Old 25th March 2009, 12:33   #31
Awaiting Email Confirmation
Thanked: 20 Times
Originally Posted by brraj View Post
Even we did a bombay trip just for a drive.
when you are driving cars that rival air travel speeds, then driving to bombay is "just" a drive. Normal people would need weeks of planning
Congrats on the timings.
What did you guys do, after removing the catcon? how did you replace that missing length?
Old 25th March 2009, 13:07   #32
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Fortunately for some people like me these married uncles dont need any notice more than a few hrs to make such long trip plans. They love living life on the edge most of the times .
The cat con very much exists, its only for show though. Empty on the inside .
Old 25th March 2009, 13:07   #33
Haha,couldn't put it better myself..You guys are insane Raj
But I may become like that myself now (not the married part though) that the pete's & green filter is going in my Elantra today evening. May just drop in on you guys
BTW my two cents is, be careful if you can't get a backup of the existing map.Sounds very risky in that case.
Man I love this thread already!
maverick030581 is offline   Reply With Quote
Old 25th March 2009, 13:11   #34
rdkarthik's Avatar
Thanked: 11 Times
Originally Posted by sameel View Post
i also support the RD piggybac ECU its good stuff. but its written mainly for the EDC16C39 units of swift CRDi i presume.
i suspect that the RD unit is universal type. will go with any CRdi unit!
irrespective of the ECU generation..
The RD units are universal. Installs onto any CRDI system.
Originally Posted by mclaren1885 View Post
Thats the next step, actually its been a long wait for the ECU's to be launched officially. Infact, Rajiv was one of the first ones to volunteer to test the ECU back in its nascent stage, but somehow it could never see the light of the day.
As a policy, we do development and testing only on our internal cars (even if it means delays or buying cars for that purpose ), hence the delay
rdkarthik is offline   Reply With Quote
Old 25th March 2009, 13:53   #35
vikram_d's Avatar
Thanked: 940 Times
Karthik, a small doubt. Can your diesel ECU control an electric servo actuated VGT?
vikram_d is online now   Reply With Quote
Old 25th March 2009, 14:26   #36
Thanked: 20 Times
Oh! OK, thought as much, I was trying to retain the catcon for use later if necessary. will need a full turboback system designed for that. So the wait continues for me.
If that doesnt work out, I'll have to fallback on your cheap and best method
Catcon in a diesel doesnt really do much does it? I mean, it is not as essential in emissions control as it is in petrols, right?
Did you guys do anything about the muffler?
Any plans on blocking off the Exhaust gas recirculation?
@karthik- has testing been completed for the swift? Is the ECU available to buy?
Old 25th March 2009, 14:41   #37
rdkarthik's Avatar
Thanked: 11 Times
As a standard option , no.. But if it is for your custom needs, then yes.
Old 25th March 2009, 15:32   #38
brraj's Avatar
Thanked: 354 Times
Does this mean that we dont require boost controllers for VGT cars like getz crdi to increase the boost if we are using your ECU? or am i wrong here.
brraj is offline   Reply With Quote
Old 25th March 2009, 15:48   #39
vikram_d's Avatar
Thanked: 940 Times
Yes that is what it means. The boost can be controlled by the ECU itself.
Old 25th March 2009, 15:51   #40
Psycho's Avatar
Thanked: 95 Times
Sorry that is wrong the ECU can only control the VGT function for the actuator and not the boost. The VGT only help get to the boost quicker by adjusting the vances inside the turbo. You would still need a boost controller for VGT enabled cars.
Old 25th March 2009, 15:56   #41
vikram_d's Avatar
Thanked: 940 Times
Yes but you can also control boost by keeping the vane angle small even at high RPM. If you don't increase the vane angle then there will be little boost.
How does Variable Turbine Geometry work?
Old 25th March 2009, 16:15   #42
sameel's Avatar
guys!! the main advantage of a VGT is that is eliminates the need for a wastegate! hence boost controllers are typically useless for VGT
do refer the WIKI link on the VGT..
Variable geometry turbocharger - Wikipedia, the free encyclopedia
the ECU does that already. we can control it through the ECU ( no need to fool the waste gate giving it fake input signal..)
yeah will see what turns out in banglore! will bring along my potable disk.
@ karthik. thats great then it should be possible to have more than one map reloaded into the piggybac right. 3-4 mods should be possible. ( economy - city - aggressive and custom) and ok off the record if you want the EDC16 and EDC17 documents i have them alright
well the 50-60 % power gain is no myth! its possible. the internals mainly the turbo is to be taken care of. the VGT units of both Sonata transform and the Captiva enable a stock tune of 150PS( a simlple tuning box will give these engines 170PS+!!) and yes these have EDC16 units which helps them more or less achieve euro4 or 5 regulations. and yes the exhaust and inlet is different.
but not out of reach of the masses.
heck the stock FGT of the Magnum produces a 30kgm torque and 121ps of power!
and @above guys tried using better oil! it will be enable free revving to an extent the vehicle will definitely become more smooth!
co-ordinate with RD and that would be possible.
and yes RD should be having the resource to back up the stock MAP of the elantra.
and for the FIAT Fanatics i know how to flash them hehe.
its too tedious a process you will mainly need three files.
.idx, .PRm, .bin if these three and a CAN -CARD -XL with a Dianalyser software is available you can flash any fiat ecu!
am currently doing a hyundai VIVA test(meg17.9.12) some gasoline ECU sorry cant let out more details.
just cant wait to get my hands on the R-series engine ECU..
cheers
sameel
sameel is offline   Reply With Quote
Old 25th March 2009, 16:51   #43
brraj's Avatar
Thanked: 354 Times
Originally Posted by Ramsagar View Post
Raj: wanna drive your monster man how about next T-bhp meet?
why don’t you join for the night drive held on 29th.
http://www.team-bhp.com/forum/team-b...-bangy-41.html
Spoke to pawan of Racedynamics, he say it has got four settings
1. Economy Mode
2. Stock Mode
3. Power+
4. Power++
Should be installing it within Saturday .
Old 25th March 2009, 17:35   #44
ashthedivx's Avatar
Thanked: 22 Times
Pardon my limited knowledge, but does it means Elantra is a true performance car which can get atleast 40-50% boost of it original capability just with a Pete Box, A free-flow Air Filter and a Racedynamic ECU ??
Old 25th March 2009, 18:12   #45
Psycho's Avatar
Thanked: 95 Times
You might have to read again am quoting from Wikipedia
"In many configurations, VGTs do not even require a wastegate; however, this depends on whether the fully open position is sufficiently open to allow boost to be controlled to the desired level at all times. Some VGT implementations have been known to over-boost if a wastegate is not fitted."
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
elantra crdi gtd vs elantra crdi (leather pack) super_700a Sedans 3 10th August 2006 07:38
Suggest me, Elantra CRDi or Elantra GLS hsmraj Sedans 16 11th April 2006 02:28
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
