Old 3rd April 2009, 23:13   #61
abhayshanu's Avatar
Thanked: 168 Times
Ok thanks dude,but what about the other mods,i am also planin to lower the car and get it stiffened.
abhayshanu is offline   Reply With Quote
Old 4th April 2009, 00:17   #62
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
You will also be prone to damaging your alloys on a pothole at moderate to high speed in 16-17 inchers.
In addition to suspension problems, steering issues will also crop up.
Tejas@perioimpl is offline   Reply With Quote
Old 4th April 2009, 10:14   #63
abhayshanu's Avatar
Thanked: 168 Times
What about iridium plugs,should i get it or not?
also which cold air intake?i would prefer low-mid rpm torque.
Old 5th April 2009, 12:15   #64
abhayshanu's Avatar
Thanked: 168 Times
im installing a heavy music system,this will really increase load on the suspension,so should i go and tighten the suspension or replace it with a new performance one,also in either please do provide cost.
Old 8th April 2009, 09:46   #65
Default CAI for OHC
sniper automobile (Dahisar) has quoted 18000/- for an K&N typoon cold air intake.
dhananjay is offline   Reply With Quote
Old 8th April 2009, 11:54   #66
abhayshanu's Avatar
Thanked: 168 Times
Dude, i really dont know about that, automech said that it would cost around 15k .Also go for pepercross or green, they are better, if you want to know why, search the forum, a big thread is there.
Old 8th April 2009, 19:38   #67
di1in's Avatar
Thanked: 92 Times
Don't use K&N, i'd rather recommend green.. check it out here (Air Filters - K&N vs Greencotton vs Pipercross).
di1in is offline   Reply With Quote
Old 8th April 2009, 20:00   #68
narayan's Avatar
Thanked: 1,356 Times
These are obsecenely high rates for what IMO is not a significant performance upgrade!
if u still need a "cold air intake", you can get it made at much less
a conical filter should be in the 5-6k range. u then need some custom piping on one side to the air intake and then u can enclose the filter in custom canister and have a flexi PVP piping leading to the wheel well or front bumper
but remember - all this makes sense if you can suck in MUCH colder air from outside than in the engine bay ( which is not the case in typical tropical climate )
narayan is offline   Reply With Quote
Old 10th April 2009, 19:24   #69
di1in's Avatar
Thanked: 92 Times
why don't you try painting the grilles like this,,
Originally Posted by Tejas@perioimpl View Post
Hi guys,
What i am considering:
- Free flow exhaust
- ECU remap
I have a free flow exhaust from Raj Hingorani that's not yet even opened. SYJ had bought it and it doesn't have a taker so if you're interested do contact me. It costs INR 14,500, and Raj Hingorani is a respected guy - as are his FFEs.
If you're car has run a lot i'd suggest atleast a ecu reset, because it worked wonders on my car. The difference that it brought up on my OHC is astounding ! Even the exhaust note changed a bit, though i dunno why. Right now it's the sweetest thing i've heard !!And the engine runs heavenly smooth.. ...
Old 10th April 2009, 20:25   #70
Dude, read the whole thread. My mods (stage 1) are all done. My OHC front grill was one of the first one to be painted body colored. Check the pics in my garage.
Old 11th April 2009, 21:29   #71
di1in's Avatar
Thanked: 92 Times
I'd intended it as reply to abhayshanu, but i quoted wrong.. sorry.
Old 15th April 2009, 11:49   #72
abhayshanu's Avatar
Thanked: 168 Times
Guys,any one here has swapped?
Not with a D16B,but others?
Even if no,can anyone tell me if i can swap a B18C5,it is done in similar chassis Civic,so can it be done it our citys?
Old 15th April 2009, 12:08   #73
viper's Avatar
Thanked: 9 Times
I have done a B16A swap in my OHC. As far as your other question goes yes you can install a B18C5 in the OHC as well and it has also been done already.
Viper
viper is offline   Reply With Quote
Old 15th April 2009, 14:05   #74
abhayshanu's Avatar
Thanked: 168 Times
Really? I have heard that they give about 190 BHP N/A,also what are the cost?I want a extremely powerful car, took inspiration from this - the B18C on wiki,and searched the net for civics or citys with it, and then found this beast.
Old 16th April 2009, 01:43   #75
v1p3r's Avatar
Thanked: 27 Times
B18Cs produce upto 200 hp in stock form. Yes, they have been installed on OHCs in India. The first project was done about 3 years ago in Bangalore.
Performance Exhaust & some other mods for the Honda CR-V 2.4 AT indra_slk Modifications & Accessories 26 28th August 2014 12:00
Honda Unicorn - Cosmetic and Performance mods - please give your views (Pics on Pg 9) rider60 Motorbikes 155 29th August 2013 14:02
Performance Mods For City iDSI Vishesh Modifications & Accessories 37 24th May 2009 01:16
76mm Honda performance pistons, baleno performance cam & NOS kit for sale. mclaren1885 Shifting gears 6 16th September 2007 14:02
