Old 21st February 2009, 21:39   #1
greenhorn's Avatar
Thanked: 1,519 Times
Default Piggybacking LED's onto exisitng Lamp connections : How?
Now That I've upgraded my number plate lights and interior lights to LED's , I feel like adding some LED goodness to the rest of the car.
Say I want to add a string of LED's to light up when the parking lights are turned on. How do i connect them without cutting any of the existing wires?
Or will i need the help of an auto electrical guy?
Old 21st February 2009, 23:42   #2
Parm's Avatar
Thanked: 611 Times
you can do it yourself but you need to understand how the electricals work, if you have that understanding....you can do it!
otherwise its wise to pay and get it done from an electrician as per your requirments!
Parm is offline   Reply With Quote
Old 22nd February 2009, 05:24   #3
greenhorn's Avatar
I know how the wiring works, Its just how to go about getting connections from the wiring connectors/harnesses without damaging anything. I suppose I could twist some wire around the connectors, ut I want to do it better
Old 22nd February 2009, 09:00   #4
greenhorn's Avatar
got hold of a guide finally
How to Install Under Car Lights on your Vehicle
I think I'll have to get the wiring done seperately
Old 22nd February 2009, 09:02   #5
srijit's Avatar
greenie, are you going to make angel eyes or fairy lights for your car?
srijit is offline   Reply With Quote
Old 22nd February 2009, 10:18   #6
greenhorn's Avatar
for my fogs first probably. need to find a way to take them apart and put them back together. theoretically , a heat gun should work
DIY-Blue LED Parking Lamp & Speedo Meter+Wire Mesh Grille & Underbody Neons for Alto badboyscad DIY - Do it yourself 133 1st March 2015 00:50
Convert Rear Fog Lamp To LED On Swift Epic Modifications & Accessories 24 3rd September 2010 22:43
How to combine 2 ADSL connections ? mithun Gadgets, Computers & Software 19 14th September 2009 11:45
Piggybacking on existing JVC DVD Player. wanderernomad In-Car Entertainment 8 3rd January 2009 13:16
Does Reliance Infocomm give connections for WCDMA phones ntomer Gadgets, Computers & Software 2 9th November 2006 15:08
