Old 27th January 2009, 13:13   #31
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by Tejas@perioimpl View Post
It's an annoying sound of plastic rubbing against plastic and metal. It seems as if the front door panel is loose and rubbing against the side of the dash. I say seems, cause i cannot exactly localize the sound nor can i find loose parts. But this happens after speeds of 40kmph and if the car goes over a bad patch of road.
Sorry Tejas, I have no clue about this since I've not faced anything like that. Get you door alignment checked. Have you seen how an Octavia door is held in place at the bottom? The small rod that goes into the car body?
Old 27th January 2009, 15:36   #32
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Thanks. I'll get that checked.
Not noticed the octavia door system.
Tejas@perioimpl is offline   Reply With Quote
Old 29th January 2009, 13:48   #33
Default Phase 1 complete
Following things done in phase 1:
Carbon clean and spark plugs checked.
Full regular service and lubrications.
Oil change.
FFE (with the custom headers - for the north boys lingo)
Used muffler in mid rather than expansion chamber to cut down on noise.
Throttle body expansion done.
K&N exhaust.
ECU Hard reset.
Next:
Clutch & brakes replacement
Later:
2-3options.. yet to decide...
And last night, without the K&N filter yet attached, i dragged with a VTEC-ANHC at three consecutive signals and left him 2car lengths behind all the three times... that guy felt so bad being beaten my a 8 1/2 year old car!!! hehehe...
But that screwed my clutch for sure...
Pics and cost breakup soon...
Old 29th January 2009, 14:08   #34
Fountainheader's Avatar
Yes please post the pics soon. Are you planning on something like Exedy ?
Fountainheader is offline   Reply With Quote
Old 29th January 2009, 15:31   #35
Nah... OEM replacement.
Old 29th January 2009, 16:17   #36
amit_mechengg's Avatar
Thanked: 1,556 Times
nice one tejas, atleast after your mind changed and you dropped the plans of selling your state of art OHC. eagerly waiting for the pics.
can you please explain hard ECU Remap. are you experiencing any changes in the way ur car rides after the ECU remap alone?
Old 29th January 2009, 16:23   #37
frankmehta's Avatar
Thanked: 2,334 Times
congrats TK. with so much work done, the SCF would have come to good use. but you and i used it on pomfret florentine and cross cafe :-P
anyways listen, whats a hard reset? is it like resetting the ECU in the car to think that everything that's installed NEW is thought off by the ECU as stock?
Old 29th January 2009, 16:40   #38
This is not a remap. It's a reset.
A soft reset is done by just removing the battery terminals for a while to get the ecu to factory settings.
A hard reset is done by attaching the scanner. When the scanner was first attached, it detected a malfunction in the air intake sensor. After the reset via the scanner, this error was gone. the car also drives smoother.
Now, after the reset, i have been asked to drive the car at higher revs so that the ecu "learns" the new driving dynamics and sets itself to that sporty setting...
EDIT: frank are you coming for the mega tbhp OHC meet? i've put your name tentatively. It's this sunday at 1pm at BKC (lunch and photo shoot). go to the below link and confirm:
http://www.team-bhp.com/forum/team-b...et-thread.html
Old 9th February 2009, 13:56   #39
Update:
Clutch replaced.
Gear and engine mounts replaced.
Iridium Sparks installed.
Rear brakes serviced. Front OEM honda brakes put.. temporarily.
Another hard ECU reset in the offing...
Annoying squeak of the door still there. Now a rattle has come up from somewhere inside the dash on the left side. May need to open the dash up...
Old 9th February 2009, 15:42   #40
ankitahuja's Avatar
Thanked: 46 Times
Tejas, I got a long list of replacements/repairs/settings done on my OHC in Jan 09. (which included a hard re-set).
Irony is, my car has also developed this strange rattle inside the dash, left hand side. This only occurs when revving real hard, when the engine is vibrating at peak and during heavy back pressure. Same for you?
Btw, I decided not to get the dash opened since the rattle does not come with normal driving.
Old 9th February 2009, 15:59   #41
The rattle starts sometimes after crossing 40kmph and sometimes at higher speeds. No fixed speeds.
I'm first gonna just remove the glove box at home and check behind it before i get the dash opened up. And if i do, i'll get the AC serviced as well!
Old 9th February 2009, 16:11   #42
ankitahuja's Avatar
Thanked: 46 Times
If it's a loudish rattel, do post a sound clip if you can. Maybe I can identify and rectify the rattle in mine as well.
Good idea to get the AC serviced.
Old 9th February 2009, 16:17   #43
It's a good idea about the audio. I'll do that. BTW, isnt the wiper motor mounted somewhere in that area? I suspect some part of that assembly to be loose.
Old 9th February 2009, 16:20   #44
ankitahuja's Avatar
Thanked: 46 Times
Wiper motor is under the hood and on the RHS, in front of the streering.
It's the AC components that are under the LHS of the dash.
Old 9th February 2009, 18:22   #45
pranavt's Avatar
Thanked: 274 Times
Update:
Clutch replaced.
Congrats! You're going for EBC braking right? Pads or rotors or both?
Performance Exhaust & some other mods for the Honda CR-V 2.4 AT indra_slk Modifications & Accessories 26 28th August 2014 12:00
Honda Unicorn - Cosmetic and Performance mods - please give your views (Pics on Pg 9) rider60 Motorbikes 155 29th August 2013 14:02
Performance Mods For City iDSI Vishesh Modifications & Accessories 37 24th May 2009 01:16
76mm Honda performance pistons, baleno performance cam & NOS kit for sale. mclaren1885 Shifting gears 6 16th September 2007 14:02
