Old 6th April 2009, 04:00   #226
ananthkamath's Avatar
Thanked: 59 Times
Good job on getting the right material. I wouldn't worry about the abrupt changes in cross-section because there is no significant side-loading going on there.
Also, I forgot to mention earlier, Grade 12.9 allen bolts only for the 4 adjusters and a minimum of 45 lb-ft of torque, and you should be good to go.
I wish you'd also incorporated a caster adjuster when the plates were designed.
ananthkamath is offline   Reply With Quote
Old 6th April 2009, 05:56   #227
16v100bhp's Avatar
This thread is getting hotter day by day.. Great work Jithu.. Keep the enthusiasm going..
16v100bhp is offline   Reply With Quote
Old 6th April 2009, 10:40   #228
amit_mechengg's Avatar
Thanked: 1,545 Times
Originally Posted by Ford Rocam View Post
Which steps you are referring to? top/bottom?
the bottom flange/step which is resting on the springs circumference.
Old 6th April 2009, 12:34   #229
Psycho's Avatar
Thanked: 95 Times
Attachment 120314
Monday work starts on camber plate.
Wouldn't it have been better if you had used a small notch to stop the spring from turning like the stock top plates.
Old 6th April 2009, 21:49   #230
Ford Rocam's Avatar
Thanked: 16 Times
The notch is there on OHC strut & that is for OHC Springs, both on top spring end & bottom assembly, but in DMS original config there is no notches either on top & Bottom where springs sits, more over springs of DMS & OHC are totally different hence decided to stick to DMS design.
They have collar both on top & bottom so that spring doesn't moves from its location, hence implimented the same design on Top.
Ford Rocam is offline   Reply With Quote
Old 14th April 2009, 23:12   #231
Ford Rocam's Avatar
Thanked: 16 Times
Finally got my Camber Plates ready, it took some time as the work was carried out on a CNC machine.
Next, it goes for anodizing process, will click the pics & update once i receive it as i didnt carry my camera today.
Old 16th April 2009, 01:33   #232
Ford Rocam's Avatar
Thanked: 16 Times
Ok guys, i managed to get few pics today before it went for anodizing process
The camber plate done up on CNC
Completely assembled with DMS shocks.
Old 16th April 2009, 03:16   #233
Thanked: 59 Times
What spring rates are you going to use?
Old 16th April 2009, 22:52   #234
Ford Rocam's Avatar
Thanked: 16 Times
@ananth these are not brand new shocks it came with springs as it is, we have very limited or no choice on springs when it comes to OHC. though i will test this setup first & then take a call regarding that.
meantime got the stuff Anodized here are some pics
with suspension
You need to hold that 6061 T6 Billet Aluminum Anodized on hand & feel it, its simply amazing!!! The people standing there who were observing were asking " sahab yeh imported hai kya "? I told them "nahi bhai idhar hi banaya hai" lol
Old 16th April 2009, 23:00   #235
ramie2400's Avatar
Thanked: 58 Times
Jitu that looks real awesome,i wish you goodluck and full success for your hardwork in your fav. project
Old 17th April 2009, 08:23   #236
vikram_d's Avatar
Thanked: 937 Times
I just noticed that you have made the threads directly in the aluminium pieces. I would recommend that you use helicoil inserts in them as the threads are going to wear out pretty quickly in aluminium. Don't worry there will not be any extra machining involved. These inserts will protect the threads and prevent them from wearing out.
Heli-Coil | Helicoil | Helicoil Insert | Helicoil Tap | Helicoil Inserts | Helicoil Gauge | Helicoil Kit
vikram_d is online now   Reply With Quote
Old 17th April 2009, 09:19   #237
Ford Rocam's Avatar
Thanked: 16 Times
Yeah vikram, helicoil was installed after some time i took the pics.
Old 17th April 2009, 11:51   #238
vikram_d's Avatar
Thanked: 937 Times
Great. Everything should work out just fine then.
Old 18th April 2009, 22:47   #239
navpreet318's Avatar
Thanked: 837 Times
Well the parts are coming up great Jitu.Good work by your machine operators.when are they getting installed?
navpreet318 is offline   Reply With Quote
Old 25th April 2009, 16:19   #240
Ford Rocam's Avatar
Thanked: 16 Times
Finally its ready... i am really happy the way its come out, but i still feel there is scope of improvement in the design, nevertheless
The Combination, Yokohama Advan Neova AD07 + DMS 50 MM Gold with custom made Camber Plates.
once i get the alignment done, i will test the setup & give my verdict in a weeks time.
My Turbo R18 Honda Civic. EDIT: End of an era... Nikhilb2008 Modifications & Accessories 145 8th November 2017 13:25
My Honda City Vtec - RRP Dyno report - Graph included fieroid Modifications & Accessories 29 25th October 2012 16:49
Re-Mapped Optra Magnum TCDI. EDIT:Dyno Graph on Pg 4 brraj Modifications & Accessories 196 4th March 2012 09:54
My TURBO-Charged Swift Petrol! And a dyno graph too Sportsmind Modifications & Accessories 43 8th September 2011 02:40
Modded Skoda RS Dyno Graph KS Motorsport Modifications & Accessories 30 21st October 2010 10:59
