Old 19th February 2009, 01:49   #1
Jun
Default Twin Spark Plug
Hello,
I have a Maruti Swift done about 5000km. I would like to change the OE spark plugs to Bosch or NGK, Twin Spark-Spark Plugs.
Would like to check 2 things:-
1. Are any modification required to the electricals to support the twin spark-spark plugs?
2. Would it improve the mileage?
Thanks.
Jun is offline   Reply With Quote
Old 19th February 2009, 15:57   #2
pradipk's Avatar
Thanked: 21 Times
No modification is required for Twin spark plug. Regarding milage, it definately improves. ideally double spark-> less unburnt feul -> more milage. but I am sure it will not be big enough in real driving conditions. Btw do you know where can we get Bosch Twin plug in Bangalore? I tried couple of places in J C Road for my matiz but couldn't found. One shop NGK was there but I am not interested in that.
Thanks.
pradipk is offline   Reply With Quote
Old 19th February 2009, 16:40   #3
Jaggu's Avatar
Thanked: 8,694 Times
If its a stock car, get a good set of genuine NGK's and you will be fine. Really doesnt make that much of diff (twin leads) and they are a pain to clean and set gap.
Old 19th February 2009, 16:42   #4
Raccoon's Avatar
Thanked: 105 Times
There is no such thing as "twin spark" spark plug! Dont get sold with such marketing gimmicks!! The only benifit you might get from twin (or more) electrode spark plugs is that they may last longer than the normal ones. But the cost will negate the benifit. You will not see any increase in fuel efficiency or anything else.
If you still want to use them, you certainly dont need to modify anything.
I would suggest you use normal NGK plugs of the correct spec. for your car.
Old 19th February 2009, 17:38   #5
cyclops's Avatar
Thanked: 9 Times
where do you find genuine NGK's in pune?
cyclops is offline   Reply With Quote
Old 19th February 2009, 20:04   #6
Raccoon's Avatar
Thanked: 105 Times
Go to NGK and find the dealers in Poona. If they are too far, you can try calling and asking them where you can find genuine NGKs closer to you. Be more careful of fakes if not getting them from the authorised dealer.
Old 20th February 2009, 07:16   #7
Jun
Thank you. Does give me some insight on the next step.
Is it really necessary to change the Spark Plug every 10K KMS ? mithun Technical Stuff 50 1st December 2015 08:12
Is It necessary to add new plug wire,ignition coil if adding new NGK Iridium Plug finetuning Modifications & Accessories 20 12th September 2011 10:45
Iridium or Twin Electrode Plug ?????? eagle_f1 Motorbikes 2 11th November 2006 23:44
How does spark plug gap affect mileage? Samurai Technical Stuff 1 27th December 2005 15:24
MSD Spark Plug Wires & Ignition coil Kaizer Sozay Modifications & Accessories 11 16th December 2005 09:12
