| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | what does intercool do to improve the performance... well i know some stuff about turbos...but not intercool... what will be the boost i will be getting... will it affect the millage to a big extend or will it increase as i heard when you install Turbo it Increases the millaga a Bit... *****How much will it cost to install turbo and intercool on my Nissan bluebird 1.8 Petrol... nothing too fancy / expensive...
__________________ I live my life a Quarter Mile at a Time... |
| | #2 (permalink) |
| BHPian | First of all you should know that a TURBO is used to push in more air into an engine, when more air is sucked and pushed into a small area like in the tube connected turbo to the throttle body, air is heated up due to friction between air molecules and because of heat there is less % of oxygen in the compressed air and mind you oxygen is necessary for combustion. another effect of compressed air is pre ignition of fuel when fuel and air is mixed because the air is hot. so charge (air + fuel mixture ) burns inside the cylinder even before the piston comes up and before the spark plug fires this is known as pinging and this damages the ports on the cylinder and also there is loss of power. to reduce the heat of the pressurised air from the turbo, an intercooler is placed between the turbo and the engine. inter cooler is like a radiator which radiates heat by flowing through small fins. This is placed below the front bumper where there is cool air blowing. see this link on how turbo and inter cooler works : http://www.mazdarotary.net/turbo.htm -shaz |
| | #4 (permalink) |
| Team-BHP Moderator ![]() | I suggest you read through This thread (Turbocharge your knowledge)
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ |
| Thread Tools | |
Similar Threads | ||||
| Do all Turbos require idling before shut-off? | GTO | Technical Stuff | 50 | 19th August 2008 18:20 |
| 135 BMW with factory fitted twin turbos confirmed | whatcanthisbe | The International Automotive Scene | 14 | 30th June 2007 02:40 |
| D series mini me head swap step by step!and turbos done.. | nitroxx | Modifications & Accessories | 6 | 10th March 2007 21:49 |
| Twin turbos for Turbo Diesel indian SUVs? | neo_trace | Technical Stuff | 5 | 4th August 2006 18:55 |
| Wanted Used Turbos | Domnic | Shifting gears | 17 | 15th February 2005 16:05 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
