Old 3rd May 2010, 00:46   #1201
Thanked: 89 Times
Originally Posted by tsk13 View Post
You're welcome. Great, do let us know which film you're going for. LLumar has a good variety.
I must be immensely tired, just can't remember the model of the film. Shall update my punto thread tomorrow or dayafter with pictures and further details.
It's very very effective though!
sukrit7 is offline   Reply With Quote
Old 6th May 2010, 11:13   #1202
Thanked: 94 Times
Unhappy
I want to ask an open question to all of you who have installed front windscreen sunfilm on their cars.
The car in question is a 9 month old Alto Lxi. it has 3M RE50 on sides and RE 35 on rear.After reading this thread, I think a front Sunfilm is advantageous for my car. The following questions popped up in my mind:
1.) I want no compromises on the front windshield, so I would put 3M CR70 and nothing else, the dealer (Auto Marc) and my colleagues say this is not a valuable proposition for an ALTO. Garware & other cheap sub 1000 Rupee films don't instill confidence in me.
2.) I have been told that winter visibility(fog) is affected by using sunfilm. I partially agree to the fact, but I still want it for privacy.
3.) A friend suggested to install 6' length top and bottom windshield sunfilm, this is ok for me, but, I don't want a burqa clad car.
4.) Another option is to buy a windshield roll which can be stuck & removed at will and, which is cumbersome & is of questionable quality.
Help me guys, do you think I am making a foolish decision by using a 70%VLT sunfilm that is many times the cost of windshield in my car, or should I go for a Burqa install with a 50%VLT film. My main concerns are VLT % and privacy.
JustCause is offline   Reply With Quote
Old 6th May 2010, 23:08   #1203
tsk13's Avatar
Thanked: 279 Times
1. Your perception of Garware is limited to the cheap versions available widely. Garware has options like Ice Cool Shield and Alps, retailing around 3k+ which have 50% Heat Rejection and 70% VLT.
2. No comments.
3. This used to be a pep trend earlier, not now.
4. Won't recommend.
If you want to go for a cheaper option, you've Garware Ice Cool Shield or Alps (same specs with green tint) or 3M RE50 for the front (50% VLT and 44% Heat Rejection). This version of 3M will cost you less as comapred to Garware Ice Cool Shield or Alps.
tsk13 is offline   Reply With Quote
Old 7th May 2010, 08:29   #1204
Thanked: 94 Times
Ok, I have decided 3M CR70 or Llumar AIR75. Installation at Gyro or Automarc depending upon proximity.
Old 7th May 2010, 14:40   #1205
salbin's Avatar
Thanked: 164 Times
Can any one suggest which film among the following has got better visibility:
- 3M CR70
- Llumar AIR 75
- Garware IceCool Shield
Is there any difference in tint/shade among these?
salbin is offline   Reply With Quote
Old 9th May 2010, 02:00   #1206
backrub's Avatar
Can someone provide the details for garware authorized dealers in bangalore?
backrub is offline   Reply With Quote
Old 17th May 2010, 16:51   #1207
sterlingjames's Avatar
Thanked: 36 Times
Dea Praveen
the blurriness on the front windscreen is an installation defect. if the film is on warranty i suggest you get it removed and refixed. there are some incompetents who use a lot of soap solution while installing and this after drying up causes this blurriness. talk to Shanmuga who is from LLumar and who can give you a fairly good opinion of correct/incorrect installations(09841278623)
sterlingjames is offline   Reply With Quote
Old 17th May 2010, 20:54   #1208
Thanked: 94 Times
Installed LLumar AIR 75 for Rs.5900 at GYRO. The film is clear & without any shading and difference is noted when touching outer & inner windshield.Be warned, it will not give you a 'tinted' feeling of privacy etc. If you want that, PP60 for Rs.3500 is an option.
Old 17th May 2010, 21:39   #1209
mukeshgoel's Avatar
Thanked: 385 Times
Originally Posted by Country Road View Post
Just got VCool installed in my Safari.
My Toll Tag (Gurgaon-Delhi expressway) however is not being read by the machine installed at the toll plaza.
There is a slight difference in the cooling.
This was my main concern before getting my front windscreen sunfilm.
However, after getting CR70, have crossed tollgate at least 20-25 times and there was no problem even once.
mukeshgoel is offline   Reply With Quote
Old 20th May 2010, 05:35   #1210
tsk13's Avatar
Thanked: 279 Times
Toll Tag issues, never heard of them but another trouble which Sunfilms have is that of GPS Reception. I've seen certain Sunfilms being advertised as no interference with GPS devices.
Old 20th May 2010, 13:51   #1211
arishi1's Avatar
Thanked: 12 Times
Have V-Kool in my car, I am happy with the Sun Film performance, have not used my GPS much after the installation, but a weekend trip to Pune the GPS was working pretty good. It took some time to get the Satellite locked, but after that it was smooth usage all the way
arishi1 is offline   Reply With Quote
Old 20th May 2010, 15:46   #1212
Sankar's Avatar
Thanked: 4,655 Times
I have Garware Icecool Shield on the front windhsield and Llumar 35 on side windows and rear windshield, its been a month since the installation was done. I'm thinking of getting the front windshield film removed.
Heat through the front windshield has reduce by a bit and it feels easier on the eyes at midday. But It does cut visibility by a little bit during the night, but only slightly. Glare of oncoming headlamps is reduced by a bit. There are a few scratches on the film, probably made when the installation was done and the scratches are a bit distracting when lit up by oncoming headlamps.
Old 20th May 2010, 21:44   #1213
tsk13's Avatar
Thanked: 279 Times
Scratches are a reason enough to get the Ice Cool Shield replaced under the 5 years warranty given by Garware.
Old 20th May 2010, 22:05   #1214
motomaverick's Avatar
Thanked: 869 Times
- 3M CR70
- Llumar AIR 75
Any answers to the above questions? in terms of visibility at night and cooling?
Old 21st May 2010, 08:57   #1215
thelightening's Avatar
Guys I am planning to go ahead with the below installation on my 2008 Model silver wagonR.
Sides and Rear: 3M (RE35 or CS35 or CS20) or 3M CR40
Front: 3M CR 70.
I am looking for your suggestions on factors like its color, visiblity and heat rejection (IRR) coefficients, from who already using any of the above sun films.
thelightening is offline   Reply With Quote
Falling stone cracks front windscreen Lukeskywalker Street Experiences 32 14th June 2012 14:26
CAUTION!!! Swift Owners installing Front Windshield Sunfilm Pace in Blood Modifications & Accessories 95 23rd June 2011 11:33
New Swift Diesel - Water Leak through front Windscreen and the following messup!!! sam_sant2005 The Indian Car Scene 71 24th December 2010 17:02
Yamaha Rd350 Front windscreen cover bsa1955 Motorbikes 28 18th February 2009 11:51
WagonR front windscreen scratched DCEite Technical Stuff 2 8th July 2008 21:26
