rd March 2009 13:30
Yamaha Rd350 Front windscreen cover bsa1955 Motorbikes 28 18th February 2009 11:51
WagonR front windscreen scratched DCEite Technical Stuff 2 8th July 2008 22:26
Falling stone cracks front windscreen Lukeskywalker Street Experiences 28 21st June 2007 19:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
