Old 20th March 2009, 16:13   #1
v&v
v&v's Avatar
Thanked: 1,099 Times
Question Safari owners : what engine oil & additive used ?
hi,
I am curious to know, whats the best engine oil options are available and does the service center give the customer the option to select the engine oil?
Also any engine oil addition needs to be used as the service cycle is of 15000 kms?
Also about the service schedule i.e. 15000 kms, will the oil be viscous enough to hold such schedule?
vnv
v&v is offline   Reply With Quote
Old 20th March 2009, 16:29   #2
jaysmokesleaves's Avatar
Thanked: 1,258 Times
You are free to change the engine oil outside using the recommended oils in the manual if you do not want to change oil at the TASS. I did an oil change at 7500 on my own outside of the TASS. I had already bought the oil from an authorised outlet as per the manual recommendation, but the TASS refused to put it stating warranty issues. So I changed the oil outside. Had no issues.
Oil change again at 15500. and now due for change at 28000kms. Inspite of hard driving there has been no need for topup.
jaysmokesleaves is offline   Reply With Quote
Old 20th March 2009, 16:43   #3
Thanked: 2,470 Times
Standard oil used is Castrol by A.S.C all over. Use the Bardhal additive along with it.
I maintain oil changes for our 3L Dicor every 5000 kms.
Old 20th March 2009, 16:50   #4
Your oil change interval is not in tune with your signature.
Old 20th March 2009, 16:53   #5
Nice one.
I maintain a 5000 kms oil change for all our cars at home. Its better to have cars with fresh oil , enhances lubrication of moving parts.
Even lifespan of the engine increases.
2.05 lacs kms on my M-800 is a standing testimony
My VW Bug is as good as a daily runner, anytime, anywhere.
Old 20th March 2009, 17:01   #6
v&v
v&v's Avatar
hi pawan,
why the tatas mention 15k service schedule, i think the now the engine oils should be evolved enough to handle the given schedule.
Is this a pre-set mindset to change afer every 5k.
Has any one maintained the tata service schedule and faced some related problem ?
vnv
Old 20th March 2009, 20:52   #7
gd1418's Avatar
Thanked: 656 Times
I've not maintained the service schedule as per the manual for my '98 TCIC 4x4 Safari. I have serviced it at 5000 kms. Earlier I used the Gulf oil then shifted to Mobil Delvac MX and am now currently using Chevron Delo 400.
Ever since Delo is being used, the service schedule has been revised to every 7500 Kms.
Old 20th March 2009, 22:28   #8
greenhorn's Avatar
Thanked: 1,519 Times
for the 2.2VTT , the owners manual says API CH4 or better. if its castrol, it better be GTX. But TASC's are not averse to using the cheaper stuff as happened here
greenhorn is online now   Reply With Quote
Old 20th March 2009, 22:55   #9
adc
adc's Avatar
Thanked: 2,103 Times
LX VTT 2.2 Castrol GTX around 7k - may be change every 5k after 30k on odo but will be on mineral oil - all these based just on some preconcieved ideas.
adc is offline   Reply With Quote
Old 16th April 2010, 20:01   #10
HIGHNOON's Avatar
Thanked: 56 Times
Hi Pavan,
How did your rear seat job came thru ? can you please send me the link / photographs.
I want to have some front facing seats made for the kids in the back.
regards,
Kedar Nadkarni
HIGHNOON is offline   Reply With Quote
Old 16th April 2010, 20:09   #11
HIGHNOON's Avatar
Thanked: 56 Times
BTW What is the oil grade specified for TCIC safari , and any idea where i may get hold of a service manual for a 2004 safari TCIC?
i bought safari yesterday but the previous owner had lost the manual.
Old 16th April 2010, 20:46   #12
mercedised's Avatar
Thanked: 177 Times
Oh!! many congrats to you. Do put up a review and some pictures of your car.
The specified grade is 20W50 and oil capacity is 7.5 ltrs.
mercedised is online now   Reply With Quote
Old 16th April 2010, 21:06   #13
HIGHNOON's Avatar
Thanked: 56 Times
Thanks buddy !
Btw i wanted the API specifications of the oil . Is it castrol GTD they specified ?
A CF4 is ok ? or CG4 Rated one is required ?
Old 27th April 2010, 09:17   #14
HIGHNOON's Avatar
Thanked: 56 Times
Exclamation
Hi Greenhorn !
Any ideas what grade / API engine oil is specified for safari TC And what interval.
Also any clue how to get hold of a user manual. I hae recently bought a used one and the manual is missing. Is it uploaded somewhere BAC ?
Kind regds,
kedar
Old 27th April 2010, 09:21   #15
HIGHNOON's Avatar
Thanked: 56 Times
Hi Buddy!
I bought an air filter for the TC safari yesterday . Made by Vtech its different than the stock as its got a mesh rather than the perforated metal sheet.
Its costing less than the stock and logically should admit more air to the motor.
Anyone safely tried this before ?
Engine Oil Additive bill1182 Technical Stuff 76 16th April 2018 20:22
Is used Safari worth a look? - Safari owners please comment. Makesh SUVs, MUVs & 4x4s 2 22nd April 2010 16:37
New to Bangalore Need STP Engine Oil Additive passion4cars Technical Stuff 7 17th March 2008 20:54
