Closed Thread
Old 20th March 2009, 14:44   #1
Proxima's Avatar
Default The new Ikon's headlights - upgrade options?
The headlights of the new Ikon are *horrible*. Cant see a thing if there is even a little bit of light coming from cars on the opposite side. Focusing and spread seem OK because if there is no other light, the road is lit up well.
Any idea how this can be bettered without spending too much and voiding warranty? I am sure the others (Condor, Dieseled, S_budhiraj etc) will be interested too.
Please let me know if I need to check out which type of headlights the Ikon uses (H!, H2, H3 etc.)
Need urgent help as I am not confident of taking her ling distance with the existing setup! I just don't feel safe doing so.
Proxima is offline
Old 20th March 2009, 14:56   #2
condor's Avatar
Thanked: 4,348 Times
@Proxima, something for us to work out ...
I am actually happy with my headlights. So before we go further, can you check & let us know what is the setting of your head-light leveller switch ? This switch is at the left of the steering column, just below the console & faces you.
condor is online now
Old 20th March 2009, 14:56   #3
nitrous's Avatar
Thanked: 282 Times
I would blame the puny 55/60 stock headlights.
Switch to 100/90 philips rallye with the wiring harness and stronger holders.
I was happy with this setup even on the highways.
nitrous is offline
Old 20th March 2009, 15:07   #4
Proxima's Avatar
Condor, I tried all that, it goes up and down but the power is the same.
That wont void the warranty right? How much will it set me back by?
Proxima is offline
Old 20th March 2009, 15:08   #5
Dieseled's Avatar
Proxima, Condor is right check the leveller, I'm happy too with the headlamps, are u keeping the fog lights on ? One thing I've noticed is that fog lamps are brighter than the headlamps, so Ikeep the fog lamps on all the time.
Dieseled is offline
Old 20th March 2009, 15:24   #6
Proxima's Avatar
Okay, will re-check the leveler today. Or maybe my eyes need attention. lol
Proxima is offline
Old 20th March 2009, 19:26   #7
condor's Avatar
Proxima : That wont void the warranty right? How much will it set me back by?
Try to get it done by the dealer itself ! Less than 1k unless you go for the costlier lamps.
Dieseled : One thing I've noticed is that fog lamps are brighter than the headlamps, so I keep the fog lamps on all the time.
The fog lamps (only) appear bright because of the shorter throw. But yes, the fog lamps help hugely. Between the headlamps & the fog-lamps, the illumination is more than manageable.
Old 20th March 2009, 19:35   #8
Proxima's Avatar
Dont think the dealer will do it. Is there some 50/60W bulb that is better? That wont need a cutout right?
Proxima is offline
Old 20th March 2009, 19:52   #9
condor's Avatar
@Proxima, any 55/60W bulb will not need a cut-out. You can try for Philips Vision Plus etc, as discussed in other threads.Give the dealer a try, During your servicing. I have done that (not Ford), and it was a quick job that helped both. No objections, no complaints, no running around for spares.
Old 20th March 2009, 20:49   #10
audiophile's Avatar
Thanked: 23 Times
I would suggest an upgrade to 90/100 with a proper harness and ceramic holders, Upgraded the same on my ikon and it much better that the stock lights.
audiophile is offline
Old 20th March 2009, 22:45   #11
Proxima's Avatar
Thanks guys. I'll give it a shot.
Proxima is offline
Old 21st March 2009, 16:31   #12
ilangop's Avatar
Thanked: 578 Times
Yaa man, I did the same for my dad's car. The difference is too good both for city driving and for highways. What I did was more of a DIY job. I went for a fully furnished relay + wiring harness where you job is to just to replace the bulbs and find a place to bolt the relay. "No need to cut any wire". The harness comes with 2 ceramic holders, wires fully closed inside a black coloured corrugated hose, and also an adaptor which you can plug into the exisiting holder.
For DIY guys, here is what you have to do.
1. Open the bonnet and remove the front grill by pulling up the plastic clips found near the ends of the grill.
2. Remove the screws (I remember like 2 per lamp) fastening the lamps to the vehicle.
3. First pull out the tapered end about 2 inches forward, and slide the assembly sidewards.
4. Remove the black coloured connector from the lamp and detach the lamp completely from the vehicle.
5. On the rearside of the assembly, locate the locks provided and un-do them to remove the trapezoidal cover to get access to the bulb.
6. Remove and replace the bulbs.
7. Now that the now holder has to be routed inside, make a small cut on the projection where the back-cover fits on to the lamp assembly to let in the thicker wires of the new harness to pass inside the lamp housing.
8. Connect the holder, put back the cover and make sure to check that the cover does not bite the wires while fully closed. Also make sure that the cut you had made is just the right size. A bigger passage would give way for dust to enter the housing.
9. Find a place some where near the lamps to connect the ground wire.
10. Repeat the same procedure on the other lamp also and revrse the ablve steps to put back the lamps and finish off the job.
11. In my case I had connected the relay on a plastic projection on the firewall and fastened it with a nut.
ilangop is offline
Old 21st March 2009, 23:48   #13
2theMax's Avatar
Any kinda wiring tampering will void Warranty.Source MPL Service.
2theMax is offline
Old 21st March 2009, 23:53   #14
theMAG's Avatar
Thanked: 1,476 Times
Note from Team-BHP support: Topic already exists. Continue further discussion there. Thread closed.
theMAG is offline
Closed Thread
Upgrade options for Scorpio's suspension ? forbhaskarm Modifications & Accessories 40 14th August 2014 12:29
Baleno Brake upgrade options crazydiablo Modifications & Accessories 27 19th August 2011 01:24
Dealer quoting astronomical amount for technically correct IKON headlights!!. dhanushs Technical Stuff 32 10th January 2011 15:01
ICE Upgrade options for my Ikon sanju.sreekumar In-Car Entertainment 4 18th December 2008 16:11
