Old 26th April 2005, 12:50   #1
shazikon's Avatar
Thanked: 19 Times
Default Turbo charging a Ford ikon 1.6
hello guys,
I am thinking of turbo charging my 4 year old ford ikon 1.6. Any suggestions weather it is worth going for TCing IKON. I have a few questions:
1. How good or bad would these modifications bode with this car?
2. What turbos are available in India/Blore? what is preferred for this car? Are there any Turbo kits available for this car including intercoolers, BOV and wasteges ??
3. Do i have to change ECU if i need to go for TCing? or would the computer calculates the change in airflow and provides a better fuel mixture?
4. Has any one in the forum already tried TCing an IKON, if so what has been the performance and how much BHP can i get?
5. any suggestions of some good experienced tuner in Bangalore where i can get this proj done?
6. what would be the cost of the entire proj including Turbo,intercooler,BOV, header modification etc?? anything else?
thanks,
-shaz
shazikon is offline   Reply With Quote
Old 26th April 2005, 13:27   #2
turbo_lover's Avatar
what mods do you have onm your ikon at present ?
turbo_lover is offline   Reply With Quote
Old 26th April 2005, 13:34   #3
ZenGT's Avatar
iceman is the right person to call
ZenGT is offline   Reply With Quote
Old 26th April 2005, 14:10   #4
shazikon's Avatar
Thanked: 19 Times
Turbo_lover i just have a KN filter installed on my intake and 14" alloys with 195-60 R14 rubber.. thats about it.
Old 26th April 2005, 15:14   #5
Psycho's Avatar
Thanked: 95 Times
[quote=shazikon]
Have to lower the car for better handling and need to upgrade the brakes.
Ready kit are unheard of but however you can source Garetts and IHI turbo's as per you needs the costs for the turbo's would be anywhere from 1,500 to 10 k. You could do with a Isuzu G1 IHI turbo with wastegate which produces about 10 PSI. Intercoolers can also be easily sourced or made am not too sure of the BOV's though.
You cannot do it with your stock electronics as you would require a 2 - 3 bar sensor to replace the MAP sensor and the same will have to be mapped to your ECU as the signal range might vary.
Well you seem to have covered all the points excepting the oil supply. The total cost at a bare minimum can vary from 20 - 40 k.
Hope that helps you.
Old 27th April 2005, 18:21   #6
Montoya's Avatar
Thats it. I have been quoted in Mumbai by KS motor sports around 1.5 Lacs minimum. Where can you get a TC for around 10K like a Garret. I was told Rs. 57500 for a T-25 Garret
Montoya is offline   Reply With Quote
Old 27th April 2005, 18:44   #7
karthik247's Avatar
Thanked: 16 Times
cost of a turbo is 1.5k to 10k ONLY!!!
karthik247 is offline   Reply With Quote
Old 27th April 2005, 18:45   #8
Montoya's Avatar
You talking about a first hand one. Where will you get it at that price
Old 27th April 2005, 18:49   #9
Montoya's Avatar
Compressor Turbine Displacement Dealer (INR) Min order
Model Hsg. A/R Wheel Trim Wheel Dia Horse Power Comp Flow lbs Hsg. A/R Wheel Trim Wheel Dia Litres quantity
GT25 0.7 48 2.09/3.00 350 44 0.64 76 1.85/2.12 1.7 to 2.7 57500 12pcs
GT25 0.7 48 2.09/3.00 420 44 0.86 76 1.85/2.12 1.7 to 2.7 58880 11pcs
GT30 0.7 52 2.17/3.00 500-580 50 1.06 84 2.16/2.36 2.0 to 2.7 80500 8pcs
GT35 0.7 56 2.41/3.22 700 60 1.06 84 2.45/2.68 2.5 to 3.2 92000 8pcs
Now what does this table say??
Old 27th April 2005, 19:57   #10
ZenGT's Avatar
you cant a new turbo for that cheap.. offcourse if u try chor bazar... u can get old used turbo for around 10 to 15k..
and to turbo your car.. there is a lot of work involved ....
what ks is selling is bolt on kits.. all brand new.. which sounds resonable....
for a good turbo setup u need proper plumbing turbo manifold...
good fuel.. good fuel flow on high rpm when the boost rises...
fuel pressure regulator.
a/f ratio meter..
boost gauge..
bov
intercooler
need a map sensor depending on the kinda boost..
or a piggy back etc etc.....
Old 28th April 2005, 10:20   #11
iceman91's Avatar
Thanked: 22 Times
hey agree with zengt totally..turbo kits for 10k,20k and 40k ridiculuous unless you want a DIY and experiment on your car using second hand unreliable stuff and leaving it in the garage for trial and testing for any period from 30 days to a lifetime!!
if you want to do a turbo install in your car and want to use a branded kit whis has all the parts/gauges the basic list is:
1. turbo
2. intercooler
3. plumbing
4. sensors
5. blow off valve
6. external waste gate
7. plumbing
8. gauges
9. piggy back ecm/ stand alone ecm
10. as well as fuel regulators adn pumps
now all this if you want buy a top of the line performance company it will cost you anywhere from 3000 to 8000 us$...shocking right!!!
well that is what you get but if you want a good turbo kit where in the turbo is branded and the other parts are equivalent you should get the whole package for under 3000us$
so karan shah's prices are ok but his work.........never seen or experienced it.
in bangalore there are a few people who can do this install for you.
iceman91 is offline   Reply With Quote
Old 28th April 2005, 11:50   #12
Thanked: 12 Times
^yeah that...or just save up money, sell ur ikon, and buy an OctaviaRS (got turbo from da factory..just up the boost/chip it and u shudd be good). Hopefully i can snag an RS for a good price (gonna put my dad's negotiating skills to the test in india ).
CaliAtenza is offline   Reply With Quote
Old 28th April 2005, 12:02   #13
iceman91's Avatar
Thanked: 22 Times
agree with you cali but a tc ikon would leave a trail of dust for the skoda to follow!!!even if it had a chip in it!!!
Old 28th April 2005, 13:12   #14
Montoya's Avatar
There is one TC Ikon running 175 BHP
Old 28th April 2005, 13:36   #15
islero's Avatar
I would love to see some pics of this car after it is done.
islero is offline   Reply With Quote
ARTICLE: Points to consider before TURBO-Charging your car Psycho On modifying a car 111 5th December 2014 20:04
Turbo-charging a Honda Accord V6? accord masters Modifications & Accessories 13 22nd September 2006 23:37
Can a Turbo's Charging be SET as needed ?? Jatt Technical Stuff 28 23rd June 2006 16:17
Turbo-charging a pre-2000 TATA Sierra hell_rider The Indian Car Scene 5 8th September 2005 13:05
turbo charging snoopy41 Technical Stuff 48 10th September 2004 12:16
