Old 14th April 2009, 23:52   #196
ashish22's Avatar
Thanked: 43 Times
Originally Posted by brraj
9.9 sec for 0-100 and i am impressed. This readings are with petes stage II and RD ecu.
i think there's a slight confusion. Is he saying he used them both simultaneously or he sued them separately?
ashish22 is online now   Reply With Quote
Old 15th April 2009, 00:57   #197
ssjr0498's Avatar
Thanked: 118 Times
I am confused myself now.. hahaha!!! I might be wrong then!!
can't find a hole to dig and bury myself lol! Looks like its only the rd from the graph... but god knows!!
Guys, can someone please clear this doubt!!
Shrey
ssjr0498 is offline   Reply With Quote
Old 15th April 2009, 06:24   #198
Jomz's Avatar
Thanked: 289 Times
Originally Posted by rippergeo View Post
I dont get it.
They always run lean OR
they are best when they run lean OR
They should run lean but the ratio can be played around with.
THey always run lean but the fuel/air ratio is played around with.
Here since a diesel doesn not have throttle, there is no driver control of airflow (gasoline has a throttle - so the airflow could be changed by the driver using a throttle). Gasoline engines usually run stoichometric (neither rich nor lean). and driver varies the air/cylinder to increase power.
Diesel at a constant rpm ,Airflow is fixed to the engine (assume an NA engine for simplicity). So if to vary the power from idle to full throttle the injection quantity is increased. Since more fuel cannot be injected than what could be burned by the air in the cylinder at that rpm, at max load the diesel engine runs stoichometric. At all other conditions it remains lean.
I don't have any experiance with tuning boxes and I don't know how they work, But i believe they make the extemely lean mixture a little less leaner. But they never make is rich- making rich only ends up in smoke.
For example, the Cummins ISB in our labs rated at 1100Nm
at 20% load lambda =3.206
at 40% load lambda =2.4337
at 60% load lambda =2.043
Note that it still remains around at 2 times air for the amount of fuel injected.
Hope this helps
Sameel sameel sameel.
I thought you left this after pointing out a blunder ?? You back agin withyour MAPS??
Let me try again to get my question to you. Answer only to the part in quotes and capitals
"CAN THE DURATION INCREASE AS DONE BY THE PETES AND THE RAIL PRESSURE INCREASE BE DONE ON A STOCK BOSCH ECU??"
I know it is possible with an ETK enabled ECU and INCA. I want to know on a stock ECU.
"IF NOT DO YOU THINK PETES IS BETTER THAN THE STOCK BOSCH ECU??"
Well your call .. and Don't go away . I'd like an answer.
Note from the Team-BHP Support Team : Please use the "edit" button if posting within 15 minutes of the first post, instead of creating another back-to-back post
Also use "Multi Quote" option for quoting Multiple posts.
Jomz is offline   Reply With Quote
Old 15th April 2009, 10:32   #199
Psycho's Avatar
Thanked: 95 Times
Not true most ECU's cycle between rich and lean to try and maintain stoic under constant load conditions but will go rich the moment the throttle is depressed or WOT situations. They typically maintain between 12.8 - 15.1 AFR depending on the conditions.
Old 15th April 2009, 11:32   #200
Shan2nu's Avatar
Thanked: 87 Times
firstly the ohc will not take 11 secs to hit the ton, it is much lesser than that.
That depends on which OHC he owns. Only the vtec does it in 9.9secs. The 1.5 is much slower, taking around 12 secs to 100.
Sometimes i wonder, how in the world does a 6bhp gain translate to almost 2 secs diff to the ton (eveyrhting else being equal). Time to get a stock vtec dyno'd!!!
Shan2nu
Old 15th April 2009, 11:58   #201
brraj's Avatar
Thanked: 351 Times
well with the latest vbox timings out for the boosted elantra, i really want to ask whether is it really worth the effort.
It is still not boosted, Test were done with petes & RD ecus only.
Every mod i have done to it have showed results of atleast a sec less for 0-100 timings and its worthit atleast for me.
I have seen many people looking at just 0-100 timings but main point you are missing here is
How is the braking?
How is the handling?
How is the highway manners when you are above 180kmph.
Till date i have never seen a car under 11lakhs which can handle & brake like an elantra and ofcourse i am talking about stock.
In elantra you feel planted. Believe me after satya sat in my car he just sold 3 of his car and bought one.
Power is waste if you cant handle it.
I guess its time for you to drive one and feel it.
To get the max out of both worlds Elantra CRDI it is.
It was with both Petes stage II and RD ecu.
brraj is offline   Reply With Quote
Old 15th April 2009, 12:15   #202
ashish22's Avatar
Thanked: 43 Times
thanks for the enlightenment brraj. So how much improvement are you expecting after boost and when will the boost kick in and what would be the boost band??
I strongly agree with what you've written. Its not only about power but safety, handling and solid feel as well. And yes time for me to really TD one.
Old 15th April 2009, 12:18   #203
[quote=brraj;1260995]It is still not boosted, Test were done with petes & RD ecus only.
Oh, now I get why the figures with Pete's only were slower than a stock Elantra, probably because of the boost drop due to bigger intercooler and due to the boost leak you mentioned. With a boost controller to compensate for the loss due to the intercooler upgrade, the numbers should drop quite a bit. Good job Rajeev and kudos to you for actually putting the numbers on the forum. Very helpful mate. Cheers.
How is the braking?
Spot on. Could not agree more
Edit : ashish, your TD is overdue mate, drive one and get a brother for your RS
maverick030581 is offline   Reply With Quote
Old 15th April 2009, 12:41   #204
kb100's Avatar
How is the braking?
Extremely well said! BRAVO!
By when are you going planning to dyno the boosted runs?
kb100 is offline   Reply With Quote
Old 15th April 2009, 13:02   #205
brraj's Avatar
Thanked: 351 Times
If it shows 8.5 sec for 0-100, i am happy.
Daily drive & highway - i want the boost to kick in only after 100kmph.
T-bhp drives - I want the boost to kick in at 50kmph.
R&D is going on as to how much boost can our cars take? After final tuning will let you know.
pipe has been fixed back so now there is no boost leak.
I am yet to fix Intercooler for my elantra and the job should be completed within 2weeks, lets see.
Timings remains same.
Only after fitting inter cooler.
Old 15th April 2009, 13:43   #206
kb100's Avatar
Oh - I was under the impression that was already done!
Any news on the brake front?
Old 15th April 2009, 13:49   #207
nnandi's Avatar
Default carry on bro!
Raj, 9.9s-->100kmph is already too hot to handle. At 8.5, it might start flying. Any thoughts on putting on a heavier driver (like me) to keep it rooted and not develop wings?
Well, I think I now need to consider your offer of joining the tbbhp night meets, seeing your red beast fly by at that speed would be sheer bliss, even better if I have the steering wheel in my hands!
OT: Are you keeping a tag on the cost of all mods? That will make people like us know what kind of savings we need to do for the future of our babies!
nnandi is offline   Reply With Quote
Old 15th April 2009, 14:08   #208
brraj's Avatar
Thanked: 351 Times
Its satyas car which had installed intercooler, am just fixing it now.
Brakes feels inadequate for a boosted elantra as tested in satyas car.
I even had plans to fit EBC brake pads but i got reviews that it works well but it has to heat up to show its performance and if there is a light scratch or crack in the rotors the pads fade very soon.
Suggestions are welcome.
You will be in the driver seat for sure when we meet.
Cost of products is already mentioned in first page of this thread and keep 1-3k for installing those.
Old 15th April 2009, 18:50   #209
sameel's Avatar
@ jomz ah the simple and straight question
YES its possible. simple and straight answer hope you are happy.
and yes its not simple. i cant let it out here. llol. but yes thadu has got a simple way of doing it. hehe. only back up will be a prob. i know how to back up but hey its his call. llol.
so stop picking up on my posts. will ya? llol.
hope doubts are clarified.
cheers !
sameel is offline   Reply With Quote
Old 15th April 2009, 19:12   #210
Jomz's Avatar
Thanked: 289 Times
cheers !
It is not picking dude. It is asking again and again till you somehow understand the question and give a satisfactory answer. You explain stuff which is all over the place and does answer everything (even incriminating you) but not answering the question.
So as of now tadu knows how to reflash a STOCK ECU.. right?? As usual you cannot let out stuff :-). Will ask him how.
tadu are you listening??
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
elantra crdi gtd vs elantra crdi (leather pack) super_700a Sedans 3 10th August 2006 07:38
Suggest me, Elantra CRDi or Elantra GLS hsmraj Sedans 16 11th April 2006 02:28
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
