Old 30th January 2009, 16:10   #16
leadf00t's Avatar
Thanked: 12 Times
I guess there was a point in the life of the car when the tyres were worth more than the car. :-)
LOL Dhanno's shoes were more worth than Dhanno itself.
Ishan tune veeru se permission lee thi kya???
Ok enough of talk
Here is what i found from Honda Ecu Pinouts - CivicLand Honda Civic Forums
OBD1 pin outs.
A1-INJ1 INJ1
A2-INJ4 INJ4
A3-INJ2 INJ2
A4-VTS VTEC solenoid
A5-INJ3 INJ3
A6-PO2SHTC O2 sensor (heating element)
A7-FLR1 fuel pump
A8-empty
A9-IACV IAC valve
A10-empty
A11-empty
A12-FANC engine coolant temp switch
A13-MIL MIL (check engine light)
A14-empty
A15-ACC (a/c compressor clutch)
A16-ALT C alternator
A17-IAB IAB Solenoid
A18-empty
A19-**
A20-PCS EVAP purge control solenoid
A21-ICM ICM
A22- *per Sander* Ignitor
A23-PG1 ground
A24-PG2 ground
A25-IGP2 to main relay and to gound for o
A26-LG1 gound
B1-IGP2 to pin A25
B2-LG2 ground to shields for CYP & TDC
B3-**
B4-**
B5-ACS a/c switch
B6-empty
B7-**
B8-PSPSW PSP switch
B9-STARTER SIGNAL starter signal
B10-VSS vehicle speed sensor
B11-CYP P CYP -P
B12-CYP M CYP -M
B13-TDC P TDC -P
B14-TDC M TDC -M
B15-CKP P CKP -P
B16-CKP M CKP -M
D1-VBU Back Up Power
D2-BKSW brake switch
D3-KS Knock Sensor
D4-SCS service check connector
D5-empty
D6-VTM VTEC pressure switch
D7-TXD/RXD (data link connector)
D8-empty
D9-ALT F alternator
D10-ELD electric load detector
D11-TPS TPS Signal
D12-**
D13-ECT ECT sensor
D14-PHO2S O2 sensor
D15-IAT IAT sensor
D16-VREF VREF
D17-MAP Map Signal
D18-**
C19-VCC1 MAP 5V
C20-VCC2 TPS 5V
C21-SG1 MAP GND
C22-SG2 TPS GND
leadf00t is offline   Reply With Quote
Old 4th December 2012, 15:13   #17
ezhilsundar's Avatar
Default Re: Honda Type 1 City - ECU pinout info needed
Can anyone tell me that does the type 1honda city 1998 1.3 exi is Obd1 or Obd 2 compliant
ezhilsundar is offline   Reply With Quote
Type of Box for Alpine Type R Woofer Akshay1234 In-Car Entertainment 15 10th August 2011 15:24
Swift Type 1 and Type 2 Vajo The Indian Car Scene 19 15th January 2010 18:18
Difference between Type 1 and Type 2 Honda 1.5 gameonrwind The Indian Car Scene 7 8th August 2008 10:54
Modifiction of Type I M800 to Type II sathyaprakash Modifications & Accessories 17 3rd July 2007 21:56
esteem type 2 instrumentation in type 1 rdkarthik Modifications & Accessories 3 3rd February 2006 14:43
