Old 11th November 2010, 20:56   #46
Thanked: 2,072 Times
Originally Posted by sapl View Post
Hi Sutripa - brief answers below:
1. The AFR was measured with the car loaded on the dyno, 5000+ rpm, WOT with a wideband AFR meter.
Wonder what the accuracy limits are? How does one recalibrate/ recertify an AFR meter?
4. I do not know what processor it uses. It is not a DIY system. Yes, the tuning tools are powerful, but they give it only to authorised dealers.
Documentation (for the DIY guy)?
Which would be a DIY friendly piggyback?
Sutripta
Old 11th November 2010, 21:34   #47
sapl's Avatar
Thanked: 188 Times
Sutripta
1. My experience on piggybacks is limited to the Unichip.
I was earlier a skeptic of piggybacks, so I never looked seriously at piggybacks !
2. One regular check you can do is that when a car is running in closed loop, check the reading with the wideband. If it is 14.7 (since the narrow band works only at this figure and is extremely accurate), we have a quick check that the wideband it is ok.
Once in a while, cross check with other wideband meters. If there are differences, it is time to replace the probe.
sapl is offline   Reply With Quote
Old 11th November 2010, 22:02   #48
For ultimate performance, I'd agree. However, cardinal rule in modifying is "one change at a time". So a piggyback to gain knowledge, standalone to gain whatever it is that you are optimising!
These are 'sanity checks'. Can anyone (NPL, ERTL etc.) actually certify?
Sutripta
Old 11th November 2010, 22:21   #49
sapl's Avatar
Thanked: 188 Times
Sutripta
I am not aware of any traceable standards for O2 sensors. However, as a long as a sample of air with controlled ratio of oxygen, it should be easy to calibrate. Sensor manufacturer do describe a calibration procedure based on free air.
Old 12th November 2010, 09:44   #50
pranavt's Avatar
Thanked: 272 Times
@Sutripta: Piggybacks like AEM's F/IC are geared towards DIYers. Not too excited about the method of ignition control myself (run a standalone/remap myself), but it should do fine for most people.
Old 12th November 2010, 20:36   #51
AFAIK, O2 sensor readings are highly nonlinear. Single point calibration will not be sufficient.
Would you have a softcopy of its documentation which you don't mind sharing.
Sutripta
Old 13th November 2010, 00:47   #52
pranavt's Avatar
Thanked: 272 Times
Sutripta
AEM F/IC Piggyback
Everything available there including the software, docs, instruction videos and FAQs.
Old 13th November 2010, 22:52   #53
Thanks. Didn't find what I wanted. Will search some more.
Sutripta
Old 13th November 2010, 22:54   #54
pranavt's Avatar
Thanked: 272 Times
What exactly do you need?
Old 13th November 2010, 23:14   #55
The ECU as an embedded system. Schematic, sample commented source code. If ASICs/ CPLDs used, their functional description. Supposing you were taking a class on ECUs. What you would need/ use in your practical class.
Sutripta
Old 14th November 2010, 00:09   #56
pranavt's Avatar
Thanked: 272 Times
Ah, nothing available then. Your only option with that much detail would be a Megasquirt. I don't know much about other ECUs but OBD1 Honda ECUs have been analysed and documented at pgmfi.org over the years. They've lost a lot of info so you'll find it through archive.org when looking through pages from 2005-2007. It's a dying breed at the end of the day so the only purpose is if you want to work with the old Hondas or learn about ECUs themselves. No point going through that info if you're looking to use it on a newer Honda.
Old 14th November 2010, 20:01   #57
Yes, when it comes to openness (of information, not architecture) Megasquirt it is. However, not really designed as a piggyback. And with some limitations.
Thanks for your replies.
Sutripta
Maruti Swift "Special" - 1.4L VVT, Unichip Tuned, 112 BHP! Sankar Modifications & Accessories 38 5th June 2017 15:10
Honda Civic tuned with Unichip sapl Modifications & Accessories 4 6th February 2012 10:31
Unichip from Spitfire, Coimbatore beejay Modifications & Accessories 4 15th December 2009 19:18
Does a stinger / chamber increase performance? rankoz350 Motorbikes 18 8th March 2006 07:27
