Old 3rd March 2009, 15:34   #1
k_shanz's Avatar
Thanked: 64 Times
Default Fuel Pressure Regulator
A top tuner mechanic from coimbatore told me ECU is not a must do set-up for a mpfi-engine while swapping the engine!
Fuel pressure regulators are enough for the job!
We can set the amount of fuel flow to the intke manifold by a regulotor switch!
Can anyone suggest me which is the best fuel pressure regulator for an Zen mpfi if am going for an esteem engine swap?
Please Help!
k_shanz is offline   Reply With Quote
Old 3rd March 2009, 21:02   #2
furioussphinx's Avatar
I dint get it, you want to swap an esteem engine into your mpfi zen, right? The ECU for both the zen and the esteem are the same. Its only the engine that differs. The engine block is the same too. So you practically dont need to change the ECU or wiring. Keep that intact and just go on for the esteem engine.
Happy modding,
Sagar.
furioussphinx is offline   Reply With Quote
Old 3rd March 2009, 22:10   #3
mura's Avatar
Thanked: 26 Times
I suggest you look for another "top tuner mechanic".
And it is news to me that both a 1.0l and a 1.3l engine share the same ECU.
mura is offline   Reply With Quote
Old 3rd March 2009, 23:06   #4
iceman91's Avatar
Thanked: 22 Times
FPR do not make such a vast difference else a 10k mod would suffice to all of us!!!
get a new tuner or maybe you misunderstood
iceman91 is offline   Reply With Quote
Old 4th March 2009, 01:03   #5
aditya.86's Avatar
Thanked: 17 Times
I would suggest you consult another tuner so that your doubts are cleared. As far as i know there is no such FPR for a zen. Its common for a few models.
Guess the FPR for a zen should suit the esteem as well.
aditya.86 is offline   Reply With Quote
Old 4th March 2009, 13:09   #6
k_shanz's Avatar
Thanked: 64 Times
Default Fpr
Happy modding,
Sagar.
Hey he is a well experienced tuner, and have been tuning Inrc cars, both for MRF, JK and sometimes red rooster! What he told is that the displacement itself make the difference as zen is 1000cc and estemm is 1300! if i dont fix any puel regulators i may run my engine short of fuel there wont be enough difference just by changing the half bottoms!
Ecu may be same there must be difference in the programming in it, the amount of fuel suplly is more in 1300 cc engine when compared to a 1000cc zen engine!
Thank You!
Old 4th March 2009, 15:48   #7
mura's Avatar
Thanked: 26 Times
So you are going to swap your Zen engine to the Esteem engine and keep the Zen ECU and add a FPR to increase the fuel flow to the Esteem engine Right?
If so why cant you get the Esteem ECU with your swap and avoid the FPR?
Surely the Zen ECU will be waaaay off in fueling and timing the 1.3 Esteem.
Old 4th March 2009, 16:24   #8
k_shanz's Avatar
Thanked: 64 Times
Default Am swapping my bottom half only!
Good question! If i go for a Esteem ECU i must fix a esteem head also! Am not swapping my engine completely! Am geting the bottom half only, which include the cranks pistons and rods!
A full esteem engine will not come under my budget!
Old 4th March 2009, 16:42   #9
Thanked: 54 Times
I'm not sure about fueling, the timing is the same for both i think
techn0l0gist is offline   Reply With Quote
Old 4th March 2009, 16:58   #10
k_shanz's Avatar
Thanked: 64 Times
Default Almost same!
Timings are almost same for most suzuki cars! Thats the advantage for the suzuki cars for swapping the engines!
Old 4th March 2009, 17:15   #11
iceman91's Avatar
Thanked: 22 Times
so u are just going with bigger internals! That is like a stroker kit. Then what you said makes sense
Old 4th March 2009, 22:18   #12
k_shanz's Avatar
Thanked: 64 Times
Bigger internals?? you mean the pistons and rods?? I have carry out a slight modification on these things!
Battery / Alternator / Voltage Regulator problem? babe_on_wheels Technical Stuff 109 10th June 2018 21:36
VW Beetle Convertible : Window Regulator Issue vivekiny2k Technical Stuff 4 3rd January 2013 21:52
Fuel Pressure regulator in ikon 1.6 Ford Rocam Modifications & Accessories 12 11th July 2012 11:03
Baleno Fuel pressure regulator nepalken Technical Stuff 5 29th June 2011 20:58
