Old 16th January 2009, 00:02   #1
Sprucegoose's Avatar
Thanked: 40 Times
Default Refurbishing an OHC 1.3
Hi Guys,
i have an OHC 1.3.
I want to mount an LCD screen in the steering wheel such that when the wheel turns, the screen doesn't.
This screen i want to connect to a FLIR [Forward Looking Infra Red] Pod, among other things like an carputer.
Is this possible and if possible would it be prohibitively / insanely expensive?
I thought it would be quite cool.
Shekhar
Sprucegoose is offline   Reply With Quote
Old 16th January 2009, 00:39   #2
Akshay1234's Avatar
Thanked: 7,243 Times
hahaha. lol i dont think your idea of an lcd on the steering is possible. but a carputer is very much possible.
Old 16th January 2009, 00:41   #3
akshay4587's Avatar
Thanked: 1,686 Times
Seems wierd to me or may be I need to upgrade my knowledge base
Old 16th January 2009, 00:50   #4
quicksilver's Avatar
Shekhar,
It may not be possible on the steering wheel, let alone be safe in case of an accident etc. Why don't you consider putting it somewhere in the Dash not too far away from the line of vision of the driver? like the instrument panel or even at the bottom of the A-Pillar. This may be easier to achieve and safer too. Just my 2c.
quicksilver is offline   Reply With Quote
Old 16th January 2009, 02:08   #5
Nitin's Avatar
I'm not sure if its feesible. All the more,its quite a distraction.
On second thoughts,maybe not.Doesn't make a big difference if the screen is on the steering wheel, or on the dash.
Nitin is offline   Reply With Quote
Old 16th January 2009, 03:32   #6
Thanked: 40 Times
Originally Posted by quicksilver View Post
Shekhar,
The Steering wheel for 2 reasons,
1> Easiest to view while driving [Purely from a FLIR point of view]
2> the COOL factor man.
Just want to know if its possible.
as for safety i doubt if the horn is any safer than an LCD Screen.
I want a Multi touch LCD, then specify:
1 finger for selecting & clicking
2 fingers for scrolling and zooming
3 or more fingers for the horn.
that would be cool.... unless ofcourse i got frustrated and pressed the horn really hard ... hehehe
Old 16th January 2009, 08:00   #7
sats's Avatar
My two bits on this idea - it would be a total distraction, safety issue and finally the horn would too have to be relocated from the steering wheel.
sats is offline   Reply With Quote
Old 16th January 2009, 11:27   #8
badboyscad's Avatar
Thanked: 172 Times
@ sprucegoose : You might want to take a look at this : touchscreen steering wheel Carputer. - MP3Car.com
But, it would be quite a big(sometimes even fatal) distraction while driving.
badboyscad is online now   Reply With Quote
Old 16th January 2009, 13:41   #9
Thanked: 40 Times
Guys,
1> It is a safety feature....
2> I intend to connect it primarily to a FLIR [Forward Looking Infra Red] system / Navigation System
It'll be easier taking a peek at the steering wheel than at a dash mounted Screen
3> If Its a touch screen i can use it as the horn also.
Old 16th January 2009, 15:05   #10
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Where are you planning to drive that you need an infrared system? Just use a good HID light system...
However, if this works, post pics and a detailed write up.
BBS, good find.
Tejas@perioimpl is offline   Reply With Quote
Old 17th January 2009, 03:48   #11
ankitahuja's Avatar
Thanked: 46 Times
I don't think this is practical. The screen should best be on the dash and not on the steering. Apart from the distraction it'll cause, feels like its a fairly difficult task in hand.
Keep posting if you get more information on this.
Old 17th January 2009, 08:14   #12
inferno's Avatar
I think so that you got carried away with iPhone's touchscreen that you want a multi-touch LCD panel with the same but I doubt that's possible as this is something which I haven't heard of.
Anyways, best of luck and do post if you are successful.
inferno is offline   Reply With Quote
Old 17th January 2009, 13:18   #13
Check the link posted by BBS,
But in that case, i think the screen moved with the steering. Not what sprucegoose wants.
Old 17th January 2009, 13:33   #14
inferno's Avatar
I went through the entire thread who's link you posted, but I can see its a simple touch screen and not multi-touch.
I think you thought, that I meant, simple touch-screen LCD carputer is not possble, but I meant, carputer with multi-touch input system is not something which I've heard of , infact I havent heard Multi-touch in anything other than Apple Products and thats why wrote that he got carried away by using iPhone.
Old 17th January 2009, 16:18   #15
Thanked: 40 Times
You have multi touch screens available.
They are REALLY <Censored> expensive though.
the only thing i'm worried about is the glare from the screen.
besides, i doubt it'll happen i'm quite sure that i have to change the enitre steering column and get a custom one fitted
REPORT with PICS: Refurbishing my OHC Vtec. And some mild performance mods! GTO Modifications & Accessories 195 2nd November 2017 07:58
Refurbishing a Mercedes E190 Ricky_63 Modifications & Accessories 48 7th March 2010 11:08
Refurbishing my M800 5 Speed Bouncer Modifications & Accessories 18 6th September 2008 00:11
Ikon - Refurbishing the 1.6ZXI in Mumbai rahuldeodhar Modifications & Accessories 10 7th March 2008 12:08
