Old 29th January 2009, 14:35   #16
Gasoline's Avatar
Originally Posted by im_srini View Post
Hi Swathy, could you elaborate please ? As far as I know, this being a RWD & all that, the gearbox & differential are quite separate (by a few feet) & connected only by the prop-shaft. Or is the odo for the Amby driven all the way from the differential ?
Surely, the Isuzu gearbox comes in its own housing...
Usually, the odo is driven from the gearbox output shaft. I'm guessing what's different is the gearing on the odo output between the old & new gearboxes - the revolutions of the odo output cable for a given distance are different.
Srini, I think Swathy is talking about the differential unit. The dive shaft is supposed to match with the Diff gear which in some cases don't. So the diff unit all so to be changed for an Izuzu Gear box. Since Swathy mentioned Odo and this matter there is a little confution i believe. As usual the odo cable receiving the drive from Gear box only, not from differential unit.
SWATHY correct me if i'm wrong. Thank you.
Gasoline is offline   Reply With Quote
Old 6th July 2011, 12:41   #17
dmaheshkumar's Avatar
Thanked: 18 Times
Default Re: Amby - ISUZU gear box change with all minor details
Hows your Car now.Any updates
dmaheshkumar is offline   Reply With Quote
Applying for an Infant / Minor's Passport - Details *here* ascertain Shifting gears 202 7th June 2018 09:43
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
A Modified Amby or the New LE Amby ??? esteem_lover Modifications & Accessories 25 25th February 2011 12:14
Isuzu G1 engine in an Amby !! man23ish Modifications & Accessories 17 22nd July 2010 14:52
Your choice of Gear Box: Tall or Short? turbo_c Technical Stuff 39 25th March 2009 01:28
