Old 6th March 2009, 10:19   #31
suren181's Avatar
An A++ to nikkibike. Wonderful fabrication. DIY at it's core and how.
suren181 is offline   Reply With Quote
Old 6th March 2009, 14:51   #32
nikkibike's Avatar
Originally Posted by sun View Post
Can any model of K & N Filter suit the 2.2 VTT ? If so what model. Please pardon my ignorance, what is to be expected after this filter is filtted on a VTT safari ?
Go get a universal conical filter and slap it. You will feel the differnace in 2.2 VTT
Thanks Suren. Well its fabricated with 18 gauge and 16 guage aluminuim sheet. 12 thick aluminium flanges are used as end plates.
Rest is basic machining and sheet metal fabrications!
nikkibike is offline   Reply With Quote
Old 7th March 2009, 01:35   #33
razor4077's Avatar
Thanked: 258 Times
Excellent work nikkibike. Very clean, very professional. Kudos
razor4077 is offline   Reply With Quote
Old 7th March 2009, 02:31   #34
rider60's Avatar
Thanked: 47 Times
awesome mate nikki i had this in mind for my accent viva too but i chose to buy the Green cotton storm kit instead back then as i lacked time and Good Help(lathe guys), well if my fiber glass kit should go kaput i will definitely resort to this.
this is good inspiration, and i am kind of a DIY guy too so lets see what the future holds
three cheers for the the JOB and AWESOME finish!!!
rider60 is offline   Reply With Quote
Old 7th March 2009, 17:01   #35
sun
sun's Avatar
Thanked: 7 Times
Can you explain what difference is to be expected ?
sun is offline   Reply With Quote
Old 10th March 2009, 11:31   #36
nikkibike's Avatar
Default C He E R S!
Ooops!! Was offline for few days. Many thanks for your kind words and appreciation guys.
Now am very happy that it works neatly as intended. Drove the car in all possible ways and the differnace felt is great.
Great plan dude. Ensure that you are right with the basic mathematics tho! This was a challenging job for me
Well... a bit of low end power and considerable differnace in the mid range delivery! U got me?
Old 10th March 2009, 11:36   #37
greenhorn's Avatar
Thanked: 1,516 Times
just curious , metal enclosure means that it will conduct heat right ?
Will that be a problem? I mean, its is supposed to be a Cold air intake.
Would some thermal insulation help ?
Old 10th March 2009, 11:42   #38
Jaggu's Avatar
Thanked: 8,684 Times
Has come out really well, great workmanship and install!
Old 10th March 2009, 12:46   #39
nikkibike's Avatar
This factor was major and considered during the planning stage. The reason to select aluminium is to tackle the heat around the casing. Aluminium will cool off quickly by the running air. Thermal insulation and much more stuffs would have been required incase if it was made in steel, which will hold heat for a long time!!
Have checked the heat on casing after a long / short run. Everything fine as of now.
Old 10th March 2009, 12:54   #40
Thanked: 1,642 Times
The OE filter on this truck is a huge black steel canister (about twice the size of the ACKNE). Aluminium will cool off faster, plus this has the advantage of cold air coming in from the grille.
Therefore this can only be better than OE.
Steeroid is offline   Reply With Quote
Old 22nd July 2010, 10:34   #41
mayankk's Avatar
Thanked: 3,559 Times
Dont know if anyone will respond here,considering its more than a year old.
However,lets have a crack.
Would it be possible to get a length of heat resistant ABS pie, cap it off with aluminium, and produce a similar DIY for an air filter enclosure?
mayankk is offline   Reply With Quote
Subwoofer Enclosure - Readymade vs Custom Raja In-Car Entertainment 13 4th December 2010 11:35
Custom enclosure for pio 307 D-4 overdose14 In-Car Entertainment 14 16th July 2007 23:54
aluminium sports spoiler a4_attitude Modifications & Accessories 5 20th May 2006 01:49
Aluminium Spoiler or Body Colored Spoiler v.tec Shifting gears 3 9th March 2006 13:24
Aluminium Spoiler for Lancer nikibusa Modifications & Accessories 3 28th July 2005 11:51
