Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
LinkBack Thread Tools
Old 10th January 2009, 13:11   #16 (permalink)
vid6639's Avatar
Originally Posted by monty9991 View Post
but isnt the ECU is sealed all around to prevent it form water. i guess they are.
The ECU is water tight only if the ECU is placed in the engine bay. If the ECU is in the cabin then it is generally not water tight.
__________________
2009 Toyota Corolla Altis
2000 Mitsubishi Lancer SFXi (Sold in 2010)
2005 Maruti Alto LXi (Sold in 2009)
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 10th January 2009, 13:20   #17 (permalink)
monty9991's Avatar
ohh ok.. now i get it.
thanks for the info
__________________
NEVER GIVE UP, JUST DO IT !!!!
monty9991 is offline   Reply With Quote
Old 10th January 2009, 13:34   #18 (permalink)
WasavaTyres's Avatar
Wink
How cheap is that !! How much of a diffrence in price would it be to have a watertight ECU for all cars irrespective of ECU placement ??
__________________
Man made booze........
God made grass.........
Who do u trust ??
WasavaTyres is offline   Reply With Quote
Old 10th January 2009, 13:56   #19 (permalink)
noidaboy's Avatar
Where exactly is the ECU placed in a swift?
__________________
DDIS:| The streets are safe until the turbo kick's in ;) |
noidaboy is offline   Reply With Quote
Old 10th January 2009, 16:20   #20 (permalink)
Pace in Blood's Avatar
The ECU is The Electronic Controller Unit which manages all the Electrical supply of your car.
It Also manages the Fuel Pump / Engine Firing, etc...
In short it is the Brain of the Car
And costs between 50000 - 100000 Depending on the car
How does this happen? Is it coz of the liquid they use to clean the windscreen? Any technical explanations?
They Use Soap Liquid first to Wash the Windscreen clean...
Then they use another liquid to help the suncreen be placed correctly as it has a Adhesive which without the liquid will stick immediately
Now both these liquids are used liberally and sprayed on to the glass area
I hope now you get the point.....
So basically a whole lot of water killed the ECU??? What nonsense!! So basically if i were to like throw a bucketfull of water on the windshield, the ECU would die? Or if i were to drive thorgh a thunderstorm for that matter!!
Hey Cyrus the problem What i stated was that the water was sprayed from inside and not outside....
And Yes if you threw a bucket of water on the inside of your windscreen your ECU will Get Damaged in a 'Swift' . (But i Dont Understand Y u Would Throw A bucket of water inside)
Originally Posted by hydrashok View Post
I think it is just a matter of getting the film installed properly.
I have Llumar AIR75 installed on the front windscreen of my Swift (Done quite a while back). There were no issues during or after installation. They placed a custom-cut semi-thick cloth sheet on the dash, under the windscreen, and taped it down before they began the install. Yes, the install is pretty messy, with a lot of water and soap solution getting all over the place.
My film was installed by the Llumar dealer's people itself. The car was taken to their godown, away from the dust of the main road and the install was done there.
Hi Hydra,
My film was also installed by LLMUAR people and was claimed to be the worlds best film and costed me 8000rs only for the front screen....
He was apraised about the problem and he also kept a cloth but anyways water seeped in.. I guess i was not lucky
Thus i was only cautioning my fellow BHP ians
Originally Posted by vikram_d View Post
Llumar is the only company who seems to be having this problem. I got mine done from V-Kool and no problem till date.
I wonder why only Llumar has this problem?
Edit: When I went to Llumar for a front windscreen film they outright refused and stated the same problem. Went to V-Kool and they did it in 2 hours.
Hey Vikram,
I think they did not do it because in my case not only did they have to pay for the ECU but also for the Touch Screen Panel (JVC AVX-800) which got spoilt and also I did not pay for the Screen which Eventually is still in Place
Note from Mod - Please use the multiquote facility instead of separate threads
Pace in Blood is offline   Reply With Quote
Old 10th January 2009, 19:32   #21 (permalink)
karankapoor's Avatar
@paceofblood noida boy asked where exactly the ecu is placed in swift
as mentioned in this thred it is somewhere behind the dash board.
as far i know the liquid which sunfilms wala uses is a mixture of water and
ezee liquid soap.
__________________
P80RSII l ID Chameleon's l Genesis Dual Mono l ID Max l Genesis Dual Mono EXtreme l Kicker l Connection Audison l Dynamat
karankapoor is offline   Reply With Quote
Old 10th January 2009, 20:26   #22 (permalink)
white_vdi's Avatar
i have garware film installed on the windshield of my swift and no problem what so ever. other friends also have got film on the windshield of their swifts and they are fine.
__________________
rain and my swift....thats all i'll ever need!!!!!!!!
white_vdi is offline   Reply With Quote
Old 10th January 2009, 21:04   #23 (permalink)
monty9991's Avatar
well again it all depends on how the guy is applying the film or using the spary of water and shampoo. if they used lots of water to clean the windscreen and did not use any cloth regularly to soak the water then this can happen.
i have never heard about this in Ludhiana as ther are no. of swifts with flim on wind screen glass.
__________________
Old 11th January 2009, 11:08   #24 (permalink)
balenopower's Avatar
Infractions: 0/1 (4)
Shux too late to read this thread...The damage has already been done on my friends swift!
__________________
My life revolves around wheels.....
Get ZIGGY with it!!
2000 Suzuki Baleno
1998 Yamaha RX-Z
2010 Kawasaki Ninja 250R
balenopower is offline   Reply With Quote
Old 11th January 2009, 22:23   #25 (permalink)
ask77's Avatar
The lesson is that one should know the location of the ECU and whether it is waterproof or not before going for accessories or mods since it is such an expensive piece of equipment. In my optra the ECU is located in the engine bay itself and is completely waterproof but even then I do not allow the washing people to use water pressure inside engine bay and prefer air pressure blow cleaning of the engine bay .
ask77 is online now   Reply With Quote
Old 11th January 2009, 23:22   #26 (permalink)
Fountainheader's Avatar
I checked with a dealer for windshield sunfilm for the Swift.. and he quoted 6k for the same. Says 1100 is installation charges (included). Does the Swift really need a windshield sunfilm ?
__________________
Sarchasm - The gulf between the author of sarcastic wit and the recipient who doesn't get it.
Fountainheader is offline   Reply With Quote
Old 11th January 2009, 23:40   #27 (permalink)
theMAG's Avatar
I had absolutely no such issues when I had the front windscreen film installed on my Swift.
__________________
Become who you are.
Old 13th January 2009, 02:13   #28 (permalink)
blueraven316's Avatar
Never even heard of this thing, but will be careful from now on, I have done a fair share of some 3M sunfilms on swift windscreens, but we always put pressure on the installer to take extra precaution. In most cases placing a plastic sheet on dash suffices.
blueraven316 is offline   Reply With Quote
Old 13th January 2009, 08:06   #29 (permalink)
supremeBaleno's Avatar
Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
Our Zxi is running with the stock tinted glass and I never felt the need for sunfilm. I would suggest you drive around for few days and then if you feel the need, you can go for it.
Old 13th January 2009, 09:06   #30 (permalink)
hydrashok's Avatar
Your thread did help. In fact I had seen your thread before I got mine installed, and if the Llumar installer had not taken the required precautions, I would have insisted that they do, based on your experience.
It does help, SB. I was doing the same (driving without sunfilm) for a few months, before I got to sit in a friend's Swift with the front-windscreen-film installed. There was a huge difference in the sun, with zero loss of visibility. You don't feel the direct heat, or that prickly sensation of the sun hitting you directly with this film installed. The only thing is that it is quite a bit expensive. Since I will be using my car for another 5 years anyway, I felt the expense was justified.
__________________
Alpine 9887 | TRU Tech STEEL S44 & S500 | Image Dynamics XS65 & CTX6 | Image Dynamics IDQ12 D2V2 | Connection Audison
Thread Tools
Front windscreen sunfilm? Samurai Modifications & Accessories 1079 20th March 2010 19:15
Installing front components sukrit7 DIY - Do it yourself 2 24th July 2009 14:17
Installing components in front doors of Esteem lordofgondor Ask the Gurus 4 1st October 2008 14:30
Honda City ZX - Broken front windshield alabjarus Technical Stuff 2 3rd October 2007 18:28
crack in front windshield a4_attitude Technical Stuff 19 24th April 2006 18:33
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652
