Old 10th October 2009, 00:23   #91
Jaggu's Avatar
Thanked: 8,692 Times
IIRC it started off at high revs few months back, now i think it has become a bit regular. I think rings and pistons needs to be checked then the head gasket. Get a garage which deals with Govt Of Karnataka, they will have very good experts with this engine.
Old 10th October 2009, 09:14   #92
memo45_m's Avatar
Thanked: 61 Times
As far as i know the best Gypsy mech who has delt wil all sotrs of gypsy's in Bangalore is Nagraj from TeamCartwheels, his shop is filled with all sort of ones from scrap to fully prepped rally gypsy's, he is avilable on 9845275036, just tell him you got his info from Sanjay or Monish from RACE dynamics, he will be all the more happy to help. Hope this help's
memo45_m is offline   Reply With Quote
Old 10th October 2009, 10:27   #93
Jaggu's Avatar
Memo this gypsy runs on Isuzu motor, he has expertise with that?
And I think Dwarak has already started with work
Old 10th October 2009, 12:26   #94
siddartha's Avatar
Thanked: 24 Times
dwarak, how many kms have u done after the engine swap? wasnt the compression test done before/ after you bought the engine?
siddartha is offline   Reply With Quote
Old 10th October 2009, 14:42   #95
Thanked: 226 Times
Siddu,
I have given the gypsy to Dale Hunter , referred by Rajachu. He has done the compression check and electronic distributer coil. He is saying there is no problem with the compression. Smoke is drastically reduced. Misfiring has stopped.
I have to see the machine on monday to cofirm.
Hopefully no issues with the engine.
Dwarak
Originally Posted by MM440 View Post
Hey Dwarak Mamu,
1>This offer is only for you.
2> How about you and I get the old lady's heart stripped to bits.I will guide and give gyan while you do all the work
3>Seriously though that is an option worth contemplating.We could always call experienced people for guidance .
4> I think a compression test (wet/dry) will tell us which direction to head.
5> And does your engine smoke continuously or only when you rev it up ??
Jammy
You are very crooked.
I have already given the gypsy for diagnosis. Compression tested and found okay. Electronic distribution coil is changed and has stopped the smoking.
Will wait for a couple of days to know status.
Dwarak
Last edited by Eddy : 10th October 2009 at 15:35. Reason: Please avoid posting multiple back to back posts.
dwaraka is offline   Reply With Quote
Old 10th October 2009, 18:01   #96
Jaggu's Avatar
Dwarak coil and smoke somehow doesnt ring bells, do check further if you are planning to sort this 100%. Hope there was no oil consumption otherwise?
ps: I have moved the post to IsuzeGypsy thread
Old 10th October 2009, 19:26   #97
Thanked: 226 Times
Thanks Jaggu,
I got call from Dale Hunter who is attending to my isuzu engine that, vehicle started smooth after he fixed the starter solonoid and electronic distributer coil. No misfiring and no visible smoke.
I am visiting him on monday to check the claims and trial run it for few kms.
Old 10th October 2009, 20:25   #98
Jaggu's Avatar
Good news Dwaraka, hope thats the end of smoking. Do rev her a bit as on OTR situation just to be sure.
Old 12th October 2009, 13:55   #99
siddartha's Avatar
Thanked: 24 Times
Originally Posted by dwaraka View Post
Siddu,
Dwarak
Dwarak
good news, glad it wasnt anything major!
Old 24th November 2009, 16:02   #100
Thanked: 226 Times
Folks,
Am back here with some good news.
1 > Smoking has completely stopped : Reason for smoking was engine head gas vent, which was supposed to be connected to air filter was wrongly connected to suction manifold of the mpfi. Suction was so powerful, it was drawing the oil spray in the engine head and mixed with fuel , injected into the cylinders. Hence, the smoke. It took an Ambassador mechanic to point out in two minutes. Thanks to Swastik Viji and Vijay Reddy for asking me to bring the Ipzy to Race Dynamics. Last OTR at Chikkaballapur was a real fun with Ipzy.
2 > I had a western ghat travel in my Ipzy saturday to monday i.e. 21st to 23rd Nov. Though the roads are horrible for cars , for Ipzy it was a cake walk. Was doing steady 40 - 60 kmph in ghat section, where as others were doing at max 20kmph. I thoroughly enjoyed the drive, no issues with Ipzy whatsoever. Although, I experienced drag when i pressed throttle to build torque, which I feel is because of MPFI issue over carburator.
3 > On Nice road, Mysore road and between Yelwala to Kushalnagar I could touch speed of 125 kmph with no hitch. Constantly kept speed of 80 -90 kmph. Because of the weight of isuzu engine and gearbox plus body weight, ipzy stood rock solid on road at 125kmph speed.
Conclusion: Am happy with implant and thank MM 440 a.k.a. jammy Anand for his suggestions and help.
Old 24th November 2009, 16:13   #101
Rudra Sen's Avatar
Thanked: 4,295 Times
Now just something to workout for wheel arches touching tyres.
Old 24th November 2009, 16:13   #102
siddartha's Avatar
Thanked: 24 Times
how come nobody else and more so no other mechanic was able to notice this?
Old 24th November 2009, 16:22   #103
Thanked: 226 Times
I really wonder. Horse vision I say.
Old 24th November 2009, 16:32   #104
Jaggu's Avatar
Glad to know its sorted, but remember i told you its not a coil issue
One doubt ipzy engine is carb or mpfi?
Old 24th November 2009, 16:42   #105
Thanked: 226 Times
Jaggu,
Distributer coil was first culprit for misfiring. Ipzy is mpfi version.
Powering Headphones ScarySkulls In-Car Entertainment 12 21st November 2015 13:56
Powering up Power of Gypsy, Should I go for it? airwolf9211 4x4 Vehicles 13 1st March 2011 01:08
Good speaker cables from powering alpine components ravigop In-Car Entertainment 6 29th January 2009 17:55
New Engine powering the Fabia Soon abhinav.gupta88 The Indian Car Scene 129 9th January 2009 15:06
Powering the vehicle with lemons ! ! rags The Indian Car Scene 13 23rd October 2007 09:02
