Old 26th March 2009, 15:43   #61
vikram_d's Avatar
Thanked: 936 Times
Originally Posted by Psycho View Post
There is one "basic" mod that has not been discussed as yet and I am quite amused that no one has thought of it yet. (No am not going to answer anyone on this, might be good fun to see the possible list before I let out.)
I think I know what you are talking about. But am not sure though.
Originally Posted by rippergeo View Post
Awww, come on! Good fun for you maybe,not for me- I'm a huge fan of instant gratification.
Weight reduction?
Blocking off the exhaust gas recirculation?
getting rid of the stock muffler?
The elantra already has a CAI as stock, so cant be that!
@prabhuav-LPG, a basic mod?
Originally Posted by brraj View Post
Now this is how GURUS will try to play around with kids like us.
Originally Posted by mclaren1885 View Post
EGR? Better CAI? Clutch? Gearing?
Its called tuners secrets. Almost all tuners talk in the same tongue these days .
May be I can some hints on what I think it is, but then the Madman would kill me in case I am right.
Old 26th March 2009, 15:51   #62
mclaren1885's Avatar
Thanked: 28 Times
Infractions: 0/1 (10)
  • Better Plumbing
  • Better Manifolds
  • Porting Polishing
  • Better Exhaust
1. Satya's car already has better plumbing. Rajiv's car is due for the intercooler installation shortly.
2. We did look around for better manifolds, but none available off the shelf for the CRDi unit. Custom fabrication is too much of a pain.
3. These guys don't want to open the engine at any cost. So it rules out P&P.
4. Better exhaust?
Old 26th March 2009, 16:15   #63
vikram_d's Avatar
Thanked: 936 Times
For this you need to know the right people. Moreover it is not a pain at all.
Old 26th March 2009, 16:38   #64
JayD's Avatar
Thanked: 1,996 Times
Something to do with the BOV or wastegate or something like that??
Old 26th March 2009, 17:14   #65
Awaiting Email Confirmation
Thanked: 19 Times
Please do elaborate! this thread has enough cryptic clues already!
@psycho-
Porting and polishing.. how much can it add? Asking because I dont know.
better plumbing- do you mean straightening out as much as possible the routes taken by air? or increasing diameter of tubes, or both?
better exhaust will help-but aftermarket exhausts for diesels, not easy to come by.
Old 26th March 2009, 17:23   #66
vikram_d's Avatar
Thanked: 936 Times
Well I finally found a source who can make even single piece cast turbo manifolds. So now nothing is out of reach.
Old 26th March 2009, 17:39   #67
brraj's Avatar
Thanked: 351 Times
Love the CAI of sonata embera
courtesy carwale.com
brraj is offline   Reply With Quote
Old 30th March 2009, 13:21   #68
Psycho's Avatar
Thanked: 95 Times
at least 10%
Both
What I mainly meant was the downpipe from the turbo.
Old 30th March 2009, 18:37   #69
brraj's Avatar
Thanked: 351 Times
Greddy Profec B Spec
Basic use of boost controllers is to change the waste gate boost response depending upon the setting. It has digital display to monitor boost pressure in real time and also has PEAK boost feature will allow the user to check the highest boost recorded.
More info on
Greddy - Founded and Driven by Racers
Basically boost controller should be tuned with the ECU to get the best results and most important point to note is to match the Air-Fuel ratio so planning to install AFR meter as well.
One important feature I like in this is we can get power with just a push of a button and switch off when not required.
Most people think that elantra has TCS feature and will not wheel spin when launched hard! you are wrong. It wheel spins if hard launched, may be i have to complain hyundai . If the boost is ON it is more.
Brakes feel inadequate if driven with boost ON.
Regarding the fuel efficiency when the boost is ON say at around 21psi it gives -2kmpl, of course it also depends upon the boost set.
I usually switch it ON when overtaking powerful cars, which are greater than 150bhp, and turbo lag is almost nil when boost in set to 21psi.
If you are planning to install one, make a note of these points.
- Have to install Intercooler before going for boost upgrade to keep the engine cool.
- Use turbo timers if you donít have much of patience to wait for a minute to switch off.
- Use synthetic oil only for the engine and is very much recommended.
- Use it when required only as more the power more the strain to the engine.
Experts can add to the points.
Shortly a video will be uploaded which shows the difference between a peted elantra v/s boosted elantra.
Old 30th March 2009, 19:22   #70
Psycho's Avatar
Thanked: 95 Times
Small correction AFR meter is used to monitor AF ratio's and the ECU to tune the same.
Old 31st March 2009, 12:33   #71
Veelubai's Avatar
Thanked: 23 Times
Strictly OT here: Can any Elantra owner using Hids or better bulbs share their experience here.Hows the light focus and spread of Hids with the stock headlight.Iam planning to use Hids in low beam ad better[100/90] bulbs in high beam. BTW is H1 low beam and H7 high beam or is it the other way? really confused here!!!
Veelubai is offline   Reply With Quote
Old 31st March 2009, 12:55   #72
brraj's Avatar
Thanked: 351 Times
True.
Prabhuav is using HID in low beam and 100/90 bulbs in high beam, so lets wait for his writeup.
H1 : High Beam
H7 : Low Beam
Old 1st April 2009, 00:23   #73
Thanked: 28 Times
For everyone's info: Hyundai engines are not mod friendly in terms of porting & polishing of heads. It was advised not to touch the head.
Vikram: Not everyone is as lucky as you.
Rajiv, I don't think all that will be necessary. I have a more accurate way of finding out the performance gains. More on it when we meet up next weekend
Old 1st April 2009, 00:34   #74
v1p3r's Avatar
Thanked: 26 Times
Actually, I was told the exact opposite by a very well known tuner who is also on this forum.
Old 1st April 2009, 01:20   #75
Thanked: 28 Times
Fortunately for us, this info comes from highly qualified tech people from Hyundai and we were advised never to open that head for mechanical engine mods.
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
elantra crdi gtd vs elantra crdi (leather pack) super_700a Sedans 3 10th August 2006 07:38
Suggest me, Elantra CRDi or Elantra GLS hsmraj Sedans 16 11th April 2006 02:28
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
