Old 9th April 2009, 16:20   #166
cmiuc's Avatar
Thanked: 13 Times
Originally Posted by maverick030581 View Post
Hi Rajeev,
I have a couple of questions if you wouldn't mind answering them.
Satya is running 15% higher boost with no issues for 25000kms.
The beauty of greddy boost controllers are swith it 'ON' when it is required ONLY.
Has Satya's car been running for 25k kms with the bosst controller on all the time or sometimes when required?
IIRC Satya's car with the intercooler upgrade & boost controller did a 7.35 sec 0-100 run tested by dynolicious sometime ago, even with a small error it is still bloody quick. With the addition of RD ECU, how much more gains are you aiming for?
yes , always used switched on in highways & not in the city, & some times in team-bhp quick meets on weekends.
when we tested 0-100 run tested by dynolicious , intercooler was not installed , later we installed the big intercooler , then normal engine oil
supposed to be replaced with shell synthetic oil ,
so didn't have a time to test after that in b/w replaced k&n filter instead of green cotton filter & shell synthetic oil .
yet to test now with with new setup of the big intercooler upgrade ,boost controller running 27% higher boost since there will be a loss of 2 psi after installed intercooler , petes stage 2 , k&n filter & shell synthetic oil
even in track i was switched off the boost controller on the MMST long loop when tested on the Vbox. since not tested with 27% higher boost .
cmiuc is offline   Reply With Quote
Old 9th April 2009, 17:27   #167
khan_sultan's Avatar
Thanked: 3,872 Times
I have seen Rajeev's & Satya's elantra on a couple of drives (never sat/driven them) and I must say that they are smooth and they do seem fast. I don't know what mods they have inside or what they run, but they do burn the roads -- very very silently.
rajeev, you have to take me out for a spin in your elantra one of these days man.
khan_sultan is offline   Reply With Quote
Old 9th April 2009, 18:00   #168
Thanks for the update Satya & Rajeev.
After the dynolicious run, it is apparent there have been plenty of changes. Are you guys planning to do any more 0-100 runs soon?
PS- I may be out of work soon as I am hooked on this thread all day
One more question - Why the switch from Green to K&N? Is the difference substantial enough to warrant the change?
maverick030581 is offline   Reply With Quote
Old 9th April 2009, 20:59   #169
IronWolf's Avatar
Thanked: 36 Times
Rajeev - lovely commitment to give your Elantra an excellent 0-200 timing.
I second Khan saab. I would love to take a ride in your Elantra.
Also the 2 separate sets of discussions kept me glued to my seat.
All in all - This is one fun thread. I have voted it as excellent.
IronWolf is offline   Reply With Quote
Old 10th April 2009, 10:49   #170
brraj's Avatar
Thanked: 354 Times
Thanks khan bhai & IronWolf, you can join us in one of our night drives.
Test reports will be up shortly. I am waiting for the tuning to be completed.
same here too.
Not much of a difference, in fact in many of our drives we all travel at same speeds and this is while speeding, ofcourse this is not with boost ctrl ON.
brraj is offline   Reply With Quote
Old 13th April 2009, 11:09   #171
brraj's Avatar
Thanked: 354 Times
Installed and tested RD Ecu for diesels
Replaced Green cotton with mushroom HKS air filter. We are working to put in proper place so that we get maximum cold air.
Name:  HKS Filter.JPG
Tested using V-box to get the accurate readings.
and now Timings
9.9 sec for 0-100 and i am impressed. This readings are with petes stage II and RD ecu.
Turbo lag is almost reduced. while testing its wheel spinning in 2nd gear which i never experienced in an Elantra till date.
Now its boring to drive a peted elantra as i am already in love with RDs P2 settings.
And when requested for AFR readings karthik told that its not needed for diesels as it will always runs rich and yes will not be installing AFR meter.
It was a bit smoking while in P2 mode and after installing HKS air filter it was drastically reduced.
I really have to thank Rd karthik & his team for this product and for patiently listening and answering to all of my question which was in pages.
Old 13th April 2009, 11:13   #172
Jomz's Avatar
Thanked: 289 Times
Diesels are supposed to be always lean. Did you mean lean in the above post???
Jomz is offline   Reply With Quote
Old 13th April 2009, 11:34   #173
brraj's Avatar
Thanked: 354 Times
My mistake . Jomz you are right its always lean.
Old 13th April 2009, 12:15   #174
Err. I'm a li'l confused. As per ACI, the stock Elantra without any add-ons was supposed to do 0-100 in 11.62 secs. From the figure, it shows an 11.68 sec run for the Elantra with Pete's stage II.
What boost are you running?
Old 13th April 2009, 13:12   #175
brraj's Avatar
Thanked: 354 Times
We ignored a small boost leak which was there, its time to fix it.
Old 13th April 2009, 17:46   #176
IronWolf's Avatar
Thanked: 36 Times
Nice timings. What was 0-200 ?
Spinning on shift to 2nd? Quite impressive.
Something tells me we are going to be discussing N2O shortly here.
Old 14th April 2009, 11:45   #177
brraj's Avatar
Thanked: 354 Times
We couldn't test for 0-200 in city, may be later.
You were right about N20 as even i was thinking to install it but when many tuners told me to be ready to blow the engine incase, i backed off. As far as i know no one has tried installing NOS for diesel engines in india.
Old 14th April 2009, 11:56   #178
Awaiting Email Confirmation
Thanked: 20 Times
In diesels, which is better for EGTs, running lean or, running rich?
Old 14th April 2009, 19:07   #179
diven_b's Avatar
are you sure about your 9.9 sec time.satge 1 remapped lauras do a 0-100 in about 9 sec
diven_b is offline   Reply With Quote
Old 14th April 2009, 19:48   #180
Jomz's Avatar
Thanked: 289 Times
Diesel has to be lean. You cannot run diesel rich unless you want heavy smoke from the tailpipe and poor throttle response. it is worth a try at wide open throttle... but still you loose the inherent advantage of high mileage by running it rich
What is EGT??
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
elantra crdi gtd vs elantra crdi (leather pack) super_700a Sedans 3 10th August 2006 07:38
Suggest me, Elantra CRDi or Elantra GLS hsmraj Sedans 16 11th April 2006 02:28
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
